Cap/Topper Options for 8' Bed
Discussion in 'Tonneau Covers, Caps and Shells' started by irhunter, Aug 7, 2024.
  1. Aug 7, 2024 at 7:50 AM
    irhunter
    irhunter [OP] New Member
    '03 Tundra V8, AT, 4x4, extra cab
    Anyone using a topper which was intended for some truck other than the Tundra?
    I am looking for one which fits "pretty good." Around here, used 8' Tundra caps are rare.
    Thanks for looking
  2. Aug 7, 2024 at 5:45 PM
    mrmahi
    mrmahi New Member
    2014 Tundra
    Mine was originally for a 6.5' bed on an older Dodge, so it can be done. I asked several folks selling old shells for the dimensions and found one with the correct dimensions. I did have to modify the back window, just had to cut off an inch or so. I used double bulb seals all the way around (except on the front) and it does not leak. Tons of different types of seals on Amazon. Here is the link to my build, shows the whole process (warning: LONG)
    https://www.tundras.com/threads/red-tundra-camper-build.140610/
    irhunter[OP] and koditten like this.
  3. Aug 7, 2024 at 5:51 PM
    koditten
    Kirk
    Midland of the Mitten
    I run Soft Toppers on both my Tundras. My 1st ST was purchased for my 2008 from Soft Topper .com.
    My second ST in my 2021 originally came off a Ford. It fits the same as the one I purchased specifically for a tundra.
    I like my soft toppers. It dies the same job as when I had rigid caps.
    I realize they aren't for everyone, but I sure do get a lot of compliments from strangers.
    If you are hunting for an 8' bed cap, the soft toppers are even more cheap used. Not a lot of peeps running 8' beds these days, so when they go to sell, not as many buyers.
    irhunter[OP] likes this.
  4. Aug 8, 2024 at 7:14 AM
    irhunter
    Great looking truck, and that's some nice build.
    Good to know the Dodge is similar dim's.
    Roy
  5. Aug 8, 2024 at 9:19 AM
    mrmahi
    mrmahi New Member
    2014 Tundra
    Thanks Roy,
    Still have to finish shell lift... been doing other things, but plan to get back to it in a month or so.
