Can you jackknife a Tundra going forward?
Discussion in 'Towing & Hauling' started by Retired...finally, Sep 26, 2023.
  1. Sep 26, 2023 at 4:20 AM
    Retired...finally
    Retired...finally [OP] Utilizing that doctorate of procrastinatory arts
    I got very close after making a left 180 in a test. I will say the unistrut is coming off while I travel. I did have a bike mounted there but now it's the base to hold my fishing rods.
    whodatschrome and Mattedfred like this.
  2. Sep 26, 2023 at 4:49 AM
    Appears you can get really close! How tou liking the vintage? We are looking at those.
  3. Sep 26, 2023 at 4:58 AM
    Retired...finally
    It's OK. A lot of Covid era assembly mistakes but after fixing those we've been very happy with it. Afterall we live in it for 7 months out of the year. Curb weight on ours is 4,178 including propane and battery with a gross of 6,080 and we never get close to that. The Tundra does great. Last fill up between Charleston WV to Salisbury NC was 12.33 MPG calculated
  4. Sep 26, 2023 at 7:01 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    They spelled Cruzer wrong :p
  5. Sep 26, 2023 at 7:10 AM
    SD Surfer
    Bruce
    So Cal
    Wow, I would not have thought so, but you gave it a helluva try!
    Maybe you need a different set-up. :rolleyes:
  6. Sep 26, 2023 at 8:32 AM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    I have come REALLY close with mine, as I live on a fairly tight cul-de-sac and it is a very, very tight turn to get it turned around so I can back it in to the parking pad.
  7. Sep 26, 2023 at 9:23 AM
    EmergencyMaximum
    EmergencyMaximum New Member
    It will mostly be dependent on truck length and construction of the trailer front end. On mine, I can keep trying, but she will never reach close enough because of v-nose trailer and dclb pickup.
  8. Sep 26, 2023 at 11:23 AM
    SD Surfer
    Bruce
    So Cal
    I generally try to avoid SUPER tight turns and maneuvering (on pavement) whenever possible to mitigate the forces exerted on tire sidewalls due to tire scrubbing of a dual axle trailer.
    Not always avoidable, and if I gotta' flip a bitch I'll do it, but it is something I keep in mind. Sometimes I'll go around the block to avoid a U-turn.
  9. Sep 26, 2023 at 11:27 AM
    Retired...finally
    I removed the unistrut and will try again when I find another gravel spot. I'll have my wife outside as a spotter.
  10. Sep 27, 2023 at 9:08 AM
    shoe07
    shoe07 New Member
    Ohio
    2004 Tundra Double-cab SR5 Tow pkg
    I think it depends on what you're towing. My previous trailer I could turn full lock and not worry about it. The unit I have now I can get very close to touching. Have not tested, but am more cognizant of the problem, based on what I was seeing in the mirror, I believe it could touch.
    My sister took out her F-150's tail light pulling out of the driveway with their trailer. My uncle got his tahoe's tail light maneuvering in a campground. Not sure if he was backing up or going forward though.
  11. Sep 27, 2023 at 9:59 AM
    EmergencyMaximum
    Adding a pillow to bumper corners usually helps. Cushions the squeeze.
    whodatschrome likes this.
  12. Sep 27, 2023 at 12:51 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
  13. Oct 15, 2023 at 7:30 PM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (current)
    I need to experiment with mine. The answer to the question is going to varey widely with the length of the tongue, any obstacles on the tongue and the distance from the coupler to the trailer axles (trailer's "turn radius")
    It's possible to design a trailer that cannot be jackknifed moving forward, it's also possible to design one (poorly) that could easily do damage on a standard 90° turn at an intersection.
  14. Oct 16, 2023 at 8:11 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    The turning radius of the Gen 3 is so bad that it would be near impossible to get that sharp of a turn :)
    Did you start this turn by hooking up at a sharp angle?
  15. Oct 16, 2023 at 10:09 AM
    Retired...finally
    If you referring to the OP, No. The camper was connected pretty much straight. We had left our site and on the way out dropped off trash. There was a wide area allowing me to make a 180 and while making the turn I watched the interface in the backup camera. These anytime backup camera mods are handy.
  16. Oct 16, 2023 at 10:27 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I can see that happening if you are able to go around in a 180. Do you have one of those wireless backup cameras on the rear of the trailer? I think a longer hitch head might give you more clearance in this situation but that changes the way the trailer load is applied to the truck. Mine has a longer head by about 12". I would hate to bump into the trailer or take out a tail light or knock the propane tanks off!
    I have already hit my trailer with my kayaks putting a crease in the aluminum skin. :(
  17. Oct 16, 2023 at 1:15 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I wish mine turned like that. I would be planning my 24 point turn if I was heading into a cul-de-sac ;) It does take many tries to park it as well. For work, we have to take it downtown and we find that squeezing it into spots is an adventure. Could it be the added length of 6'-6" bed that creates all this fun?
    Mattedfred likes this.
