Broken Wheel Sensor Identification
Discussion in '2.5 Gen Tundras (2014-2021)' started by karlhungus, Dec 31, 2022.
  1. Dec 31, 2022 at 2:16 PM
    karlhungus
    karlhungus [OP] New Member
    2019 TRD Sport 5.7 4x4
    Had dash lights flashing. 4Hi/4lo,ABS, TCS. No CEL. Looked under the truck and found the Left Rear sensor had broken off. Went to the shop and we could not find the broken part in his system. Searching came up with nothing. Looking up ABS sensor shows Front and Left or rear center. The attached picture is from the front.
  2. Jan 3, 2023 at 7:12 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    texasrho83 likes this.
  3. Jan 3, 2023 at 7:23 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Once you replace, install sensor guards so you don't have to worry about this happening again
  4. Jan 3, 2023 at 8:05 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Truck definitely has a wheel speed sensor on all four corners at each wheel/tire combo. My assumption is they are all the same as the just count the teeth of a gear rotating. It sees/creates a pulse each time a tooth of the gear passes by.
    All 4 report data to the ABS ecu to drive speedometer, odometer, and monitor wheel slip/traction control ect.
    Are you just saying you are having trouble finding a replacement sensor for the left rear?
