Change from single zone climate control to dual-zone
Discussion in '2.5 Gen Tundras (2014-2021)' started by eubeman, Sep 20, 2018.
  1. Sep 20, 2018 at 8:29 PM
    eubeman
    eubeman [OP] New Member
    2017 SR-5 Silver Tundra 4x4 5.7 i-Force V-8
    So this might be an off the wall question but I have a 2017 SR-5 Double Cab Tundra with single zone A/C unit. Can you upgrade to a dual-zone and besides the face place is there any other components that would need changed to allow this. I was looking at some schematics of a platinum and all the components appeared to be the same but I am assuming I am missing something. So if you could help it would be appreciated
    Y0TA PR0 likes this.
  2. Sep 20, 2018 at 8:38 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME
  3. Sep 20, 2018 at 8:47 PM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    Welcome. Aside from the controls, you'll need the dual blend doors and the ducting is probably different to accommodate the dual blend doors. IDK though. I haven't been behind the dash.
    ColoradoTJ likes this.
  4. Sep 20, 2018 at 8:58 PM
    Welcome to the site.
    Hopefully you can look in local junk yards for a limited or higher trim package and get all the components that way.
    My 2012 CM had dual climate controls, and that was a requirement. So I can understand why this might be important.
  5. Dec 12, 2021 at 4:59 AM
    RicksCTTundra
    RicksCTTundra New Member
    Rick
    2019 SR5 TRD OFF ROAD
    Tonneau, Side steps, 12 volt solutions remote start
    Hi,
    Did you ever have any luck with this mod? I'm interested in doing the same. Thanks
  6. Dec 12, 2021 at 6:37 AM
    Kung
    KG, VA
    Pretty much. A year ago I had some odd and VERY intermittent sensor issue with my truck; I've got the dual-zone auto HVAC thing.
    I was asking if it was possible to 'downgrade' to the single zone manual HVAC system. I was told I "could" but they'd have to replace some other components particular to the dual-zone system (blend doors, actuators, etc.). It was prohibitively expensive UNLESS one either is a mechanic or already had/has it torn apart for something else.
