Bumpstop question
Discussion in 'Suspension' started by Jimes, Dec 14, 2018.
  1. Dec 14, 2018 at 8:35 AM
    Jimes
    Jimes [OP] New Member
    Bay Area, California
    2015 toyota tundra trd pro
    I just received my sets of wheelers 01superbumpkit for my 2015 tundra. These things are huge. I attached pics of the original and the new ones just set in place. I have to jack the truck up to get them on. For anyone who has these on their trucks, are they supposed to sit in the LCA the entire time like in the picture? Just want to make sure before I install them. Thanks. A708F1DC-0C72-4A0B-802A-BBE5DBFFB736.jpg9A1490D9-CB7F-4FEE-A36E-6D4164FCA037.jpg
  2. Dec 14, 2018 at 8:38 AM
    Tacotundra
    Tacotundra New Member
    Vegas
    2022 Tundra
    Depends on how much you have your coilovers cranked if the gonna touch or not. And if its touching will be fine.
  3. Dec 14, 2018 at 8:39 AM
    15whtrd
    15whtrd Mr. Blonde
    They do work for stock ride height but they are very close to always being in contact with the LCA. I had them on my truck at stock ride height. They worked but it did stiffen up the ride. It cornered better LOL but it was a much harsher ride driving down the road. I have since lifted the front of my truck 2 inchesWith the pro suspension. I kept the stops on for a while.Recently I removed them and put the stock ones back on. I could tell it was still coming into contact and not letting me experience my new shocks as well. In my opinion they would be better suited for someone in the 3 inch or 4 inch lift range.
    They do help a lot and a bottom out situation. They are not harsh in that aspect.
    Tacotundra likes this.
  4. Dec 14, 2018 at 8:41 AM
    Jimes
    They’re touching already. I wedged the bump stop in. This is how the coil overs are set. Passenger then driver side4E62D598-AE97-4CC4-99C7-02914D647909.jpg28F9C790-810C-4B30-BE56-D9505673CBA5.jpg
  5. Dec 14, 2018 at 8:42 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    No, there is space buffer, just went outside and took this pic for ya
  6. Dec 14, 2018 at 8:42 AM
    Jimes
    Well that sucks. Mine seem be touching the entire time
  7. Dec 14, 2018 at 8:43 AM
    Tacotundra
    Vegas
    2022 Tundra
    My truck is at 3 in of lift up front and they dont rest on the lca. How much lift you have up front?
    14burrito likes this.
  8. Dec 14, 2018 at 8:46 AM
    Jimes
    Should be 2.5” to 3” in front and 2” rear. Got the king OEM Shocks with ext travel option.
  9. Dec 14, 2018 at 8:47 AM
    Jimes
    I will have to see how much the suspension settled. Have to take measurements
  10. Dec 14, 2018 at 8:48 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Im at 3" with space.
    Distance will be lift dependant.
  11. Dec 14, 2018 at 8:49 AM
    Tacotundra
    Vegas
    2022 Tundra
    Maybe closer to 2.5 then if they touching.
  12. Dec 14, 2018 at 8:51 AM
    15whtrd
    15whtrd Mr. Blonde
    That’s weird. I had a small gap at stock hight.
  13. Dec 14, 2018 at 8:52 AM
    Jimes
    The suspension more than likely settled and need to adjust the coil overs. Great. Another alignment.
  14. Dec 14, 2018 at 8:53 AM
    Tacotundra
    Vegas
    2022 Tundra
    I was thinking the same. But every truck different. I run one spacer under mine also and still have a gap.
    15whtrd[QUOTED] likes this.
  15. Dec 14, 2018 at 8:55 AM
    Tacotundra
    Vegas
    2022 Tundra
    On my wife's 4runner I have 2.5 lift up front and have a small gap with the super bumps on there.
    15whtrd likes this.
  16. Dec 14, 2018 at 8:55 AM
    Jimes
    Damn. Ok. I’ll have to deal with it on Sunday morning if I want to keep these. Was looking forward to putting them on my truck. Thanks everyone for the info. I appreciate it.
    Tacotundra[QUOTED] likes this.
  17. Dec 14, 2018 at 9:04 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    I just looked at your pic again, that's not where I put them, same angle on mine:
    They'd probably have contact up there, mine are behind.
    15whtrd and Tacotundra like this.
  18. Dec 14, 2018 at 9:06 AM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    It looks like your superbumps are installed at the front location. Try replacing the rear bumpstops instead of the fronts.
    joonbug, TheBeast and 15whtrd like this.
  19. Dec 14, 2018 at 9:06 AM
    Jimes
    I guess there should be another question to ask. For those of you who have the same king setup, how many threads do you have showing and at what point will it be too much and my ride gets worse?Right now it drives great. As a heads up. After putting like 2000 miles or more on the new Kings, they have never been adjusted since the initial install. So definitely settled like a 1/2” from my measurements.
  20. Dec 14, 2018 at 9:07 AM
    14burrito
    2014 SR5 CM 4x4 5.7
  21. Dec 14, 2018 at 9:08 AM
    Jimes
    Are they only supposed to be on one side? Not replace all four? Let me try that. I tried to replace the front set.
  22. Dec 14, 2018 at 9:09 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    No, you only need to replace 2, usually the ones behind
  23. Dec 14, 2018 at 9:09 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Don't want to be the bearer of bad news....but Kings are notorious for their coils being garbage and clapping out.
    With that said, its pretty darn close to a 2 - 1 radio, curious what your distance measures in regards to the threads showing.
  24. Dec 14, 2018 at 9:10 AM
    Tacotundra
    Vegas
    2022 Tundra
    Good eye. I run mine in the rear position also
    JoshuaA[QUOTED] likes this.
  25. Dec 14, 2018 at 9:12 AM
    Tacotundra
    Vegas
    2022 Tundra
    JoshuaA likes this.
  26. Dec 14, 2018 at 9:12 AM
    TheBeast The Beach
    yep
  27. Dec 14, 2018 at 9:14 AM
    Jimes
    So far the shocks have been great, but only time will tell. I don’t abuse the suspension when I wheel. I’m sure I could go faster and harder, but I don’t like dealing with the truck being down for repairs. So slow and steady for me. As for the measurements I measured 24 1/4” from center of hub to fender on passenger and 24” on the driver. I initially had them both at 24 1/2” when I initially installed them and aligned.
    15whtrd likes this.
  28. Dec 14, 2018 at 9:15 AM
    TheBeast The Beach
    stock King on passenger (7 or 8 I think) and 12 threads on driver to compensate for lean.
  29. Dec 14, 2018 at 9:16 AM
    TheBeast The Beach
    mine on similar setup.
    14burrito and Tacotundra like this.
  30. Dec 14, 2018 at 9:17 AM
    Jimes
    Thanks. Let me try the rear ones. Well. Looks like I have an extra set cause I figured I was supposed to replace all of them.
