Can't get oil filter cap off
Discussion in '2.5 Gen Tundras (2014-2021)' started by NeilAgg, Jun 6, 2020.
  1. Jun 6, 2020 at 9:49 AM
    NeilAgg
    NeilAgg [OP] New Member
    Neil
    2017 Silver Tundra SR5 4wd
    I have been trying and trying with an oil filter tool to get the filter cap off. I now have bloody knuckles and it is not budging.
    Does anyone have any tips on doing this?
  2. Jun 6, 2020 at 10:02 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Got picture of oil filter tool?
  3. Jun 6, 2020 at 10:02 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    Lots of discussion on here - you absolutely need the right tool. Don't even try it without it. Something like this....
    https://www.amazon.com/Motivx-Tools-Toyota-Filter-Engines/dp/B00XTAGHU0
    TheBeast and JohnLakeman like this.
  4. Jun 6, 2020 at 10:14 AM
    JohnLakeman
    Agree^^^. That Motivx tool made for 3/8" drive. Use a drive adapter (3/8" to 1/2"), and then a 1/2" drive breaker-bar handle. If that's not enough, then add 1" pipe to extend the breaker bar handle until the filter cap does move. If you break the Motivx tool in the process, be sure to report back with your results.
  5. Jun 6, 2020 at 10:19 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I find it easier to use a 27mm socket on the oil filter tool.
    Leo's first and JohnLakeman like this.
  6. Jun 6, 2020 at 10:30 AM
    NeilAgg
    Neil
    I have the 27 mm socket tool. It also has a 3/8 inch square hole. I put PB Blaster on the thread and used a breaker bar. That solved it. Wow, I can't believe how much force that took!
    Thank you all for your help!
    Pinay and JohnLakeman like this.
  7. Jun 6, 2020 at 10:31 AM
    JohnLakeman
    That is the best answer if you already own a 27mm socket. The biggest socket in my set is 24mm. If the OP has to spring for a drive adapter, he should just buy the 27mm socket as you recommend.
    NewImprovedRon likes this.
  8. Jun 6, 2020 at 10:32 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Don’t put it back on that tight, it’s just a oring that seals it
    Leo's first, MatthewPTguy and Hoff like this.
  9. Jun 6, 2020 at 11:31 AM
    Johnders2586
    Johnders2586 New Member
    2017 Tundra SR5 W/TRD pkg
    Toytec Performance Aluma 3" Lift- Toytec rear shackle, Fuel Vector Wheels, Toyo Open Country C/T 295/70/18 Tires
  10. Jun 6, 2020 at 11:44 AM
    TheBeast The Beach
    get the MOTIV kit and the aluminium housing
  11. Jun 6, 2020 at 11:51 AM
    TransNone13
    TransNone13 New Member
    Oophf! The torque specs are pretty low, they definately torqued that sucker.
  12. Jun 6, 2020 at 12:19 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Yep, and don't buy a tool like that
    JohnLakeman likes this.
  13. Jun 6, 2020 at 12:22 PM
    TransNone13
    Which tool do you use? Is there a CNC one? I have the motivx one.
  14. Jun 6, 2020 at 1:08 PM
    JohnLakeman
    The broken tool in the pic is not a Motivx tool. Panic after the Motivx tool breaks.
  15. Jun 6, 2020 at 1:13 PM
    JohnLakeman
    Torque spec on the filter housing is 18 ft-lbf. I noticed the next time I changed the oil that the filter housing seemed tighter than I left it. Engine operation heat and vibration may have some effect on the tightness, but enough to break a cheap tool.
  16. Jun 6, 2020 at 2:51 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I have one I bought at auto parts store. That was after buying a cast one which I broke. After dealership change I used a 2' bar on my 1/2" rachet with neighbor holding my legs. I know what 130 ft lbs feels like and I am sure that is what it was.
  17. Jun 6, 2020 at 3:24 PM
    TransNone13
    Yeah I'm concerned about it. I'm doing my own at 5000 miles and swapping the housing from the plastic one.
  18. Jun 7, 2020 at 7:57 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    I have not had any trouble with the plastic housing. I have the Motivx tool and it fits very well - there are three lugs on the top of the housing on one side and you need to get those into the fingers on the tool to get a good grip on the housing. If you don't have the tool securely on the housing, with all the fingers engaged, I could see how it might break. I do torque it to spec every time I put it back on and still have to use a breaker bar to remove it.
