Cabin Air Filter
Discussion in '1st Gen Tundras (2000-2006)' started by 2006Tundra, Aug 2, 2023.
  1. Aug 2, 2023 at 7:55 PM
    2006Tundra
    2006Tundra [OP] Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    Hey guys,
    I think I stumbled upon something here! Check out this video. I PM'd the guy on Instagram and the filter cost $35 shipped.
    Yes, their reusable and washable. Check out his instagram page @OCD4WD for more info.
    https://youtu.be/K3wif9u-Vuk
    G_unit3000 likes this.
  2. Aug 2, 2023 at 8:01 PM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    shifty` likes this.
  3. Aug 2, 2023 at 8:29 PM
    2006Tundra
    Lou
    Long Beach, CA
  4. Aug 3, 2023 at 12:13 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Forget the filter I want the push to start. :)
  5. Aug 3, 2023 at 5:33 AM
    There's one other member on here who has it, in their signature/truck mods section but I can't find them. I look under their name and see it once in a blue moon, forget about it, and move on. One of these days I'll jot it down.
    But here's one option: https://www.tundras.com/threads/06-dc-daily-driver-2wd-to-4wd-conversion.48447/#post-1259892
    One caveat: https://www.tundras.com/threads/1st-gen-lunch-table-general-discussion.60450/page-527#post-2235455
    artsr2002[QUOTED] likes this.
  6. Aug 3, 2023 at 5:40 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    My FGT has gotten along fine for 23 yrs w/o a filter. But since we in the blower motor area, my condensate drain drips hours after I've driven. I am in swampy SC but wondering if this is normal? Some to do it longer than my other vehicles.
  7. Aug 3, 2023 at 5:50 AM
    I feel like that's pretty normal. I don't run my A/C much. Condensate does build up on the coils, though, and continues to drip in the pan for as long as the evap coil holds condensate, drips into the tray, which drips out onto the floor.
    There are coil cleaning kits out there. Toyota makes a service kit. https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1571#post-3126837
  8. Aug 3, 2023 at 6:14 AM
    cran2
    cran2 New Member
    Folly Beach, SC
    07 Crewmax 4x4 and 03 Sequoia 4x4
    The filter works great. It was a really tight fit for my son’s 03 Sequoia. When you install, it will snap in once but you need to keep pushing until it snaps a 2nd time. The first time I pushed it in it was interfering with the the blower fan so I took it out thinking it wasn’t going to work.
    Btw here are the before and after of an 03 coil. I used an 18” pcs of flexible tubing taped to the shop vac nozzle, sucked all the nasty right away, then sprayed some of the coil cleaner.
  9. Aug 3, 2023 at 6:32 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    May be others but the only one I have saved is @MrDirtjumper from his 2wd/4wd build thread. He hasn't posted since last year but visited last friday.
    Knock, Knock @MrDirtjumper (Josh) request more detail Please
    06 DC Daily Driver / 2wd to 4wd Conversion
  10. Aug 3, 2023 at 3:11 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Maybe I need to do this myself. Seeing those pics makes me wonder how bad mine is. You pull out the blower motor resistor to get to this?
  11. Aug 3, 2023 at 3:20 PM
    cran2
    cran2 New Member
    Folly Beach, SC
    Yep, pull the glove box off and then a plug and two screws opens the coil access.
    The airflow out of the vents is so much strong after the cleaning.
  12. Aug 3, 2023 at 4:03 PM
    I didn't even need to remove the glovebox.
    Be careful when you pull the resistor out. It's both a tight fit, and ceramic, and has a penchant to crack to bits.
  13. Aug 10, 2023 at 2:14 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Have received 1 each from the 2 sellers mentioned in this thread and other thread. Have installed the one from Off-Road and volume does not appear to be lessened. Will run this awhile and then try other one.
