Broken valve cover bolts
Discussion in '1st Gen Tundras (2000-2006)' started by randomuser72, Jul 13, 2021.
  1. Jul 13, 2021 at 9:16 AM
    randomuser72
    randomuser72 [OP] New Member
    2005 Tundra 4wd
    Hey y’all
    so I was having a small oil leak from the valve covers, and since I recently got the truck I decided to change the valve cover gaskets and everything that goes with them. Well, taking the bolts out, two broke, same one on each side. Any tips on getting them out? Or thoughts on how to move forward? Thanks for any help 67EB5367-A6B2-4685-991A-6CCFAC936762.jpg D08AFB25-EB17-41E2-9C6F-9FA601D886A5.jpg
  2. Jul 13, 2021 at 9:22 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    @bmf4069 had this same issue I think. Tagging him for help.
  3. Jul 13, 2021 at 9:36 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Ouch, that's in a tough spot too. Good thing is they shouldn't have much torque on them say an ez out will make quick work of them.
    randomuser72[OP] likes this.
  4. Jul 13, 2021 at 10:10 AM
    randomuser72
    2005 Tundra 4wd
    Thanks guys, I’ll get an ez out kit. I don’t think I’d be able to get a drill in there, y’all think I can turn it by hand?
  5. Jul 13, 2021 at 10:12 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    I used an easy out on 2 of my broken ones, and the 2 others that wouldn't move, I drilled and tapped. It's been 9 months since I did my VCG and I have no leaks....
  6. Jul 13, 2021 at 10:16 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    I had that issue on an N52 in a BMW once. I applied PB blaster, let it soak overnight, then use needle nose pliers to apply pressure and twist and it worked for me. EZ out by hand might be difficult.
  7. Jul 13, 2021 at 10:19 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Vise grips would work too if you can catch a thread.
    Glock 40 and randomuser72[OP] like this.
  8. Jul 13, 2021 at 10:33 AM
    randomuser72
    2005 Tundra 4wd
    I did try soaking in pb and trying needle nose and channel locks I couldn’t get it to budge and snapped some of the exposed bolt. I think the po cross threaded it when putting it in. The other bolts were barely in tighter then finger tight
  9. Jul 13, 2021 at 10:37 AM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Drill a hole through a piece of metal you can hold onto, then use that piece of metal as a guide so the drillbit doesnt walk.
    if an ez out needs a pilot dimple*
    dont let the bit grab the guide and cut your fingers off.
  10. Jul 13, 2021 at 10:59 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Jam the easy out into a 9/32 socket and use a 1/4" drive ratchet.... easy peazy. I'm pretty sure I have a few pictures of my extraction/tapping in my rebuild thread.
    **Post #193 has photos of how I removed the broken studs.
  11. Jul 13, 2021 at 12:24 PM
    300BLK
    300BLK New Member
    Genius. Thanks for the tip
    N84434[QUOTED] likes this.
  12. Jul 13, 2021 at 12:31 PM
    randomuser72
    2005 Tundra 4wd
    Thank y’all for the help and tips, I’ll get an ez out today after work and give that a try, will report back when I get them out
    Glock 40 likes this.
  13. Jul 13, 2021 at 12:35 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Also might help to have a punch. Hammering against the threads goes a long way.
    N84434 likes this.
  14. Jul 13, 2021 at 12:39 PM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Make sure to use a center punch BEFORE drilling holes. You'll need all the guidance you can muster, mister...
    Sirfive likes this.
  15. Jul 13, 2021 at 3:02 PM
    That conventional oil makes the inside of the engine look like Trumps face. Crazy.
    FirstGenVol and des2mtn like this.
  16. Jul 13, 2021 at 3:10 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    15whtrd and des2mtn like this.
  17. Jul 13, 2021 at 3:14 PM
    2mchfun
    Left hand drill bit, if you need to get a bit extension, get a few bits in case you break some.
    N84434 likes this.
  18. Jul 13, 2021 at 3:33 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Just curious @randomuser72 , did you plug the coils back in so as not to forget which cylinder they were attached to or pull them out that way ?
  19. Jul 13, 2021 at 4:36 PM
    randomuser72
    2005 Tundra 4wd
    Alright so Amazon had just about everything I think I’ll need, should be here tomorrow or the next day.
    @BubbaW yes I only pulled them out for the picture, to get the cover off but I will number them when trying to get the bolts out.
    Thanks again to everyone for the help, I appreciate it
    bmf4069, BubbaW and 2mchfun like this.
  20. Jul 13, 2021 at 4:46 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Good luck on bolts, patience and let bit do the work !
    2mchfun likes this.
  21. Jul 13, 2021 at 4:50 PM
    2mchfun
    Don't forget to keep a vacuum running near the drill bit sucking shavings as you go, in other words, find an assistant.
    BubbaW and N84434 like this.
  22. Jul 13, 2021 at 5:10 PM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Yes, Absolutely! I had my shop vac hose laying adjacent to the drill work area while I was drilling. It's a must do.
  23. Jul 13, 2021 at 5:16 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Use tape and plastic to cover the whole engine cover area, can’t have any shaving inside those heads
  24. Jul 13, 2021 at 5:18 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Best is use center punch and left hand drill bits, it will auto unscrew itself when you almost hit the bottom.
    2mchfun likes this.
  25. Jul 13, 2021 at 5:20 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Turbo sockets are what I use. A 6mm turbo socket would have that sucker right out.
    Assuming it didn’t break flush. If it broke flush, easy out
    2mchfun likes this.
  26. Jul 13, 2021 at 6:49 PM
    Wahoo155
    Wahoo155 New Member
    Lee
    Southside Virginia
    2008 Salsa Red
    0CD64CFE-0E4E-44CD-8ABA-8BC79901C2C7.jpg EBCFC616-C9C5-4D36-9D79-ADAFF5C36540.jpg 75045F41-F3C8-43BD-8ED1-8658AA982368.jpg
    I did my valve cover gaskets 2 weeks ago and had the same bolt break off on the passenger side. I sprayed with PB Blaster, let sit over night and used vise-grips to try and remove but wound up breaking off the remaining part of the bolt even with the head. I used a right angle drill to drill out the bolt starting with a drill punch, then progressing with drill bits until removed. Then used an M-10 size tap and die to retread the hole. Still no leaks so far!
    jerryallday, FirstGenVol and bmf4069 like this.
  27. Jul 13, 2021 at 7:17 PM
    randomuser72
    2005 Tundra 4wd
    Thank y’all for the tips, I wouldn’t have thought about the vacuum or coving it with tape and plastic until it was too late.
    I’ll grab some turbo sockets for the side that isn’t broken flush
    Thanks for the tap size, I’ll order one now.
    I feel a little better not being the only one who’s broken these bolts haha
    2mchfun likes this.
