Can I see your 275/70r18 please.
Discussion in 'Wheels & Tires' started by Rngr188, Sep 16, 2017.
  1. Sep 16, 2017 at 1:49 PM
    Rngr188
    Rngr188 [OP] Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    I don't have a lift yet but think I will do some 6112 on the 1.9" setting eventually and leave the rear alone (maybe do 5100 or 5160 back there but no lift). I want to go ahead and get some Ridge Grapplers mounted to my stock TRD OR wheels in 275/70R18 before I do my front lift. Anybody have pictures of that tire size on stock rims, lift or no lift just pics of that tire size. Will I have rubbing at stock height and when I do pick the front up will the tire size still look good or too small? Thanks.
  2. Sep 16, 2017 at 1:51 PM
    ToyotaTundraMike
    2015 Tundra
    No rubbing on stock height and still looks good with a little front lift like you are describing. Check my build thread for pics of that tire size, links in sig.
    MDHinSD likes this.
  3. Sep 16, 2017 at 3:29 PM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    IMG_20161228_211520_457.jpg IMG_2186.jpg I've done some mods since these pics were taken but this is with a 2.5in sus lift in the font and 1.5 block in the rear. All other components were stock. These were 275/70r18
  4. Sep 16, 2017 at 3:30 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    I've had the luxury of being good buds with a tire guy and he threw on 295's which were the biggest at full crank with my 2.5in and no other mods. Hope this helps.
    Big J and (deleted member) like this.
  5. Sep 16, 2017 at 3:32 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Before you ask, it may seem higher because of the front clearance but that bumper was modded for that. But they fit nicely
    GNTundra likes this.
  6. Sep 16, 2017 at 3:41 PM
    Rngr188
    Chad
    Harrison AR
    Will the 275/70 be fine if i put them on before I lift the front?
  7. Sep 16, 2017 at 3:57 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    I don't want to say yes and be wrong but I'm about 99 percent sure. They're just a 33 variant
  8. Sep 16, 2017 at 4:03 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Screenshot_20170916-160221.jpg Screenshot_20170916-160105.jpg you'll be just fine.
  9. Sep 16, 2017 at 4:07 PM
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
    You'll be fine. That's what I'm running with stock suspension. Initially I didn't think I had any rubbing but after a few weeks I noticed I slightly rubbed my front skid plate. I rolled the sides in about a 1/2" and that took care of it.
  10. Sep 17, 2017 at 3:37 AM
    PermaFrostTRD
    Northern NY
    No rubbing for me!
  11. Sep 17, 2017 at 2:25 PM
    Rngr188
    Chad
    Harrison AR
    Factory ride height?
  12. Sep 17, 2017 at 3:40 PM
    be77solo
    be77solo New Member
    2017 Silver Crewmax 4x4 5.7L
    KO2's on ENKEI ST6's, BakFlip MX4
    Here are 275/70r18's on mine. Stock suspension, no lift. No rubbing, you should be fine. Should still look fine with a small lift like you mention down the road. Plus, you won't have quite the performance hit on acceleration and gas mileage a bigger tire would have.
  13. Sep 17, 2017 at 5:38 PM
    PermaFrostTRD
    Northern NY
    Yes
  14. Sep 17, 2017 at 5:51 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    275/70r18 bfg ko2
    I had them on stock height with 0 issues.
    Currently have 6112s on 3rd setting and 1.5 inch lift shackles on the back.
  15. Sep 24, 2017 at 11:36 AM
    HOTDAM
    HOTDAM Feeling Dangerous
    2013 Crewmax 4x4
    Toyo Open Country AT2
    Black rhino wheels Warlords +12
    The Dude, Airn890, tumaro and 4 others like this.
  16. Sep 24, 2017 at 12:25 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    You'll be just fine. I have a 3/1 and 275's. They look way too small but would look perfect with stock suspension to a 2.5 lift!
  17. Sep 24, 2017 at 3:33 PM
    Borgs
    Borgs New Member
    PA
    Any performance/acceleration decline and mpg decline with 275/70r18 bfg ko2 on stock wheels and height?
  18. Sep 24, 2017 at 4:01 PM
    PermaFrostTRD
    Northern NY
    Very slight. But noticeable. Lotta extra rubber. But worth it.
    JuanTon21 and GODZILLA like this.
  19. Sep 24, 2017 at 7:42 PM
    Muleycrazy13
    Muleycrazy13 New Member
    Buckeye, AZ
    2024 Chevy Silverado 2500HD Duramax
    Not the best pic but you get the idea
    Isntthatdandy, D4x4TRD, Big J and 2 others like this.
  20. Sep 29, 2017 at 4:58 AM
    Borgs
    Borgs New Member
    PA
    This may be a dumb question but I don't know anything so dumbness is relative: is it necessary to recalibrate the speedometer and or adjust shift points with a move to even a slightly larger than stock tire such as 275/70/18? It seems to me even a modest size increase will throw off your odometer after awhile since the circumference of the tire is larger than stock.
    Also, any long-term transmission issues to worry about with jumping up in size from stock? The Toyota engineers put 275/65/18 stock on for a reason - I trust them and assume they did that for a reason.
  21. Sep 30, 2017 at 8:44 AM
    Muleycrazy13
    Buckeye, AZ
    I'm sure they did do that for a reason prob more so for mpg. If your not comfortable with it don't change them. I have 275s now and I don't have any issues it is a slight bit thirsty but it's not bad at all.
    MDHinSD and PermaFrostTRD like this.
  22. Sep 30, 2017 at 9:58 AM
    Beaverscott1
    Beaverscott1 New Member
    Scott
    Renton Highlands
    2017 tundra trd pro
    275 70 r18 on my pro. I love ‘em!D81AE220-9938-4E39-9BAF-6A19020E2AE8.jpgC86D0EFB-5A38-45F0-A2F3-D7B7B04B0EC5.jpg69AE0479-E7FE-42C5-B9D4-C877968E16CF.jpg
  23. Nov 3, 2017 at 6:44 PM
    MarkM0369
    MarkM0369 New Member
    Mark
    2017 Tundra SR5 4x4
    275/70 KO2, Pro Hood Bulge and grille, OEM fender flares, Fox rear shocks
    I run 275/70-18 KO2s,and I don’t think the 4% makes too much difference as far as the speedometer goes, 60 on the dial is 60-61 on the gps, with the tread on KO2s I would imagine they are like new OEM tires when they are about 1/2 worn, My truck came with 255/70-18, but didn’t stay on long enough to wear the molding marks off,so can’t say for sure the speedo was perfect from factory.
    On my other truck, I did see a noticeable mileage hit, compared to street tires of the same size, but that’s what the 38 gal tank is for. They do improve handling a bit compared to the stock (Bridgestone Duelers),
  24. Nov 3, 2017 at 7:00 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    Nitro ridge grapplers on fuel octane +20 wheels9B98029C-16BA-4F95-B100-D8DFDC2F95CC.jpg
  25. Nov 3, 2017 at 9:20 PM
    ToyotaTundraMike
    2015 Tundra
    More pics of that tire size with minimal lift in my build thread
    SouthBoundSteve likes this.
  26. Nov 9, 2017 at 6:00 AM
    airgunner
    airgunner New Member
    N-KY
    2015 DC MGM TRD
    That's almost the exact setup I'm looking at right now. Did you pull the front mud flap? If so, did you have to because of rubbing? Do you happen to have a shot from the front or rear to see how much they stick out of the wheels wells if at all?
    Thanks
  27. Nov 9, 2017 at 6:26 AM
    Vendeta2k
    Jay
    Bozeman, Montana
    Front mud flap is still there....I’ll get a side shot in a bit when I go to work...think they stick out a bit but not bad...
  28. Nov 9, 2017 at 6:53 AM
    Vendeta2k
    Jay
    Bozeman, Montana
  29. Nov 9, 2017 at 6:59 AM
    airgunner
    N-KY
    2015 DC MGM TRD
    That's perfect. Exactly what I'm looking for. Thanks for the pics :thumbsup:
    How are you liking the Ridge Grapplers so far? How are they in the snow and rain? Notice much difference in ride quality or gas mileage?
    BTW - I love that color. I'm pretty happen with the MGM on mine but given the choice, I would have gotten Cement too! :cheers:
  30. Nov 9, 2017 at 7:48 AM
    Vendeta2k
    Jay
    Bozeman, Montana
    The ridge grapplers are great so far....quiet....no howl on the highway....tracks and drives straight.....wet tractions and snow seems good so far. I only noticed a very small drop in mpg going from the factory tire to these...although I did only go from a 275/65 to a 275/70....so not as big a jump as most others that have plus sized wheels.
    Sunnier likes this.
