Can't unlock truck with key fob?!?!?!?
Discussion in '3rd Gen Tundras (2022+)' started by David713, Jun 19, 2023.
  1. Jun 19, 2023 at 5:12 AM
    David713
    David713 [OP] New Member
    2023 Tundra Platinum
    King shocks, TRD UCAs, Hellwig rear bar, 295/60-20 tires on 20x9 Sparcos
    This morning I couldn't unlock my 2023 Platinum by touching the door handle or buy clicking the key fob button. I unlocked it with the key then the alarm horn went off so I relocked. The truck was new in November so I can't imagine the fob battery is dead so soon. Any ideas?
    I'd have tried the second key fob but of course I don't have one!
  2. Jun 19, 2023 at 5:29 AM
    Breathing Borla
    Northern Illinois
    Replace battery and try again, rather than ruling that out first
  3. Jun 19, 2023 at 5:40 AM
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    2023 Celestial Tundra CM TRD OR
    I bet it's your fob battery. I got my truck in November and my fob battery is already weak.
  4. Jun 19, 2023 at 5:55 AM
    David713
  5. Jun 19, 2023 at 6:47 AM
    violetkibbles22
    violetkibbles22 New Member
    2022 tundra
    This happens to me when ever I use the app to unlock then lock the truck. The key fob won’t work until I lock the truck again with the key fob
  6. Jun 19, 2023 at 8:58 AM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    I did a reset one day by mistake on the big display and left the wife in the truck with the fob. When I came out of the store the display read "place fob over start button" once I did that the truck started. Guess it wanting to set that fob to my settings?
  7. Jun 19, 2023 at 9:00 AM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    Try opening the fob, pulling battery and putting it back in. Worked for mine after getting low battery in key fob warnings.
    I checked the battery voltage with a meter and it was fine.
    Bad contact/oxidation is my guess. Been fine for months now.
    ChiefG likes this.
  8. Jun 19, 2023 at 3:28 PM
    David713
    It was the battery. That’s pretty sad it only lasted 8 months. My other car’s fobs last 5 years or more
  9. Jun 19, 2023 at 3:31 PM
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    My wife's 6 months old WRX had fob batteries fail in 4-5 months. I think the fobs try to communicate with the vehicle too much when they are within range parked in the garage. Subarus manual has a section about putting the fob in sleep mode to conserve battery. Technology....
    ChiefG, ToyoMon and NewImprovedRon like this.
  10. Jun 19, 2023 at 3:58 PM
    David713
    ^good point, the truck key sits just across a window from the truck. I’ll start keeping the key farther away.
    DMackler and NewImprovedRon like this.
  11. Jun 19, 2023 at 7:59 PM
    Brums
    Brums New Member
    Bethel, OH
    22 Tundra DC TRD Sport
    you can turn the fob off, press and hold lock, then hit unlock x2, will turn the fob off, turn it back on simply hit unlock
    Piney, Mattedfred and ToyoMon like this.
  12. Jun 19, 2023 at 8:47 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    I can’t remember if it was the truck or the app, but was telling me the battery was low. Since it didn’t last long I bought a 2 pack with a spare in the truck. Will be going through them at a good rate.
  13. Jun 19, 2023 at 9:50 PM
    ToyoMon
    ToyoMon New Member
    2022 White Tundra SR5
    Mine died also within a year. I'll try the tips posted in here, thanks!
    Another tip is that when the fob died, I couldn't start my truck because it didn't recognize a key fob was near...after the alarm was sounding for 15 minutes and a phone call later, I learned that you need to use the key fob to push the start button and it will start as normal ‍
  14. Mar 2, 2024 at 9:33 AM
    ChiefG
    ChiefG Limited 4X4 TRD OR
    Burlington Township, NJ
    2022 Tundra Limited Off Road 4X4
    Just minor stuff. For example, Undercover bed cover, Tufskinz custom door sill protectors, and TRD air filters.
    On my 2020 Avalon and 2022 Tundra you can turn the key fobs off. Push the lock button, and while holding it down, push the unlock button twice, then release lock button. The red light will blink several times letting you know it’s off. You can check it by trying to open the door. It shouldn’t open. Pushing a key fob button will reactivate it. IMO, the batteries are cheap China made crap and don’t last long either.
    pwpblue likes this.
