Busted A/C! What are my options?
Discussion in '1st Gen Tundras (2000-2006)' started by Nick244, Oct 1, 2024.
  1. Oct 1, 2024 at 3:20 PM
    Nick244
    Nick244 [OP] 05’ RCLB 4.7 4WD with 27k miles
    Nick
    California
    Hey y’all
    I bought my 05’ with a busted A/C. After a good while of full time living out of it, and numerous complaints from my girlfriend, I’ve been investigating the issue. I typically stay coastal, so it’s been a manageable issue so far, but getting stuck in traffic inland feels like a near death experience.
    There are likely a few problems, mainly the doors to control air flow don’t work when trying to isolate the upper vents, and the air blows cold-ish. The system is charged. I think the issue is the compressor, compressor sensor, temp control gauge for evaporator, and maybe the cable for the vent doors. (I’m not a mechanic so don’t take my diagnosis too serious).
    I got it casually checked out by a mechanic, but a proper diag is about $200 in California. The main issue seems to be my budget, and the fact that the job cost is likely 90% labor and hourly is $120-150 out here.
    I’m looking for any Tundra specific input regarding the issue, as well as wondering if it’s worth traveling to cheaper area for? I’m about to head to Nevada/Utah/Colorado, and confirmed with a mechanic in Utah they charge $80 an hour. I don’t mind camping for a night or two to save a couple hundred, but would love to hear anyone experienced in doing such a thing.
    I’m sure there are no reasonable alternatives to A/C, and I really can’t spring $1k+ for cold air, but it’d be a huge quality of life upgrade.
  2. Oct 1, 2024 at 4:51 PM
    shifty` I'm a member of a country club
    The blend door is known to snap.
    The evap coil is known to get dirt but is cleanable.
    If the A/C button's LED is flashing, it's often a loose ground next to the compressor, which sometimes happens after a timing belt change, wrong length screw gets installed.
    Really, you could do yourself a world of favor if you can find someone with A/C pressure gauges, and you can barter with them to measure the high and low side so we know if your system is properly pressurized or not. If it's not, you really should seek out an A/C specialist. Don't use generalist shop.
  3. Oct 1, 2024 at 5:16 PM
    Nick244
    Nick
    California
    It is still pressurized. Just had a mechanic check it for free! Didn’t seem eager to do the job themselves but offered and happy to help otherwise.
    he said it was properly pressurized too. No shifting of pressure.
    FrenchToasty likes this.
  4. Oct 1, 2024 at 5:25 PM
    Is the pressure supposed to shift from high to low? I thought the high side was supposed to be higher than low by at least 50%?
    Anyway, I would urge you to check the blend door. Check this: https://www.tundras.com/threads/cold-air-behind-glove-box-solved.123112/#post-3155626
    Also, check the evap coil isn't clogged. These videos may help.
    Weagle likes this.
  5. Oct 1, 2024 at 5:46 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    This thread covers the inspection and lubrication of the mechanisms and cables.
    Vent Control Binding - Solved
    Pressures are irrelevant without knowing the ambient temperature.
    FrenchToasty and shifty` like this.
  6. Oct 1, 2024 at 7:05 PM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    watched the one with the 2004 Sequoia. Wow that was nasty. That is definitely on my to do list although every time I check something like that on my truck it's never as bad as what's in the videos
    I guess I need to search on what to do for my air filter that supposedly doesn't exist on the 06 tundras I had to get in there to replace my ECU and there was the thinnest piece of foam that appeared to be permanently installed. it was dirty, but nothing comparable to what was in that video
  7. Oct 1, 2024 at 7:20 PM
    Yeah that video was nuts. I can show pics of mine from the “what’s you do today” thread. It was pretty pristine in comparison.
  8. Oct 1, 2024 at 7:23 PM
    Weagle
    Prattville, AL
    i'm going to first check my cabin temperature I know mine isn't close to 50 like he ended up with after he cleaned it
    I just watched a video where people are using 3-D printers to make an air filter that goes behind the blower motor for these trucks
  9. Oct 1, 2024 at 7:29 PM
    Talon2006
    Talon2006 New Member Vendor
    You can also turn on the AC and see if the compressor engages. If it does see if the cold side gets cold and the hot side gets hot. Cold side is tropically after the orfice tube/ evap valve.
    That can give you an idea of the compressor side of things is working. From there you’re probably gonna need some AC gauges. I have had good luck with cheap ones on Amazon and harbor freight. The real game changer is a vacuum pump, but I have fixed several ac systems before without one.
    shifty` and Randy Morton like this.
  10. Oct 2, 2024 at 5:08 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    I wouldn't recommend this to people who aren't handy with a wrench.
    my dad and I made a lot of $$$ cause people, who ARE handy with a wrench, absolutely ruined their a/c system cause they thought a few gauges, a can of "freon", and or a can of a/c stop leak from the zone would fix their issue.
    OP do yourself a favor and find someone who has a shop like my dad's.
    A automotive A/C specialist.
    Our shop had vehicles from other shops since we had the proper equipment to PROPERLY service a/c systems along with our own customers.
    KNABORES and JakeJake like this.
  11. Oct 2, 2024 at 7:17 AM
    Talon2006
    Everyone has the capacity to learn new skills and advance themselves. OP seems like someone who is interested enough to learn. Got to start somewhere.
  12. Oct 2, 2024 at 7:29 AM
    FishNinja
    Lee
    06DC2wd
    I mean, yea, but probably best to learn under the guidance of a professional. You know, where you're not gambling with $2k in repairs
  13. Oct 2, 2024 at 8:57 AM
    I'm on the fence on this one. I've definitely tinkered in the past with A/C systems in cars, and at least diagnosed or repaired my A/C system.
    I learned the basics of how the system works, how to check if the A/C clutch is engaging, how to bypass pressure switches/jumper relays to diagnose if it's an issue of low refrigerant and misc other stuff. I'm not the kind of d-bag that would just release refrigerant in the open air, I know if the system is low, you need to have the system evacuated properly, have lines vacuumed and leakdown tested, replace seals, TXV etc.
    Even though I know all that stuff, I would only ever do it to diagnose. I've learned the hard ware a couple of times, A/C is one of two things on a vehicle where a specialist is mandatory, even seasoned mechanics often don't have the equipment/proper tools/know-how, and you should NEVER go to a chain store or generalist mechanic, it's not worth risking. Like, if you're having ankle problems, why would you see a Cardiologist, or even a General Practicioner? Always go to a decently rated Auto Air/Heat shop for this shit. Same with driveline stuff, always go to a driveshaft shop.
    Roborob70 likes this.
  14. Oct 2, 2024 at 7:12 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Is the clutch engaging and if not have you traced the electrical from the fuse to the relay to the compressor clutch? A system with a failed clutch can show equal pressures on high and low side. Gauges can be rented "for free" at LAPS. Also have vacuum etc.
    I thought this guy gives a good quick description on how an HVAC system works including what the high/low readings mean, and this guy gives a very in depth overview of more components like diagnosing electrical and compressor clutch issues.
    Have swapped a compressor with bad clutch before after having system evacuated and later recharged at a shop for just a little $, and also diagnosed bad clutch to replace while keeping compressor and hence no need to evacuate system.
    shifty` likes this.
  15. Oct 2, 2024 at 8:22 PM
    Nick244
    Nick
    California
    Heard. I really appreciate everyone’s resources and advice, but this is probably the most realistic. It seems to have stumped the two experienced mechanics that have attempted to diagnose the issue, and this is good insight to just inquire with a specialist. Considering that 90% of the job is labor, I don’t want the mechanic to be fumbling the issue.
  16. Oct 3, 2024 at 6:05 AM
    Yup, if there's anything I've learned over my years:
    • Never go to a chain store for anything, not even an oil change.
    • Always use a mechanic shop well-versed in your brand, not some "does all brands" place.
    • Two times to never use a "generalist" shop: A/C and anything driveline related. Always use an auto heat/air specialist for A/C issues, and always go to a driveshaft/driveline shop for anything potentially linked to driveshaft/driveline.
    PennSilverTaco and AresEsMaLo like this.
