Carrier bearing drop question.
Discussion in 'Suspension' started by Badge618, Mar 4, 2022.
  1. Mar 4, 2022 at 4:39 PM
    Badge618
    Badge618 [OP] New Member
    Lassen County, Ca
    2019 TRD Pro Voodoo Blue
    I have a 2019 TRD Pro that I bought with the ready-lift sst installed. 2” block in the rear on top of the pro’s already 2”. It doesn’t have a carrier bearing drop done but I’ve don’t feel any vibration. I have a Coachbuilder drop that I could install. Should I just go ahead and install or no vibe no foul
    Coachbuilder1 likes this.
  2. Mar 4, 2022 at 4:40 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    If there's no vibration I wouldn't touch it
    831Tun and Badge618[QUOTED][OP] like this.
  3. Mar 14, 2022 at 10:58 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    May not feel like a vibration, but more like a shudder when you accelerate from a dead stop. Not even full throttle, trying to light the tires…. Just some solid acceleration will reveal any issue. It almost feels like the tires are trying to break traction a little…
  4. Mar 14, 2022 at 11:16 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Cheap insurance…2” in the rear I definitely would. Anything over an inch I’d correct the angle vibes or not.
  5. Mar 15, 2022 at 8:01 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Coachbuilder will recommend a drop kit (he offers and I've purchased it) on his 2" and 3" shackles
  6. Mar 17, 2022 at 4:18 PM
    Badge618
    Lassen County, Ca
    I am switching from the SST rear blocks to stock TRD setup with coachbuilder +3 shackles. I have the coachbuilder drop kit. I guess it won't hurt to install even if it feels like I don't have a vibration.
  7. Mar 17, 2022 at 4:21 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Since when does a Pro come factory with a rear lift?
    831Tun likes this.
  8. Mar 17, 2022 at 4:25 PM
    Badge618
    Lassen County, Ca
    As far as I know, and I am new to the tundra, the Pro models sit 2" taller front and back compared to non Pro's.
  9. Mar 17, 2022 at 4:26 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    I do not believe that to be accurate for the rear.
  10. Mar 17, 2022 at 4:28 PM
    Badge618
    Lassen County, Ca
    Max Lift: 2.0"F-2.0"R - Max Tire Size: 35".
    Equal to 4" lift on standard Tundra. 2015-2019.
    For use on 2015-2020 Tundra TRD Pro w/ Bilstein/Fox TRD Pro shocks. Retains use of the factory Bilstein/Fox TRD Pro shocks.
    This is from the ready lift website.
  11. Mar 17, 2022 at 4:37 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Those are the readylift specs, not the Pro OE specs. That tells you what the lift is over stock, +2F, +2R so overall 4" F and 2" R.
  12. Mar 17, 2022 at 5:16 PM
    Badge618
    Lassen County, Ca
    sounds good. I guess I never noticed the rake in a non pro to realize there wasn't anything in the rear of the pro like there is in the front. Like I said, I am new to the tundra platform. Doesn't really matter as my question was about the carrier drop with a lift if I didn't notice a vibration. I guess now we can get back to my original question about the carrier drop.
  13. Mar 17, 2022 at 5:18 PM
    Badge618
    Lassen County, Ca
    I guess I misunderstood when it said 2" front and 2" rear so 4" total compared to standard tundra. Nothing about 4" front and 2" rear.
  14. Mar 17, 2022 at 5:24 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Right on their website
  15. Mar 17, 2022 at 5:26 PM
    Badge618
    Lassen County, Ca
    So did you have a reply about the carrier bearing?
  16. Mar 17, 2022 at 5:26 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    If you dont have the vibration, no reason to try and fix something not broken right?
    And to the comment in bold, it does matter - you should know what you have, bought and run IMO.
    Not trying to be rude or abrasive here, just trying to provide you with details so you know what you have.
    GreatBasinTundra likes this.
  17. Mar 17, 2022 at 5:55 PM
    GreatBasinTundra
    GreatBasinTundra Beer Me!
    Reno, NV
    2020 Tundra SR5 DC
    Kings f/r, TC UCAs, RCI skids, RCI sliders, C4 bumpers f/r, Warn 12s winch, 35s on 17” Rebounds, softopper, wet okole covers
    I would check your drive line angles and only adjust if needed. IF you choose to do the CB spacer make sure you mark the exact location prior to loosening the CB bolts for left to right consistency. If this alignment is bad you will get far more vibration than what the CB drop will fix, from your explanation of your current situation.
    Badge618[OP] likes this.
  18. Mar 23, 2022 at 10:43 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I have a very minor vibration from lifting the rear an inch. With such little lift, I am concerned that the drop kits out there from vendors may be too much, most appear to be about 3/4 inch. Thoughts? I wonder about using some washers or some other spacer that is smaller, half inch or so, that I may be able to find a lowes or HD. Or should I just get the coachbuilder CB drop?
  19. Mar 23, 2022 at 10:50 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    Just grab a handful of 1/2" washers. I used the square plate washers because they were readily available. They're 1/4" thick. Available at HD, as well as Lowe's for much less than the CB kit, and you can have it today...
    https://www.homedepot.com/p/Simpson...K3oeHTrUWVscHExfg6xoC4I0QAvD_BwE&gclsrc=aw.ds
    BTW, I started with 3/4" stacks. Lost the shudder, but picked up a very mild vibration I could feel in my feet. I pulled one washer out of the stacks and now have 1/2". Vibration is better and still no shudder. My rear lift is via Deaver U748 springs and is still about +3" over OEM.
    I like the washers because you can dial the angle in with minor adjustments.
  20. Mar 23, 2022 at 10:55 AM
    frichco228
    Thanks, this is what I was thinking and what I will try!
  21. Mar 23, 2022 at 12:16 PM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    With the RL 2" blocks supplied in your kit its still worth adding some correction at the carrier bearing. RL uses a tapered block but even with the taper the amount of load the pinion feels at take off is not nice on the pinion or rear U joint. Our small CB drop kit. measures .750" and will work excellent. https://shop-coachbuilder.myshopify...kit-rear-lift-0-2?_pos=2&_sid=450d0bf8b&_ss=r
    Side note: the larger 6"-8" RL kits have the same problem with loading the pinion up during take off. We see this often.
  22. Mar 23, 2022 at 2:27 PM
    Badge618
    Lassen County, Ca
    I have your small cb drop kit already. I plan on removing the RL block and using your +3 shackle. If I put the drop kit in now with the block should I leave it in after the switch to the shackle?
  23. Mar 23, 2022 at 7:13 PM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    I agree with @14burrito . If you have a shutter and/or vibration use the carrier bearing drop kit. I had a slight vibration at take off with my 3/1.5 lift and the @Coachbuilder1 spacers did the trick. Not much more to say about it.
  24. Sep 30, 2022 at 7:40 AM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Latest thread I could find on the topic. It looks like my '21 Pro came with a drop kit from factory? I made some aluminum spacers real quick at work this morning and crawled under the truck to find this. I don't notice any vibration but do have CB +3 in the rear.. figured it wouldn't hurt to add them. 20220930_073352.jpg
  25. Sep 30, 2022 at 7:47 AM
    TwistedTad
    Tad
    Canyon Lake, CA
    @V10Ace that is a carrier bearing drop spacer. If there is no vibration and/or shuttering at take off you should be good to go. No need to add more spacers.
    V10Ace likes this.
