C1241, C1333, C1340 errors
Discussion in '2nd Gen Tundras (2007-2013)' started by frank_m_roberts, Jan 23, 2022.
  1. Jan 23, 2022 at 5:40 PM
    frank_m_roberts
    frank_m_roberts [OP] New Member
    I currently have lost the ability to switch to 4 wheel drive. I received the above errors in my 2007 tundra after several weeks of driving it in very cold conditions with lots of salt and ice on the road. Most of the time I was in 4 wheel high. Bases on other threads I have read I replaced the rear speed sensor and wiring harness to the sensor. Unfortunately this has not resolved the issue. I also have checked the fuses in both fuse boxes (under hood and in cab). Any ideas folks?
    Thanks for your help!
  2. Jan 23, 2022 at 5:43 PM
    frank_m_roberts
    Current idiot lights flashing include: 4 low, 4 hi, abs, traction
  3. Jan 25, 2022 at 2:25 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
  4. Jan 27, 2022 at 7:43 PM
    frank_m_roberts
    Yes I replaced the speed sensor wire with a factory Toyota replacement.
  5. Jan 27, 2022 at 10:10 PM
    audiowize
    Paul B.
    And when you did the left rear speed sensor, you used an OE part I hope? If the wiring looks good it's not as hard as it sounds to slip the axle out to see if maybe the tone ring has failed and the sensor has nothing to read.
  6. Jan 28, 2022 at 7:57 AM
    frank_m_roberts
    Audiowize, I did not use an OE part when I did the sensor. Do you believe that the sensor could be suspect?
  7. Jan 28, 2022 at 5:22 PM
    audiowize
    Paul B.
    Oh yeah, discount auto parts stores are not exactly known for good quality electrical parts unless you get something that is made in Japan (it will probably cost more than all the other options).
  8. Jan 29, 2022 at 7:41 AM
    frank_m_roberts
    I will look for an OEM speed sensor. In the event that this fixes it, do I need to clear the codes to make all the blinking lights on the dash stop? Or should it just stop blinking once it runs the test and sees that the circuit is functioning? I have a blue tooth OBD2 reader, but haven't really found an app for my phone that I like. Are there recommendations?
  9. Jan 29, 2022 at 7:42 AM
    audiowize
    Paul B.
    The dash light willl likely go off on its own.
  10. Mar 16, 2023 at 6:53 PM
    Bigchilly
    Bigchilly New Member
    2017 tundra
    OP
    What ended up being your issue ? I’m having the same run around on my 17’ tundra
  11. Dec 27, 2023 at 3:45 AM
    DerekROB
    DerekROB New Member
    I also have a 2017 Tundra with 4HI and 4LO lights flashing, traction control on, ABS on, and i can't use 4 wheel drive. i've replaced the sensor, replaced the rear harness, swapped front sensor to back to ensure the new sensor was good and it is. HELP! PLEASE!!! I keep getting the same code C1333
  12. Dec 27, 2023 at 7:11 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I would check that sensor and ensure it hasn't been damaged. You may need to pull the sensor and look that it doesn't have excessive grime or debris. Additionally to this you will need to follow most of the wiring to ensure it hasn't been damaged or consumed by rodents at any point. I would pull the wiring diagram on this site for your specific model, but I'm pretty sure they're mostly identical, but I'd go with the specific model and go from there. Check grounds mainly as those will be exposed usually and are more likely to be damaged by corrosion, rocks and other debris getting kicked up.
  13. Dec 27, 2023 at 7:48 AM
    DerekROB
    DerekROB New Member
    Wiring diagrams on this site? I guess i haven't seen them anywhere on here.
  14. Dec 27, 2023 at 8:47 AM
    blackdemon_tt
  15. Mar 9, 2024 at 6:59 PM
    LooseGoose2
    LooseGoose2 New Member
    2008 Tundra limited DC 4wd 5.7
    Any updates? I’m dealing with the same issues and codes. I’ve replaced the rear harness, replaced the axle, and tried 3 different sensors on the right rear wheel.
    The battery is new and 12.3 at rest and 13.7 when charging.
  16. Apr 10, 2024 at 4:16 PM
    LooseGoose2
    For anyone else with these issues - it was the frame harness had melted for reasons unknown. The new harness has been upgraded from the original so it may be more common than thought. The melted part was under the passenger side under the back of the cab.
    The original part# was 82164-0C180
    The updated part# is 82164-0C890
    This is for the non-flex fuel. I believe the flex fuel has different wires for the fuel pump
