Cabin Filter Change.
Discussion in '2nd Gen Tundras (2007-2013)' started by MoToad, Apr 20, 2022.
  1. Apr 20, 2022 at 8:32 AM
    MoToad
    MoToad [OP] New Member
    Toad
    BC Kanuckistan
    2009 Tundra DLX
    Looks like it needed it. A lotta dust, a few bugs. Replacement straight forward. Drop the glove box and easily unclip the cover plate. The only 'bug' was the replacement direction. Pics show air flow arrow and lettering the same. To us easily confused it puts the lettering upside down with the arrow down. A few have said it probably doesn't matter but I can see you prolly get a better seal with the correct placement. That is, sharp edge up.
    WVI and gosolo like this.
  2. Apr 20, 2022 at 9:18 AM
    BayRunner
    2017 Tundra Platinum
    I also just changed mine with a STP filter..the one that was there did not have any arrow so does the arrow point up or down?
    gosolo likes this.
  3. Apr 20, 2022 at 9:36 AM
    tundratoofun
    tundratoofun Yall better rednekonize
    Glendale
    Beast
    I miss that style, I hate that the 2.5 has it inside the box. Way too easy to break tabs... Im still not sure if air flow up towards the dash or down towards the floor
    gosolo and BravoDeltaRomeo like this.
  4. Apr 20, 2022 at 9:57 AM
    skip1980
    skip1980 New Member
    Columbia, Missouri
    That's pretty clean. Wait till you pull one out with mouse terds that's been half eaten threw.
    gkelm and gosolo like this.
  5. Apr 20, 2022 at 11:28 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    The air definitely flows either up or down.
    15whtrd and GODZILLA like this.
  6. Apr 20, 2022 at 11:30 AM
    tundratoofun
    Glendale
    Beast
    It could go sideways... Things usually do for me pretty quick. LoL
  7. Apr 20, 2022 at 12:15 PM
    CTB Mike
    CTB Mike It's RED? My rods and cones must be screwed up!
    Southern Arizona
    2011 Red Rock Warrior
    Pretty sure the air flows downward. If it didn't all of the leaves and other garbage will be trapped in the bottom of the air box.
  8. Apr 20, 2022 at 12:17 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    :rofl::rofl::rofl::rofl::rofl:
    :thumbsup:
    GODZILLA likes this.
  9. Apr 20, 2022 at 12:39 PM
    @15whtrd
    Which way does the arrow go?!???? :anonymous:
  10. Apr 20, 2022 at 7:33 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    So as they beat me with common sense and "witness identification" the air flows down (comes from the cowl into the box and down) ARROW should point in the direction of air flow, meaning down.
  11. Apr 21, 2022 at 12:15 PM
    MoToad
    Toad
    BC Kanuckistan
    2009 Tundra DLX
    That's the new one.
  12. Apr 21, 2022 at 12:17 PM
    MoToad
    Toad
    BC Kanuckistan
    2009 Tundra DLX
    Down
  13. Apr 22, 2022 at 5:03 AM
    Slim Gym
    Slim Gym New Member
    2013 Tundra DC 4X4
    Arrow should point down. I confirmed by holding a sheet of paper in the slot while I ran the fan. The air flow pulled the sheet of paper down towards the fan. Very confusing. Most people put theirs in backwards.
  14. Apr 22, 2022 at 6:56 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    That is Clean compared to several I've found, leaves, dirt, fuzz built up an inch++ or so, haha did we breathe better after that swap out....
  15. Apr 22, 2022 at 10:17 PM
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    I changed mine shortly after I bought my Tundra. Here is what it looked when I pulled it out.
  16. Apr 22, 2022 at 11:48 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Nice and clean!
  17. Apr 23, 2022 at 10:17 AM
    Thumper_6119
    HEPA quality filtration going on there. That thing was soooo nasty.
  18. Apr 23, 2022 at 2:45 PM
    15whtrd
    15whtrd Mr. Blonde
    The arrow goes down unless it says this side up LMFAO!
  19. Apr 23, 2022 at 6:03 PM
    pnw tall trees
    pnw tall trees New Member
    Pacific Northwest
    07 Limited Crewmax
    I knew I had a mouse/rat issue and for the last 9 months have been spraying a peppermint oil/dawn/water mix inside the engine compartment at least once a week with good results; i.e., no visible poop and no chewed wires or tubes. I hadn’t changed the cabin filter for 2 years though. I pulled the filter and got this:
    There’s poop in them thar crevices and I was totally grossed out. I vacuumed out the area from inside the cabin and got some more crap out but it seemed to me like this was a BS situation. How could rodents get into the vehicle? I did some YouTube searches and discovered there’s a completely open slot directly above the cabin filter underneath the windshield wiper plastic molding. Watched the videos and knew it needed attention to prevent future infestations.
    The YouTubers I watched attached metal mesh over the openings using epoxy putty or drilled holes and zip ties. I didn’t want to drill holes if avoidable and the epoxy putty would make getting the mesh off a big hassle. I decided to use exterior grade tape materials to ensure that if I ever needed to get one off I would be able to do it without having to resort to a hammer and chisel. I got this:A1A5EF77-E062-4762-A19E-51B3B0FC35CB.jpg325D7681-576F-41B7-8C6F-60CE9D6F42E9.jpg
    The 3m mounting tape went down first against the body cleaned with isopropyl alcohol, then applied the 1/4” galvanized mesh, then covered the edges with the gorilla tape. Seems to be good. At least it will keep the critters out of the vehicle itself and future cabin filter replacements should not be nearly as hideous as this recent one.
    I will still apply the peppermint oil mixture to protect the engine compartment wires and tubes.
    ZappBrannigan and TILLY like this.
  20. Apr 23, 2022 at 6:39 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Did you cover the vent hole on the D/S beneath the wiper assembly? I missed it the first time covering the vents and still had them getting in. Just a heads up, its easy to miss.
  21. Apr 23, 2022 at 7:41 PM
    pnw tall trees
    Pacific Northwest
    07 Limited Crewmax
    Yes, good call. I covered all 5 openings including the little 5/8” hole between the two bigger openings I had pictured. Every hole is covered. Thank you for pointing that out.
    gosolo and TILLY[QUOTED] like this.
  22. Apr 23, 2022 at 7:45 PM
    TILLY
    Massachusetts
    :thumbsup:
    gosolo likes this.
  23. Apr 27, 2022 at 7:22 PM
    Kerthao09
    Kerthao09 New Member
    Thanks for the reminder
