Cable from Battery to Fuse & Relay Box
Discussion in '2nd Gen Tundras (2007-2013)' started by tundrabubba, Oct 18, 2023.
  1. Oct 18, 2023 at 2:36 PM
    tundrabubba
    tundrabubba [OP] New Member
    Andrew
    Hello,
    I have a question regarding a specific cable in my tundra (2008 DC SR5 4x4). There is a cable that is running from the positive side of the battery into the Fuse/Relay box. I cant exactly fiure out what cable that is. I need to replace it because its corroded badly. I found a Tundra part # 82122-0c220; but that seems to be the battery cable harness. ( I dont see that exact cable on there) Does anyone know if it is part of that battery cable harness, or a completely different part? If so, what is the part # for that.
    TY in advance.
  2. Oct 18, 2023 at 3:12 PM
    tundrabubba
    Andrew
    Its has the # 608 on it. Its goes straight into the fuse box
  3. Oct 19, 2023 at 7:20 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Getting into that fuse box is tricky. I've tried and couldn't get in - didn't want to break shit either.
    If it's only the terminal that's corroded, then cut it off and replace it with a new one + 3-5" of new cable of the same gauge so it can reach the battery.
  4. Oct 19, 2023 at 7:41 AM
    tundrabubba
    Andrew
    Do you what size the wire is? and where I can get something like that? Its more than the terminal unfortunately.
  5. Oct 19, 2023 at 7:45 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    It's either 2 or 4 AWG. You could buy something already premade, chop off one end, then use a butt connector to reattach it to the truck.
    Example:
    https://www.amazon.com/Battery-Copper-Inverter-Automotive-Motorcycle/dp/B0BRXVYBSK?crid=3TBAM2U6Q1EK7&keywords=4+awg+battery+cable&qid=1697726605&sprefix=4+awg%2Caps%2C141&sr=8-3-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
    Edit: you will need an appropriate crimper
  6. Oct 19, 2023 at 7:48 AM
    tundrabubba
    Andrew
    Thank you! The terminal itself has the # 608 on it. Is that relevant at all?
  7. Oct 19, 2023 at 7:52 AM
    JRS
    JRS New Member
    2012 DCLB
    Are you having electrical issues? If not, and you're trying to be preemptive, clean it with a brass brush + baking soda/water and then Vaseline it. Connectors can usually be saved for a while. The cable really only needs to be swapped if the corrosion gets in-between the strands and under the jacket.
    baraynavab likes this.
  8. Oct 19, 2023 at 7:57 AM
    tundrabubba
    Andrew
    Yes, I am having electrical issues. I figured if I could swap that out, I should be set.
  9. Oct 19, 2023 at 8:07 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Couldn't find anything on it.
  10. Oct 20, 2023 at 2:16 AM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    Yes I would properly fix not just the 608 cable you're mention but also that ugly + battery cable terminal itself. It doesn't look oem to me.
    The proper way would be to cut of the cable ends a few inches deep (hopefully you don't have corrosion on the length of the cable). Hydraulic crimp that 608 and the positive cable with new likely 2 gauge cables and new positive terminal. And double heat shrink it. With marine gear waterproof HS.
    If you were in Atl. I have all that equipment that would be great to get this work done. Let me know if your close by.
    Heck I would swap out all my grounding cables as well to ensure all my grounds are in great condition as well. I can help you to get those grounding cables replaced. Let me know.
    Shanet421 likes this.
  11. Oct 20, 2023 at 7:31 AM
    coTony
    Tony
    Montrose, CO
    If it is a 2008 and is corroded that bad from what we can see most likely it goes on down the cable. I would replace the entre cable if it were me, cutting the ends and replacing is just a bandaid in replace of a surgery.
    Fuse box is not that difficult, just a lot of work. Remove the battery and work from there
