Broken piston
Discussion in '2.5 Gen Tundras (2014-2021)' started by Kenz, Feb 4, 2025.
  1. Feb 4, 2025 at 6:54 PM
    Kenz
    Kenz [OP] New Member
    Have a 2014 with 87000 miles, oil changed every 5000 with full synthetic and Toyota filter. Started engine after sitting 3 days in 30 degree weather and very nasty knock o right bank. Thought it was cam chain tensioner. Took it to an independent shop that specializes in Toyota. Ended up pulling coils and plugs on right bank. No compression on #6 cyl. Bore scope shows that piston isn't going up and down. Trying to decide how to proceed. Obviously out of warranty. Anyone heard of Toyota stepping up on something like this. Everyone I talk to says this is unheard of. Appreciate any help.
  2. Feb 4, 2025 at 7:08 PM
    Retired...finally
    Any damage to the top of the piston? If so, maybe a valve got sucked. Some Tundras did suffer valve spring breakage.
  3. Feb 4, 2025 at 7:42 PM
    Kenz
    Looking for a bore scope to do some troubleshooting before I make a decision
  4. Feb 4, 2025 at 8:13 PM
    If the piston isn’t going up and down, you don’t have a broken piston per se, you have a broken connecting rod. I’ve never heard of that happening on a 5.7.
    Toyota will not be stepping up on a truck that’s well beyond the warranty period.
    Is there more back story here? If not, freak occurrence.
  5. Feb 4, 2025 at 9:08 PM
    AZBoatHauler
    So.Arizona
    Seems very odd that it would be fine when you shut it off but has catastrophic damage restarting a few days later.
    I don’t know what good a borescope is going to do if the piston isn’t moving. That broken rod in all likelihood has smoked the bottom end. Is there a puddle of oil under it?
  6. Feb 4, 2025 at 9:11 PM
    Kenz
    No back story. Babied most of it's life. The reason I'm thinking broken piston is the knock doesn't seem to be bad enough to be a broken rod. I am thinking the crown of the piston broke off. Just a hopefulI guess .Will find out when I tear it down.
  7. Feb 4, 2025 at 9:15 PM
    AZBoatHauler
    So.Arizona
    That would be a really odd failure.
    Cpl_Punishment likes this.
  8. Feb 4, 2025 at 9:27 PM
    So you think it broke at the wrist pin? Or that the top of the piston could separate from the bottom part, even though it’s all one piece?
  9. Feb 4, 2025 at 9:49 PM
    Kenz
    Just a theory that piston crown broke off. Noise doesn't sound like anything striking the block. No holes in oil pan. Nothing external. Neverexpecteda Toyota to fail like this.
  10. Feb 5, 2025 at 3:48 AM
    blanchard7684
    blanchard7684 New Member
    Was this towed to the shop?
  11. Feb 5, 2025 at 6:28 AM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    For that to happen it would require a ring or the piston itself to essentially weld itself to the cylinder wall which would be pretty odd to "just happen"
  12. Feb 5, 2025 at 6:51 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Broken piston almost guarantees a ruined zylinder.
    Seek ye a used engine. If any are out there.
    1lowlife, Mdl and Cpl_Punishment like this.
  13. Feb 5, 2025 at 8:12 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, DIY Traction Bars, Tuning by snivspeedshop.com
    Odd for it to "just happen". Search all Toyota forums (not)plenty of rod /wrist pin/piston failures on the(supercharged) 5.7. Not at a high level but are out there.
  14. Feb 5, 2025 at 8:15 AM
    Really
    Mdl[QUOTED] likes this.
  15. Feb 5, 2025 at 8:17 AM
    AZBoatHauler
    So.Arizona
    Links would be great if you can provide any. I’m on here and ih8mud and have never seen it.
  16. Feb 5, 2025 at 8:43 AM
    Couldn’t find any confirmed wrist pin failures when I searched. One thread that speculated that was it, but the motor was replaced and never confirmed that failure. Same motor had previously had all 32 lifters replaced for some reason. Soooo, coming up blank on that particular failure, not common it seems.
    Cpl_Punishment and Mdl like this.
  17. Feb 5, 2025 at 8:48 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    My response to this thread was off as majority were on supercharged engines. So my fault for not paying attention.
  18. Feb 5, 2025 at 8:49 AM
    That would certainly seem more plausible, didn’t see any of those either, but it was a cursory search, not a comprehensive one.
  19. Feb 5, 2025 at 8:55 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Some on tundratalk/solutions. A few PM's where people didn't want to admit they grenaded their engine. Definitely not a "plenty as I said. Thanks for keeping it real.
    Saltyhero13 and AZBoatHauler like this.
  20. Feb 5, 2025 at 8:59 AM
    AZBoatHauler
    So.Arizona
    Boost can do bad things to good engines!!
    Mdl[QUOTED] and Cpl_Punishment like this.
  21. Feb 5, 2025 at 10:08 AM
    CasperTheFriendlyTundra
    CasperTheFriendlyTundra New Member
    Bore, hone, and send it.
  22. Feb 5, 2025 at 10:14 AM
    bflooks
    bflooks New Member
    Metrowest MA
    or if you don't want to deal with it: https://xatracing.com/XAT-3UR-full-build.html
    :anonymous:
    I feel for you OP. Surprised engine failures for something you didn't try to do isn't exactly an easy pill to swallow. If you go used, get one with with a warranty so you can have some sort of confidence it's running without issues. They're also $4-8k which is why I went the XAT route so I'm not dealing unknowns. YMMV. Good luck!
    Rdrcr, Saltyhero13, Mdl and 1 other person like this.
  23. Feb 5, 2025 at 10:27 AM
    Unfortunately it sounds like these motors cannot be bored and honed.
  24. Feb 5, 2025 at 10:28 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Interesting.
    Neither price included shipping to the customer.
    Keep or use stock parts. :eek2:
    The cheapest option, you send them your engine on your dime.
    With all the bells and whistles and they supply the engine, convert to 6.8 liter.:eek:o_O:thumbsup:
    Rdrcr and HulkSmurf14 like this.
  25. Feb 5, 2025 at 10:35 AM
    centex
    centex New Member
    Why not?
  26. Feb 5, 2025 at 10:38 AM
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
    Wow, at that price I might as well grab a spare. ;) Not knocking them as I'm not familiar; those prices just seem like a lot.
    bflooks and 1lowlife[QUOTED] like this.
  27. Feb 5, 2025 at 10:38 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    You can hone anything. Just like you can milk anything that has nipples!
    :thumbsup:
  28. Feb 5, 2025 at 10:42 AM
    So much truth
  29. Feb 5, 2025 at 10:45 AM
    One of our resident Toyota techs responded in one of the existing threads that mentioned wrist pin failure that these blocks are not designed to be machined, bored, honed whatever. There is a coating or plating that’s applied that doesn’t allow that to be done easily or maybe at all.
    @empty_lord was the poster in that thread I believe. I am not the authority on the topic for sure, just sharing. He could expand on that if he wishes.
  30. Feb 5, 2025 at 10:46 AM
    bflooks
    bflooks New Member
    Metrowest MA
    #nobodypayslist - pick up the damn phone, there may be pleasant surprises on the other end (though their voices are a bit deep for my liking).
    Seriously, though. They've been amazing, and while even a discounted core wasn't in the plans, either, it saved time on having to get the motor pulled, shipped, waiting, risking being told it couldn't be repaired, etc. The premium, for me, was worth it. They also have a short block option, too. Just tossing it out there since you don't know what your getting with a used engine.
