center console shifter surround replacement
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by daveS67, Aug 13, 2021.
  1. Aug 13, 2021 at 9:36 AM
    daveS67
    daveS67 [OP] New Member
    So this chromed and silver surround around the shifter and the cup holder reflects the sunlight directly into my eyes while driving. Even with sunglasses, the chrome bits are brutal on the eyes.
    Has anyone experienced this? Has anyone found a good quality replacement that is black or some other dark/non-reflective finish? I would rather replace than take these off and paint them.
    Thanks!
    Tundra812 likes this.
  2. Aug 13, 2021 at 9:39 AM
    mech_engineer09
    mech_engineer09 Tundra Enthusiast
    Ohio/Pennsylvania
    2020 MGM Platinum
    Ceramic Pro, XPEL Ultimate Plus, Woolwax Undercoating, Diamondback HD, TRD Air Intake, TRD Skid Plate, TRD Front & Rear Sway Bar
    Southshore30 likes this.
  3. Aug 13, 2021 at 9:40 AM
    Highsierraguy
    Highsierraguy New Member
    Nor Cal
    If you want a tacticool look, AJT designs makes a black version for both. Otherwise, you'll need to remove and paint it yourself.
  4. Aug 13, 2021 at 9:49 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Both pieces pop right off. Quick clean and scuff. Adhesion promoter and SEM trim black make it look real nice.
  5. Aug 13, 2021 at 10:01 AM
    RobertD
    Robert
    DFW, Texas
    As stated, you can either get cover pieces or just paint. Not difficult to paint them.
    https://www.tundras.com/threads/painting-chrome-trim-bezel-around-shifter.27828/
    Edit: realize you stated you didn't want to paint. From what I've seen about the AJT reviews, you still have to disassemble and drill for the shifter surround, I think painting would be easier but that us up to you.
    Edit 2: I used SEM trim paint in their charcoal metallic, pretty much matches the trim piece on the dash that isn't black or light gray.
    EN2TUNDRA and Tundra234 like this.
  6. Aug 13, 2021 at 10:11 AM
    +1 for the SEM trim paint
  7. Aug 13, 2021 at 10:15 AM
    justcuz
    justcuz 2.5 Gen Member
    Painted mine too used SEM black paint. Then did some body color paint matching.
    EN2TUNDRA likes this.
  8. Aug 16, 2021 at 8:53 AM
    browniemix33
    browniemix33 New Member
    New Hampshire
    2017 Metallic Grey Tundra Limited 4WD
    following
