Carrier bearing drop kit. Do I need one?
Discussion in 'Suspension' started by Sharpienads, Aug 29, 2018.
  1. Aug 29, 2018 at 8:31 PM
    Sharpienads
    Sharpienads [OP] New Member
    2018 Tundra SR5 TRD O/R
    Hey all,
    I added a Toytec/Eibach 3/1 to my 2018 CM in super white (fastest color) and have read about guys adding carrier bearing drop kits because they notice "drive line vibrations". What exactly does that feel like? Would I know it if I had that problem? I have a slight vibration in the gas pedal that wasn't there before (I don't think), but I also added larger tires, if that would even make a difference. Is there any down side to the drop kit? Should I just add it because I lifted my truck and they're cheap anyways? Thanks!
    usmchawk and Blueknights75 like this.
  2. Aug 29, 2018 at 8:48 PM
    You’d know when you accelerate from a dead stop.
    YTThao530, Rica25 and Watt maker like this.
  3. Aug 29, 2018 at 8:48 PM
    White Tundra Crue:benchpress:
  4. Aug 29, 2018 at 8:50 PM
    Rica25
    Ricardo
    Tulare
    If I have billstein at highest setting in front with 1/2 inch spacer by toytec on both front also have 1 inch rear block would I need diff kit?
  5. Aug 29, 2018 at 8:58 PM
    Sharpienads
    Ok, thanks. My vibration is constant and barely noticeable. I don't notice anything when accelerating from a stop.
  6. Aug 29, 2018 at 9:00 PM
    Sharpienads
    What's your total lift up front? If more than 2.5" I think it's recommended to use a front differential drop kit.
  7. Aug 29, 2018 at 9:03 PM
    Rica25
    Ricardo
    Tulare
    Its between 2.5 and 3 I'm sure......can't remember the highest setting on the billstein plus the .5 inch
  8. Aug 29, 2018 at 9:07 PM
    Rica25
    Ricardo
    Tulare
    Diff drop kits are only for 4x4?
  9. Aug 29, 2018 at 9:10 PM
    Sharpienads
    Yes, 2wd Tundra doesn't have a front differential.
  10. Aug 29, 2018 at 9:16 PM
    o_O
    Rica25 likes this.
  11. Aug 30, 2018 at 4:17 AM
    TuFerLife
    TuFerLife New Member
    Taylor
    Chattanooga, TN
    2018 Tundra TRD Sport 4x4
    3" Toytec Eibach coilovers with .5" coachbuilder shims and Coachbuilder +3 shackles, JBA Upper Control Arms, Fuel Assault 20x10 -18 offset on 35x12.50 Cooper ST Maxx, Amp research stepbars, JBA Long tube headers, custom mid pipes and TRD Replacement exhaust system by Dirty Deeds, TRD Black Chrome Tailpipes, Bullit liner spray in liner, S&B CAI, Katzkin leather with Degreez heated and cooling system, Husky floorliners, Coachbuilder roof rack with 13 Rigid pods and Switchpro switch, TRD skid plate, Pop-N-Lock, Auto Tailgate down mod, Rattletrap sound deadener in headliner and door panels. Kenwood DDX 9906XR headunit with full Tech 12 volts sound system and dash cam.
    Just got my toytec eibach kit in the other day. Hope to have it on soon.
    You got any pics of your setup?
  12. Aug 30, 2018 at 7:05 AM
    Sharpienads
  13. Aug 30, 2018 at 10:28 AM
    Sharpienads
    You look confused... That's called a bench press. White Tundra Crue is fast and buff.
    :D
  14. Aug 30, 2018 at 10:30 AM
    Blueknights75
    Ron
    Clayton, NC
  15. Aug 30, 2018 at 10:44 AM
    What's so fast about white? We all have same engines, only fast ones are ones with S/C
    Black Wolf likes this.
  16. Aug 30, 2018 at 4:26 PM
    Sharpienads
    Super white is just the most fastest color. It's science.
  17. Aug 30, 2018 at 4:38 PM
  18. Aug 30, 2018 at 4:49 PM
    We both know the preferred color for delivery and cable guy trucks. The ones with the fastest color....it's science.....
  19. Aug 30, 2018 at 5:08 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    If you lift the rear of your truck, its said you'll need the carrier bearing drop. I have 2" blocks in the rear, I haven't done it, yet. I'm planning too soon. They say all you need is 3/4" shim for 3" lifts. In another thread I read someone got his spacers from lowes for under $2 , and reused his bolts. Made a difference
    Nativeimages likes this.
  20. Aug 30, 2018 at 6:32 PM
    Sharpienads
    I may just do it even though I'm not sure if I need to. The kit from Toytec is only $12. Maybe I'll look around at Lowe's, thanks for the info.
  21. Sep 15, 2018 at 8:06 PM
    Rica25
    Ricardo
    Tulare
    What's the difference from diff drop or a carrier bearing kit......or Is it same thing just different terms?
    FREEK likes this.
  22. Sep 16, 2018 at 12:02 PM
    Sharpienads
    Front differential drop lowers your front differential in order to reduce the angle of your front drive shaftes after adding a lift to the front of the truck.
    The carrier bearing supports the drive shaft towards the rear of the truck. Adding a drop kit to that does the same thing, helps correct angles to the drive shaft after lifting the rear.
    At least that's how I understand it, I'm definitely not a pro when it comes to this stuff.
    Rica25[QUOTED] and T-Rex266 like this.
  23. Sep 16, 2018 at 12:41 PM
    Rica25
    Ricardo
    Tulare
    So do I need the rear one for a 2wd ?
  24. Mar 21, 2019 at 7:02 AM
    dlos
    dlos Truckin'
    2019 Cement Off-Road
    Mods Mods Mods....
    I'm experiencing the same thing with a 2" block in rear, it's slight but it's there and driving me crazy. Did your spacer eliminate the problem? Did you also do the driff drop? Thanks!
  25. Mar 21, 2019 at 7:37 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Same here. I dug through my box-of-bolts and found two 3/4" spacers that fit perfectly. No more shudder.
  26. Jan 3, 2020 at 5:19 PM
    The Shaggy Fox
    The Shaggy Fox Astronaut Cat
    Just installed my RC kit today.
    Still need to see if it helped (just installed it a bit ago).
    Super easy and quick install.
    All you need is the kit and a way to unscrew/screw bolts. :D
    Others have mentioned (in various places) a jack to support the drive shaft. I didn't need one (and you shouldn't NEED one if you do it correctly - at least on a 2nd gen Tundra [but always be safe!]). I just gave some lift to my shaft with my shoulder to make it easier to manipulate (and make sure it wasn't going to fall incase a bracket or something broke). However, I have enough space to sit Indian style under the truck and rest my shoulder under it (ymmv). So set up a couple jacks if you want to for safety, but it wasn't required for my fix (assuming you follow the correct instructions when loosening up the existing connections.
    Oddly enough the head size of the RC bolt was larger than that of the stock Toyo one.
  27. Jan 3, 2020 at 5:27 PM
    The Shaggy Fox
    Also, does anyone know the ratio of lift to drop we should (optimally) use? Seems that most? kits are about the same size.
  28. Jan 3, 2020 at 5:36 PM
    DesertGorilla and SprinterAE86 like this.
  29. Jan 3, 2020 at 10:36 PM
    The Shaggy Fox
    Rica25 likes this.
  30. Jan 4, 2020 at 3:52 PM
    The Shaggy Fox
    Just found this:
    A general starting place would be ¼” of carrier bearing drop for every 1” of additional lift in the rear.
    Does that comport with what else anyone has heard?
