Center Bore Question - again
Discussion in 'Wheels & Tires' started by Puppypappa, Nov 21, 2021.
  1. Nov 21, 2021 at 8:26 AM
    Puppypappa
    Puppypappa [OP] New Member
    I've read extensively on here and I still can't seem to get a clear understanding of what size my Bore is when I'm looking at purchasing wheels.
    2019 Crewmax SR5
    I have read on here 110 and 110.5. If finding wheels with 110.5 in Canada wasn't such a PITA I'd just purchase something in that size.
    Looking for 18X9 but I'm having a hell of a time finding somewhat plain black rims (no bling) in a 25 offset.
    I can even find 110.1 and 110.2 but the selection of anything 110.5 is next to nothing.
    Am I correct in the sizing?
    Thanks
    Pup
  2. Nov 21, 2021 at 9:14 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    My '16 is 110mm. So are my wheels and they're a bit too tight. I think you're fine with 110.1 or larger.
  3. Nov 21, 2021 at 1:49 PM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    .5 MM is not going to make much difference. I had 3rd gen wheels on my 08 for a long time without issues.
  4. Nov 26, 2021 at 10:11 AM
    DerickBinDa
    DerickBinDa New Member
    Derick
    @Puppypappa your hub is 110.0 - this means that you need a 110.1 in order to fit over your hub perfectly and make it hubcentric.
    check out these options if you are in Canada:
    https://www.wheelsnearme.ca/product-detail/wheel-fast-hd-invasion-101707
    https://www.wheelsnearme.ca/product-detail/wheel-replika-r226-102982
    https://www.wheelsnearme.ca/product-detail/wheel-replika-r225-102981
    Those options are direct fit for your vehicle which means that you can use the original nuts and you don't need hardware. Wheelsnearme.ca also offers Canada-Wide free shipping!
    good luck.
    Derick.
  5. Nov 26, 2021 at 10:20 AM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    :spam:
  6. Nov 26, 2021 at 10:26 AM
    2mchfun
    I just installed Black simple design, XD Heist by KMC. 18x9 +30 though. Perfect fit on center bore. Ext. Thread conical nuts. Changing the factory center caps to dump the chrome logo. i ordered center caps with a srew on logo and it will get unscrewed, painted, and reinstalled. 20211120_085609.jpg 20211120_085609.jpg
  7. Nov 26, 2021 at 10:33 AM
    Hightide
    Abalama
    Magic School Bus
    Your only posts up until this one is pushing your wheeliesnearme…
    Even the post you edited that you initially quoted me in.
    :spam:
  8. Nov 26, 2021 at 10:38 AM
    2mchfun
    Roll with a 110 centerbore. If tight, sandpaper it just a bit and you will be fine. Might need to wire brush your hub rust before installation too.
