Can someone explain compressors?
Discussion in '3rd Gen Tundras (2022+)' started by JerseyGeorge, Sep 5, 2024.
  1. Sep 5, 2024 at 1:53 PM
    JerseyGeorge
    JerseyGeorge [OP] New Member
    2024 Platinum
    OK. I do know what a compressor is. I am just wondering if folks are mounting compressors on their Tundra only for air suspension, or is it a general purpose compressor that can fill a bike, trailer, vehicle tire also.
  2. Sep 5, 2024 at 1:56 PM
    6rian
    6rian New Member
    Airing up tires after deflating them for off roading.
    JerseyGeorge[OP] and Fobroader like this.
  3. Sep 5, 2024 at 1:56 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Both. Off-roaders learned a long time ago that by airing down their tires, they are less likely to get stuck in mud and sand. Do so; however, requires you to reinflate before hitting the road again.
    JerseyGeorge[OP] likes this.
  4. Sep 5, 2024 at 2:05 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Air lockers and train horns too.
    Black Wolf, reywcms, Yaboy and 2 others like this.
  5. Sep 5, 2024 at 2:24 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Impromptu air supply for a Senco roofing nailer because SOMEONE forgot to bring their padlock key to gain access to the jobsite’s Greeenlee lock box that the air compressor was in. I propped open the hood on my CJ7 and plugged in a 100’ long air hose into the compressor. The CFM was a bit low, but it did the trick for the next 6 hours while i was two stories up on an 8/12 pitch roof.
  6. Sep 6, 2024 at 6:24 AM
    steveh
    steveh New Member
    '24 Tundra Limited
    Nothing Yet!
    I just keep one in a box with my camping/or stuff, mostly for the air bags and reinflating low tires after off-roading.
  7. Sep 6, 2024 at 6:38 AM
    GilFavor
    GilFavor New Member
    2023 silver tundra 1794
    These are pretty handy
  8. Sep 7, 2024 at 7:35 AM
    TrimTab
    TrimTab Old man with a beard
    Trim
    do feel this the best portable air compressor available on the market ? i am looking for something to assist me from lugging around my 6 gal 150psi pancake electric porter gable air compressor , when we go on long trips.
  9. Sep 7, 2024 at 7:43 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    All the things mentioned above but I’ve also used mine to air up our paddle boards
    TrimTab and KNABORES like this.
  10. Sep 7, 2024 at 7:45 AM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    Fantastic unit - it dips down to $145 on Amascam on occasion.
    TrimTab[QUOTED] likes this.
  11. Sep 7, 2024 at 7:50 AM
    GilFavor
    GilFavor New Member
    It uses the batteries I already have but I’m sure all the good brands like dewalt etc. are just as good. Way more convenient than a corded compressor. Not sure if it’s as strong as your 6 gal pancake but for tires it does the job.
  12. Sep 7, 2024 at 7:57 AM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    There are two types of compressors generally. Tires and Lockers - High pressure low volume because a tire isn't that big.
    Low Pressure High Volume - I had a hand pump and could pump up my 18' inflatable jet boat in less than 30 min.
    Good for paddle boards and air beds too.
    I'm sure portable like the Milwaukee will do both depending on how much time you have and how many batteries you carry.
    Also some require a lot more AMPS to run than you might think, and get hot. So spec it out before you buy.
  13. Sep 7, 2024 at 8:41 AM
    bfunke
    South Carolina
    Inflatable jet boat? Pic please…
    Black Wolf and Tundrastruck91 like this.
  14. Sep 7, 2024 at 10:14 AM
    TrimTab
    Trim
    thankyou all for some guidance , appreciate all of you here in this little forum community, a little more details on my journey,, well i have looked into the clore automotive JNCAIR 1700 Peak Amp 12V Jump Starter w/ Air System , however it to is almost the same lugging weight , as my pancake air probably close to 40lbs , not a problem, but am aging , most of the time i just wanna reach into the bed of my tundra while standing on the ground. an when im on the side of truck it gets a tad difficult. ain’t 30 yrs old no more. , however the clore seems overkill , as i already have a noco portable lithium jump starter. Cruiser pilot i already have a hand/foot pump but got to save my back bro. something more portable would definitely be beneficial especially if it can handle truck / trailer tires.
  15. Sep 8, 2024 at 7:27 AM
    AND
    AND New Member
    Washington, PNW
    The title of this thread made me think of this video. :rofl::rofl::rofl:
    Rodtheviking and Cruiserpilot like this.
  16. Sep 8, 2024 at 9:54 AM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Priceless!!! :thumbsup:
  17. Sep 8, 2024 at 10:29 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Sigmoid rumbling below the beltline, hate that.
    I have Viair 300p that I keep with me at all times.
    Malinois38 likes this.
  18. Sep 8, 2024 at 6:06 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I have a WARN 9500 Compressor Winch. It’s attached to the winch motor. It is really efficient. I don’t know why no one liked them and hence WARN quit making them. I also have a ARB compressor but it’s the small one only for lockers. ARB makes expensive but pretty efficient larger models that I’d endorse.
  19. Sep 8, 2024 at 7:48 PM
    Hella Krusty
    Hella Krusty New Member
    I remember when my knees could do that !
    MS22 likes this.
  20. Sep 8, 2024 at 9:00 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    lol I was hurtin after this don’t let the pic fool you
    Hella Krusty[QUOTED] likes this.
  21. Sep 9, 2024 at 5:00 AM
    Rockpig
    Rockpig You did what?
    08 Limited
    I'm in the middle of installing a dual compressor system in my 24. Ran one in my 08 and used it for everything, tires, trailer, kids floaties, lockers, etc. Using dual Viair compressors and a 3 gallon air tank. Plan on putting a quick disconnect air chuck fitting in the bed of the truck for easy access. I'll post up in a few days on the final results.
    TrimTab[QUOTED] and Cruiserpilot like this.
  22. Sep 9, 2024 at 6:04 PM
    Crawldad
    Crawldad New Member
    2024 Tundra Limited TRD OR w/3” Lift
    I also had the ARB dual compressor mounted under the hood of my 2016 Tacoma. That was a great setup, I should have removed it before I traded it in. For my F250 Tremor I bought the MOORFlate TenSix compressor with the quad plus hose kit which I will use for the Tundra. It works great to fill and air down all 4 tires at once.
    https://morrflate.com/shop/air-sources/portable-compressors/morrflate-tensix-12v-compressor/
    https://morrflate.com/shop/morrflate-multi-tire-air-kits/morrflate-quad-plus-4-tire-air-kit/
    TrimTab likes this.
  23. Sep 9, 2024 at 7:20 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    That's a pretty impressive unit. Never heard of it before.
  24. Sep 10, 2024 at 4:28 AM
    TrimTab
    Trim
    also never heard of them looks good and durable thankyou
  25. Sep 10, 2024 at 5:57 AM
    JayDee
    JayDee New Member
    I keep one of these DeWalt inflators in my truck's tool box. Will run from either a 20V battery or from 12V via an extension cord. It has two different modes for inflatables with high volume and low PSI or for tires with higher PSI. It will automatically stop at the selected PSI
    I liked it so much that I bought another one for my sailboat which is great for inflating fenders and the dinghy.
    TrimTab, Tundrastruck91 and KH1414 like this.
