Can you share a link on removing the glovebox? Also, quick driver side plastic panel question…
Discussion in '2.5 Gen Tundras (2014-2021)' started by phatjoe, Mar 28, 2019.
  1. Mar 28, 2019 at 7:21 AM
    phatjoe
    phatjoe [OP] New Member
    2019 TRD Pro Voodoo Blue
    Hi,
    I’ll be installing the FRAC harness on my 2019 Tundra this weekend. I’ll feed the wires through the passenger side. Can someone share a link on how to remove the glovebox?
    I’ve come across plenty of videos showing the center console and stereo removal, but I haven’t seen a video (or step by step) regarding the glovebox.
    Regarding the plastic panel near the driver side (pic below), does it just pull off? Better to ask than to break it. :)
    Thanks
  2. Mar 28, 2019 at 7:23 AM
    For the pic you just posted, there is a bolt below that and one on opposite side, that whole piece comes off
  3. Mar 28, 2019 at 7:38 AM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    SpeshulED and porkitt like this.
  4. Mar 28, 2019 at 8:53 AM
    Scotty Dive
    Scotty Dive New Member
    Connecticut
    For that panel under the column, be careful because mine got scratched to hell on the lower right corner against the center console
  5. Mar 28, 2019 at 9:03 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    Yes, this piece just pops right off w/just a little prying. As mentioned, just be gentle so as to not scratch the panels. I used the plastic pry tools you can get at any Harbor Freight store.
  6. Apr 1, 2019 at 6:45 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    @phatjoe, how did the installation go?
