Cab mount bolt seized. Rusted.
Discussion in '1st Gen Tundras (2000-2006)' started by ventorph, Jul 28, 2020.
  1. Jul 28, 2020 at 11:57 AM
    ventorph
    ventorph [OP] New Member
    Christian
    Las Vegas
    So I went to the local pic a part. Got a cab mount $7.00. Mine the rubber deteriorated and it sounded like a door was ajar. Drives me crazy. I can’t get the bolt out. Help !! Any tips or advice would help. Thank you.
  2. Jul 28, 2020 at 2:29 PM
    Professional Hand Model
    Hand Protectors
  3. Jul 28, 2020 at 2:40 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Have you tried heat and when that's done more heat?
  4. Jul 28, 2020 at 3:10 PM
    ventorph
    Christian
    Las Vegas
    Not yet. I have map gas torch. I’m a little intimidated by that for reasons I think the rubber will simple and burn. I don’t have access to work on my truck outside. I live in a condo and it’s not allowed. I will do it as a last option. I have to get this thing off.
  5. Jul 28, 2020 at 3:19 PM
    Hand Protectors
    Take pics. I don’t think anyone here has done this swap before. I’m interested in the how/to process.
    Pucks18 and ventorph[QUOTED][OP] like this.
  6. Jul 28, 2020 at 3:21 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    Not sure how much space you have to work with...but maybe use a sawzall?
  7. Jul 28, 2020 at 3:46 PM
    ventorph
    Christian
    Las Vegas
    Can’t get the angle. I tried.
  8. Jul 28, 2020 at 3:51 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I think PHM had a good trick, if you can get a drimmel in there, score the bolt all down the length, then take a cold chisel and basically open the nut, cut up into the rubber so you know you’ve got all the nut cut and ready to be smacked apart/open
    Hilandr likes this.
  9. Jul 28, 2020 at 3:53 PM
    ventorph
    Christian
    Las Vegas
    My choices are.1. Dremel. But, I can’t cut that metal bushing vertically. I could cut it off as high up as I can, but then what ?
    2. Pneumatic impact driver from the top.
    3. Heat.
    I was ready to push it over a cliff yesterday. So I figured I would take a break today. I just wanted some opinions.
  10. Jul 28, 2020 at 3:56 PM
    FrenchToasty
    Mo
    Bone stock
    Oh is the nut already off, or what secures it? Pound it up if that’s just a bushing. But yes on the big Bertha impact
    if just the bolt is stuck in the metal bushing, get a brass drift or a dead blow or something and just start pounding it up and out
  11. Jul 28, 2020 at 4:03 PM
    Hand Protectors
    Hammer the chisel into a groove you’ll make with a Multi-tool or Dremel.
    huntertn, Tundra2 and FrenchToasty like this.
  12. Jul 28, 2020 at 4:08 PM
    Hand Protectors
  13. Jul 28, 2020 at 4:11 PM
    FrenchToasty
    Mo
    Bone stock
    So I thought that was the nut, but I think that’s just a bushing that is the full length of the rubber. I think the nut is off but just the bolt won’t come out, I don’t know if an impact from top would do anything more than just break it free, then it could be pounded up
  14. Jul 28, 2020 at 4:13 PM
    Hand Protectors
    I thought this job requires jacking the cab up off the frame a bit?
  15. Jul 28, 2020 at 4:39 PM
    ventorph
    Christian
    Las Vegas
    Yes it does to remove any insert new mount. That’s the easy part.
  16. Jul 28, 2020 at 4:41 PM
    ventorph
    Christian
    Las Vegas
    Yes that’s the bushing that was housed in the rubber mount. I already pounded it. Put a bottle jack under it. Pumped it up until the rear wheel was almost off the ground. Nothing.
  17. Jul 28, 2020 at 4:45 PM
    ventorph
    Christian
    Las Vegas
    I think the problem with this is getting the dremel to cut it vertically. I can’t fit it in sideways.
  18. Jul 28, 2020 at 5:29 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    I replaced the right forward mount and bracket while repairing my frame and once I got the nut off, I soaked it with penetrating fluid and was able to beat it straight up and out. Didn’t need any heat on that one. Perhaps a good soaking, or throw a little heat on it and then immediately hit it with the penetrating fluid.
    FrenchToasty likes this.
  19. Jul 28, 2020 at 6:46 PM
    ventorph
    Christian
    Las Vegas
    How did you soak it. From above. Or did you spay it directly. Or maybe I should just put a bucket under it and spray the shit out of it. Good tip. I’m going to try this first.
  20. Jul 28, 2020 at 11:04 PM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    Break the bolt loose up top with impact?
    Isn't the bolt simply rusted/seized inside of the spacer? You'd think if you can get it broken loose up top that you should be able to pound it right up easily.
    Heat is the next best here, but I can understand why you wouldn't want the burning rubber smell in the complex.
  21. Jul 29, 2020 at 4:28 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    I sprayed from the top and from the bottom. Make sure to use a quality penetrating oil, like Knocker loose, kroil or PB Blaster. Applying heat will help the oil wick into the threads, if you can heat it up. Heck, drive over to the Walmart Parking lot and give it some heat, and spray it while its still hot.
  22. Jul 29, 2020 at 4:33 AM
    Hand Protectors
