Camper towing
Discussion in 'Towing & Hauling' started by Geri4x4, Mar 10, 2023.
  1. Mar 10, 2023 at 4:55 PM
    Geri4x4
    Geri4x4 [OP] New Member
    2022 tundra 1794 TRD off road
    Toyota lift
    I have a 2022 tundra 1794 TRD off-road it has the Toyota lift. We are looking at getting a camper. We have looked at a 34 ft 7100 dry weight and a 30 ft 5980 dry weight. With that being said has anyone have any advice? I haven’t had a camper in a few years and this is a new truck.
  2. Mar 10, 2023 at 5:00 PM
    Those are big campers. Lifting your truck doesn’t help with towing at all. Both are likely within your towing limits, but are pushing the upper edge. May not be an easy or pleasant experience to pull them long distances. Maybe others on here with lifted 3rd gens have experience with large TT’s and can advise.
  3. Mar 10, 2023 at 5:02 PM
    Get something 30% smaller than that. 1/2 ton trucks are light duty and better suited to towing 25' or less with no slide outs. Lots of people will haul houses anyway, but it would be a much better experience and less wear if you stuck to something smaller.
    Geri4x4[QUOTED][OP] and t300 like this.
  4. Mar 10, 2023 at 5:09 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Our trailer is 4500 GVW and the Tundra does a great job. You are going to get some sag in the rear with that tongue weight but your's might have the air suspension so it might level things out. We use a weight distribution hitch with sway control and the ride is very solid and stable.
    You need to pay attention to the payload rating for your truck as this will get used up quickly with a bigger trailer which means that you will be over if you have a bunch of stuff in the truck bed and 5 people in the truck. Your payload sticker is on the door jamb. There is some info in the owners manual on how this works and what you need to count when loading the truck.
    Dfrink and Stinky Buffalo like this.
  5. Mar 10, 2023 at 5:27 PM
    This is 28' of trailer.
    So is this:
    My 28' camper made me buy the first pictured truck.
  6. Mar 10, 2023 at 5:33 PM
    This is 33.5’ of camper
    Geri4x4[OP] likes this.
  7. Mar 10, 2023 at 7:01 PM
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    Hwy 71 South of Fort Smith?
  8. Mar 10, 2023 at 7:08 PM
    Marvthehamster
    Marvthehamster New Member
    CO
    2018 CM
    ADS/Deaver, Method's, 35's, RCI sliders
    :popcorn:
  9. Mar 10, 2023 at 8:04 PM
    Not quite that far west. Lowe’s parking lot, Conway Arkansas of I40 en route to Petit Jean
  10. Mar 10, 2023 at 8:49 PM
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    I pull a 29’ that’s 5500# dry and I wouldn’t want to go any larger personally.
    Dfrink likes this.
  11. Mar 10, 2023 at 8:52 PM
    Aces and 8s
    Aces and 8s I Turn Wrenches
    2023 Tundra CM Ltd
    General rule of thumb; just because you can tow 11k+, doesn't mean you should. 70% of advertised tow capacity when fully loaded is a good standard to live by.
  12. Mar 10, 2023 at 9:06 PM
    JohnnieBoy
    JohnnieBoy New Member
    2022 Army DC 4x4
    Icon Stage 3 Method 316's on 275/70/18 Ko2's NYTOP bumper w recovery's Leer 100XR
    I'm more comfortable with 40 - 50%. I tow a small toy hauler with a 5k total gvwr and 425ish tongue weight. Weight distribution/sway hitch is crucial to a smooth tow.20230306_113949.jpg
    Crazycalvin, AircareTundra and t300 like this.
  13. Mar 10, 2023 at 10:48 PM
    cruiserhead
    cruiserhead New Member
    How would the TRD lift that the OP has affect his towing capability?
    ColoradoTJ likes this.
  14. Mar 10, 2023 at 10:56 PM
    A lot of towing capability is geographic. Just because one is under the GTWR doesn't mean it's a good idea. Visa versa some people can tow at GTWR and be totally fine. Someone that tows in Florida only probably can get away with more weight. The same person will struggle in eastern Tennessee. Lord forbid they decide to vacation in the Rocky Mountains.
    Some of the toughest towing I ever did was on relatively flat land but the wind was fighting me the whole way. North Dakota, Wyoming, Utah, and New Mexico have been sporty in the constant and dreadful wind.
    On the flip side, towing at 11K feet of elevation is no beginners ball either.
    It's hard to answer a new members question "can I tow this" without knowing more details.
    Jorts, Crazycalvin, Y0TA PR0 and 2 others like this.
  15. Mar 10, 2023 at 10:57 PM
    Yes
    GODZILLA likes this.
  16. Mar 11, 2023 at 3:48 AM
    Malinois38
    Malinois38 New Member
    Pa.
    2022 Platinum Hybrid WCP
    This is 28’ and 7k loaded for camping with 980lbs of tongue weight. Family of four and an ugly dog. Been all over the U.S., well over 30K towing. Will do the same with my 2022 when the weather breaks.
    g6t9ed, bfury4, Crazycalvin and 2 others like this.
  17. Mar 11, 2023 at 7:06 AM
    For starters, the higher center of gravity doesn’t help with tow vehicle stability. Next up, the TRD lift was designed with off-roading manners in mind, not towing manners. Next up, “leveling” the truck like everyone wants to do for purely esthetic reasons gets rid of the rake, that’s supposed to be there on a load carrying vehicle to allow the weight you load it with to compress the suspension without pointing the vehicles nose in the sky. All the things people complain about on here when towing, the lift makes worse. Not to mention if they lift, they almost always choose taller heavier tires, which also fight you when towing or really just driving around period. They take more power and fuel to move. To sum it all up, the simple laws of physics make the TRD, or any other lift kit, a bad addition to a vehicle that will tow heavy.
  18. Mar 11, 2023 at 7:13 AM
    Crazycalvin and mayan like this.
  19. Mar 11, 2023 at 7:19 AM
    Yeah, a deer ran out in front of me, a pothole ate my home work. What caused that crash is what causes most towing crashes. Speed, setup and experience. No way a pothole causes me to lose control like that driving my TT down the road. I’ve been driving around a corner at 50mph on a highway here and due to road construction, dropped off a 5” ledge. Was pretty violent in the tow rig, could have used a “dip” sign to warn me, but the rig tracked true.
    Mattedfred and 4genRunner like this.
  20. Mar 11, 2023 at 7:29 AM
    I'm thinking it was a rather large pothole. That lane was shut down for repairs. Never say never.....
    Crazycalvin likes this.
  21. Mar 11, 2023 at 7:34 AM
    Must have been a monster. Wasn’t a terribly large tow vehicle or travel trailer. Can’t see if he’s running a WDH or sway control. Trailer is swerving around like the tongue weight was a little light. Couldn’t tell if a tire blew out on that video either. They fail to show the relevant parts of the video leading up to the crash. Probably some “evidence” in there that they don’t want public?
  22. Mar 11, 2023 at 8:39 AM
    Hard to tell if a WDH was in use. The video is just dash cam footage, so probably limited viewpoints.
  23. Mar 11, 2023 at 9:08 AM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    I’ve got a 30’ 7000# camper and have been pulling it all over Pennsylvania with 2020. No problem but probably won’t be going with a lift any time soon. Would like to bump up the tire size at some point to fill in the wheel well a little.16913CEB-E088-45AC-968A-BCE6DD5716FF.jpg
  24. Mar 11, 2023 at 9:40 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    The PA silver tundra, imagine TT gang. 2800BH here!
  25. Mar 11, 2023 at 10:14 AM
    I think everyone was ok. Probably had to clean out some underwear.
    He was in the slow lane, and on that particular stretch of road is pretty rough. I usually stay in the center or fast lane if possible. The reason for posting that was not due to recklessness or anything like that. It was to show things can get out of control very quickly.
    Age may be a factor (more so experience). Out of the 6 deaths I've seen (work related), 4 were 30+ year employees. Complacency got them. Experience is good to have, but not the only benefitting factor.
  26. Mar 11, 2023 at 12:12 PM
    Crap. Forgot to actually answer your question.
    Depends on lift. Most people level, so when weight is added to the rear the headlights are pointed at the sky. Then the bandaid's come out (take your pick...airbags/helper springs/others) and really people lose suspension range/motion. This can lead to control issues.
    When lifting, most people install larger tires without re-gearing. Loss of power and control is common.
    A lift also causes more wind drag/resistance. It's obvious why that isn't great.
  27. Mar 11, 2023 at 12:16 PM
    cruiserhead
    Thanks. Yeah I knew it probably wouldn’t be as good and could cause problems, but needed to think through and understand exactly why.
    I have this lift, but not sure I want to install it. I don’t tow much now, but might in the future so considering what is best.
    Thanks!
  28. Mar 11, 2023 at 12:25 PM
    All generation Tundra trucks can tow and do it well in stock form. Just want to manage expectations when mods are put on any truck.
    cruiserhead[QUOTED] likes this.
  29. Mar 11, 2023 at 12:32 PM
    More information. Damn that's a hole.
    graf_von_tundra likes this.
  30. Mar 11, 2023 at 12:41 PM
    couple of thoughts on that report.
    1. The pothole shown at the end is a complete perforation of a bridge deck! That rebar and patch job they show should not be an acceptable repair.
    2. if one of these types of potholes is what caused them to lose control of their trailer, then they should submit for the city / county / state or whoever maintains that road for the repairs and damages to their vehicle.
    3. Then I would get the ticket for “reckless driving” or whatever thrown out.
    this is assuming the story from the couple is true. Still think a properly setup tow rig traveling at safe speeds should be able to negotiate road hazards such as dips and potholes. Truck looks older, good chance the shocks and what not are worn out.
