Cargo/3rd. Brake light bulb?
Discussion in '2nd Gen Tundras (2007-2013)' started by Ronmat4X2, Jun 28, 2018.
  1. Jun 28, 2018 at 12:01 PM
    Ronmat4X2
    Ronmat4X2 [OP] New Member
    2007 4X2 TRD
    Are the cargo and 3 brake light bulbs exactly the same?
    Thanks
  2. Jun 28, 2018 at 12:12 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    I believe they are the same bulb just different color. I’m sure someone here will know the answer though...
    If they need replacing, I’d look at replacing them with LED over OEM style bulbs. Cheap and way better. Check out Headlight Revolution or VLEDs.
  3. Jun 28, 2018 at 12:16 PM
    TheBeast The Beach
    I replaced mine with some LEDs from vled. much much better. Very bright.
  4. Jun 28, 2018 at 12:17 PM
    Ronmat4X2
    2007 4X2 TRD
    Are they all white bulbs
    HecticEnergy likes this.
  5. Jun 28, 2018 at 12:26 PM
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    Yes, they all same white bulbs
  6. Jun 28, 2018 at 12:27 PM
    Ronmat4X2
    2007 4X2 TRD
    Thanks folks
  7. Jun 28, 2018 at 1:05 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Vled!
    I would use red for brake.
  8. Jun 28, 2018 at 4:58 PM
    TheBeast The Beach
    yep that's what I did : 2 white for cargo and 1 red for brake.
    BlueBottle[QUOTED] likes this.
  9. Jun 28, 2018 at 5:00 PM
    Bulb no. 921, yes all same
  10. Jun 28, 2018 at 7:40 PM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    I would recommend changing to LED The center would be a red LED and the cargos are white.
    Check out HeadlightRevolution.com
    JoshuaA likes this.
  11. Jun 28, 2018 at 7:44 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    921 bulbs. If using LED definitely use red for center brake bulb. 194/186 also fit and are very bright. That's what I used for cargo bulbs, some day I'll buy 921s, those will be even brighter
    JoshuaA likes this.
  12. Jun 28, 2018 at 8:58 PM
    HecticEnergy
    HecticEnergy New Member
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Winjet Rear brake lights, leather seats, BackFlip tonneau cover, Spyder headlights, Pro Grille, pop&lock
    The light cover doesn’t make it red enough?
  13. Jun 28, 2018 at 9:55 PM
    Pudge
    CT
    Its fine with incandescent bulbs but with LED being so bright the lights takes on a pink hue. Red looks better imo
    Buildn and HecticEnergy[QUOTED] like this.
  14. Jul 3, 2019 at 9:09 PM
    JASON1234
    JASON1234 New Member
    2010 Tundra : '86 Chevy C-10 w/ LT1
    It is not the brightness that causes that pink hue. It is the frequency (color) of the output light. A traditional bulb's light emission is a wide array of different colors which, when passed through a colored lens, only that frequency will pass. In the case of a brake light, that would be red. Only the red light will pass, the other colors are absorbed (filtered). Most LED's put small range of frequency. hence, when you see something like 3k or 7k. 7k will be bluer. There won't be any frequency of reds emitted from the LED, which is why you get that pink look. Hope this is not too techie but it is the best way I could explain it. Use yellow/amber LED's if they are covered with amber lenses as the same will happen there too.
  15. Jul 3, 2019 at 9:47 PM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Baby mods doo doo doo doo doo doo
    Audio/Lift/Tires
