Camshaft Position Sensor 1 & 2 ??
Discussion in '1st Gen Tundras (2000-2006)' started by landluke, Aug 29, 2023.
  1. Aug 29, 2023 at 10:11 AM
    landluke
    landluke [OP] New Member
    05 tundra
    Team,
    I have code P1340 camshaft position sensor : Bank 1 Sensor 2. engine starts but hunts/stumbles until dies 3 seconds later. 2 UZ-FE Engine - 2005 V8 4.7L
    My question is : What is difference between Sensor 1 and Sensor 2?
    > Bank 1 is driver side , Done
    > but is sensor 1 the sensor by the timing belt, then sensor 2 is where ??
  2. Aug 29, 2023 at 10:19 AM
    landluke
    05 tundra
  3. Aug 29, 2023 at 10:24 AM
    I want to say someone on here indicated in the past it was one of the bank 2 sensors. Let me see if I can dig on that.
  4. Aug 29, 2023 at 10:25 AM
  5. Aug 30, 2023 at 7:03 AM
    landluke
    05 tundra
    Thanks Shifty.
    So I replaced VVT1 and it didn't fix. I replaced the camshaft sensor in front, and it worked.
    So even though my code showed "sensor 2" that is not the VVT sensor. It is still the camshaft sensor in front.
    shifty` likes this.
  6. Aug 30, 2023 at 7:18 AM
    I had my doubts about it, there's a reason I didn't definitely answer. Thanks for clarifying. T
    Curious, was the camshaft position sensor up front physically damaged in any way? Wires nicked, etc.? I was under the impression Toyota fixed the design in '02-'03 with a new integrated wire retaining clip to prevent damage.
  7. Aug 30, 2023 at 8:44 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Irrespective of what your code reader says, there is only one cam shaft position sensor and it’s located by driver side cam as noted in TSB that came out in 2006 pertaining to the P01340 code. There should be no doubt. The link that was posted above dealt with the OP indeed a VVT sensor problem not cam shaft
    Tom's Tundra likes this.
  8. Aug 30, 2023 at 8:54 AM
    Indeed it did, only linked it because you clearly indicated there was only 1 camshaft position sensor in your reply. Thanks for that.
  9. Aug 30, 2023 at 9:40 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    I understand….it’s a questionable sensor that has come up on numerous occasions since I’ve been here and certain comments have been incorrect….”replace both cam shaft pos sensors”….just one example.
    Any/all timing belt videos linked to in here would show that, along with any of the FSM’s that are being linked to. No harm, No foul….simply an important fact IMMHO
  10. Aug 30, 2023 at 9:43 AM
    Guilty!
    BubbaW[QUOTED] likes this.
  11. Aug 8, 2024 at 12:18 PM
    Tom's Tundra
    Tom's Tundra New Member
    2005 Tundra Sr5 4.7l Double cab
    Hey BubbaW, in the linked info you provided above it mentions the Camshaft Position Sensor Assembly was improved. Would that include the addition of a silver colored band being added to cover the tip of the sensor? Asking due to a replacement I bought at RockAuto having this added feature with a green check mark indicating it fits my vehicle? Thanks, Tom
  12. Aug 9, 2024 at 11:29 AM
    Did you buy an OEM sensor, or aftermarket? It fits, and it’s the original part are 2 different things. This truck’s are picky with electronics and sensors.
  13. Aug 9, 2024 at 4:13 PM
    Tom's Tundra
    Hey Knabores, I appreciate you taking time to reply & assist.
    After getting a no start single click/thud from starter & P0340 / P0345, I sourced the HOLSTEIN CSPS 2CAM0335 (in timing cover) & 2 Dorman 907-866 CSPS's (the top of the valve covers) from Rock Auto due to the price & the lil blue INFO button leading me to believe the OE hype. Another gracious member has posted somewhere that the actual name for these 2 Sensors is VVT.
    Sadly, I read that part about being picky in several 1st Gen threads after I had ordered & installed them. (The $117. Denso sensor assembly (in timing cover) pic shows it also has this thin silver band screwed down over the tip of the Sensor.) Despite the replacement of all three & new battery, I'm still getting the same ol single click/thud from starter & no codes. I'm reading the crap out the EWD's posted by Shifty & others & related threads. I'm starting a Return & getting OEM today, when able can you tell me which ones you'd buy & from where?
    Thanks again.
  14. Aug 9, 2024 at 5:05 PM
    Use an online Toyota parts dealer such as Serra in Birmingham and put in your vin. You can find OEM sensors that way. Sometimes Rockauto will also have the OEM option. But it won’t say Toyota. It will say Denso (electronics) or Aisin.
  15. Aug 9, 2024 at 5:09 PM
    Tom's Tundra
    Thank you very much. Have a good one.
