Can’t take rotor off
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1Tundra5, May 5, 2023.
  1. May 5, 2023 at 2:25 PM
    1Tundra5
    1Tundra5 [OP] New Member
    Junior
    2015 White SR5
    I wasn’t able to take the rotor off.
    Does anyone who is there a part i Can screw into the hole with thread, to make it pop off?
  2. May 5, 2023 at 2:27 PM
    Two words.
    B F H
    Johnmatrix and PKFan like this.
  3. May 5, 2023 at 2:30 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    You can screw in a bolt to pop it off or hit it with a torch or penetrating oil
  4. May 5, 2023 at 2:33 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    A couple of M8x1.25 bolts tightened into those holes will pop it free with minimal effort.
  5. May 5, 2023 at 2:40 PM
    Mr Badwrench
    Mr Badwrench New Member
    If it is your rear rotor.... is your parking brake off?
    1UP, landphil and KNABORES like this.
  6. May 5, 2023 at 3:25 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    This. Even if it is off, there might be a parking brake clip keeping it on.
    Beating on your rear rotor with a BFH wont work if there is.... Ask me how I know :anonymous:.
    My mechanic neighbor still laughs about it.
  7. May 6, 2023 at 5:11 PM
    Joeb33
    Joeb33 New Member
    joe
    2015 Tundra TRD
    There is a rubber plug in the rear rotor. Pop the plug and roll it to 6 o'clock, there is a star wheel in there you need to wind it down to move the emergency brake shoes away from the drum. when it is loose enough the rotor will slip off, or you can pull it off with bolts. If you don't back the shoes off, you'll break the shoe retainer locks.
    tech1208 and JLS in WA like this.
  8. May 6, 2023 at 7:48 PM
    Scorpion006
    Scorpion006 I'm athletic - I’m known to surf the web for hours
    Austin, TX
    2017 White Tundra 1794
    This... take little to no effort when you use it.
