Cant get lower control arm back up to bolt on to Ball joint
Discussion in '2nd Gen Tundras (2007-2013)' started by Hotdog, Jun 18, 2021.
  1. Jun 18, 2021 at 10:38 AM
    Hotdog
    Hotdog [OP] New Member
    2010 Tundra Dbl cab
    Hey everyone, I'm stuck. I'm putting on my lift and I'm at the step of jacking up the control arm back to bolt onto the ball joint assembly. I have removed the sway bar out of the way and now I can only get it up about 2 inches shy to bolt before it just starts lifting the truck instead. What can I do? Thanks!
  2. Jun 18, 2021 at 11:20 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Loosen the lca cam bolt.
    Hotdog[OP] and blackoutt like this.
  3. Jun 18, 2021 at 11:54 AM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    ^^^ that, and if that doesn't relieve enough binding then loosen the upper control arm bolt as well to allow the knuckle to drop down onto the LCA ball joint bracket.
    Silverghost and Hotdog[OP] like this.
  4. Jun 18, 2021 at 12:01 PM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
  5. Jun 18, 2021 at 1:49 PM
    Hotdog
    2010 Tundra Dbl cab
    Ah I see how that could work thanks! I didn't even think about pulling the upper down
  6. Jun 18, 2021 at 2:42 PM
    Aught16TSS
    Aught16TSS New Member
    J
    Tuckasee
    2016 TSS - Magnetic Gray Metallic
    Dual Flowmasters, hidden LEDs in hood bulge, 3.5" lift and Ridge Graps
    I ran into something similar and had about a two hour headache before I realized the axle shaft had pulled out of the differential about 1/4”. Wiggled the axle shaft back and forth until the splines realigned and the control arms literally fell into place.
  7. Jun 18, 2021 at 3:53 PM
    Hotdog
    2010 Tundra Dbl cab
    I will check that out thanks!
  8. Jun 18, 2021 at 3:57 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    I had a similar problem, but I put the strut perch on upside down. One side went together just fine and then I was saved by this forum after wondering wtf was happening with the other.
    Hotdog[OP] likes this.
  9. Jun 18, 2021 at 5:50 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    The ratchet strap trick worked for me…make sure your CV joint hasn’t pulled out either. Another member here had that problem.
  10. Jun 18, 2021 at 6:27 PM
    Hotdog
    2010 Tundra Dbl cab
    Thanks! You all have been very helpful. First thing tomorrow I'm going to give these ideas a go. My confidence level is already increased 10 fold!
    HLR_NM and Silverghost like this.
  11. Jun 19, 2021 at 1:27 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    I did this when I resprung my front end. At least I only did it once!
  12. Jun 19, 2021 at 2:16 PM
    Dalandshark
    Northwest
    Eibach Level LIft
    Glad to know I’m not the only one! I wonder how @Hotdog is doing?
  13. Jun 19, 2021 at 3:52 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    The Westcott lift instructions have you use a pry bar to pull down the UCA leveraging against one of the coils of the spring. Worked like a charm last weekend to get things lined up for me
  14. Jun 20, 2021 at 7:51 AM
    Hotdog
    2010 Tundra Dbl cab
    Success! Well, mostly. Using the ratchet strap to pull the upper control arm down I was able to line everything up and bolt back together. Only catch is I think I may have stripped out a couple bolt holes for my sway bar brackets when putting the sway bar spacers in. They looked like they where straight while laying upside down o_O. Not too big of a deal to correct that though. But the worst part is done thanks for the tips!
    HLR_NM, RainMan_PNW and Danny3737 like this.
  15. May 20, 2024 at 8:36 PM
    ThiRdChoice
    ThiRdChoice New Member
    Tommy
    I’m having the same problem! Going to try the strap tomorrow and hopefully it works!!!
