Cheap amazon light bar in hood bulge
Discussion in 'Lighting' started by TRDProLife, Apr 15, 2021.
  1. Apr 15, 2021 at 4:55 PM
    TRDProLife
    TRDProLife [OP] LETS GO BLUES
    St.Louis
    Barcelona Red Metallic TRD Pro Tundra
    Window Tint, ICI Magnum Steps, firestone spring helpers for towing, 295/70R18 Atturo Trsil blade X/T's
    Bigboitundra likes this.
  2. Apr 16, 2021 at 12:15 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    There is a recent thread somewhere in here about it.
  3. Apr 18, 2021 at 7:13 PM
    That thread was about the orange one which was nothing more than an led strip. However, I have not seen the one that the OP linked.
  4. Apr 18, 2021 at 8:21 PM
    crewmaxlmt
    scott
    My bad. I will be interested to see the opinions. I would like a hood bulge light bar that is reasonable and works well.
    Bigboitundra and TheGreyTundra28 like this.
  5. Apr 18, 2021 at 8:44 PM
    Rubberdown
    Im interested too. Let me know what you find out!
  6. Apr 18, 2021 at 8:45 PM
    TheGreyTundra28
    TheGreyTundra28 New Member
    2018 Grey Tundra Sport
    Dirty Deeds 10 budget exhaust, Roof rack, 52" windshield, Truxedo Tonneau, and Line x Bedliner
  7. Apr 19, 2021 at 11:39 AM
    TRDProLife
    St.Louis
    I ended up not choosing this light, as it is actually 41.625 inches.
    I ordered the single row 41" nilight from Amazon.
  8. Apr 24, 2021 at 9:11 PM
    TRDProLife
    St.Louis
    No complaints as of now. For a $100 light bar it's hard to complain. Not quite finished with the install. It is getting late. All I have left to do is clean up the wiring and finish bolting on the hood bulge.
    Here is a quick video from the cab.
    Low beams, high beams, then light bar
    https://1drv.ms/v/s!AtEkKNu1Au1pqCb6Lw3KFsnWFP34
  9. Apr 24, 2021 at 9:32 PM
    13igtymer
    13igtymer New Member
    2016 toyota tundra crewmax limited
    Did the light come with mounting brackets?
  10. Apr 24, 2021 at 9:36 PM
    TRDProLife
    St.Louis
    Yes it did. Just simple L brackets.
  11. Apr 24, 2021 at 10:31 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    that looks really good
  12. Apr 25, 2021 at 2:58 AM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    Can you post some more pics of how this mounts to the hood bulge if you get a chance, curious to see how this fills the space and what all had to be done make it a tight fit around the light, looks good so far!
  13. Apr 25, 2021 at 4:12 AM
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    I have Extreme LED 38” slim line. Very happy
    You can use sdhq brackets with little modifications.
    I also have 30” RC led bar in the bumper but extreme LED is better in my opinion.
  14. Apr 25, 2021 at 5:19 AM
    TRDProLife
    St.Louis
    I sure can. I am about to head out to finish it up now. I will take some more pictures before I close it all up.
    I don't think you can have a much tighter fit to be honest.
  15. Apr 25, 2021 at 5:54 AM
    TRDProLife
    St.Louis
    It's a pretty simple job. You have to cut the three braces and the two tabs on the ends. Then you can mock it up and mark your holes.
  16. Apr 26, 2021 at 6:55 AM
    TRDProLife
    St.Louis
    So I got the chance to get out of the city and hit the back roads in Southern Illinois last night. I can say without a doubt, I am extremely pleased with the performance of this cheap nilight light bar. I mean it is dad gum bright folks. It has a good spot down the road and plenty of flood to the left and right.
    Who knows how well it will hold up. But it has a 2 year warranty and I can easily buy another one later if I needed to.
  17. Apr 29, 2021 at 8:39 PM
    JJ_TNDRA20
    JJ_TNDRA20 JJ
    SOCAL
    2020 TUNDRA TRD PRO SW
    *Wheels/Suspension -ReadyLIFT Plus 2 -ReadyLIFT skid plate adapter -Method MR701 18 x 8 + 25 -BFG KO2 305/70/18 *Exterior -BakFlip MX4 hard cover -Rigid Industries foglight caps *Audio -2 AudioMobile 10 in subs -Sealed dual 10 enclosure -Helix Class D 1 channel amp -Helix 4 channel amp -5 channel Line Out Converter -BLAM audio 6.5s/6x9s/tweeters
    Looks dope...I've been trying to figure out which one I want to get...
  18. Apr 29, 2021 at 10:05 PM
    NWPirate
    Zach
    WA
    TheGreyTundra28 likes this.
  19. May 15, 2021 at 1:48 PM
    TxGnRnr
    TxGnRnr New Member
    2021 Silver 1794
    Peragon Cover, AMP Bedstep, OPT7 LED Bar, Yaesu FTM400XDR, Wouxun KG-1000G
    @TRDProLife Can you please post the item name from Amazon? The link to Amazon just goes to "Tundra Accessories" search results. TIA.
  20. May 16, 2021 at 8:36 AM
    TRDProLife
    St.Louis
    No problem
    This is just the light bar no wiring, relay or switch.
    https://www.amazon.com/gp/aw/d/B019XS8BKK?ref=ppx_pop_mob_b_asin_title
    This is the wiring kit I used. The switch however is too big. You will need a "toyota small switch if you want it to fit in one of the factory blanks.
    https://www.amazon.com/gp/aw/d/B074GWMRGD?ref=ppx_pop_mob_b_asin_title
    Pro tip, I also used two button head allen bolts for mounting the light bar instead of the allens that came with it. This allows it to rest a little farther back in the hood bulge.
  21. Jun 3, 2021 at 7:47 PM
    619Iron
    619Iron Desert Diva
    Amber
    San Diego
    2018 Tundra TRD-OffRaod CrewMax
    Method NV wheels 0 offset with Micky Thompson 36” tires and TRD wheel caps , fox 2.5 DSC coil overs, Camburg KINETIC UCA's, TRD front & Rear sway Bars, TRD Skid plate, Addictive Desert Stealth Fighter front Bumper, Rigid 40" curved Light Bar, 2 BAJA DESIGNS 10" AMBER driving lights, Baja Designs 40" ONX6 and S8 Amber behind the grill lights, 40" Radiance SR Pro RBGW light bar in hood Bulge, Rigid DSS pro Ditch Lights, pro Comp RGBW rock lights. Amp running boards with custom red LED lighting system, Custom TRD dual air intake with use of GTEK fab and 4" Spector intake tube and Mishimoto silicone fittings, AFE throttle body spacer, Dual Switch Pro 9100 lighting & electrical systems, Pedal commander, Warn Zeon 10K S Platinum winch, SDHQ dual battery Kit with Power steering Upgrade. TRD Pro Front Grill, with Color Matched Hood bulge, Coach Builder Shackles and coil over spacers, Coach Builder bump stops and bushings. Coach Builder tie rods, and steering bushings, IKON RST leaf springs, SDHQ traction bars, Dirty Deeds straight exhaust with Helmholtz resonator, RCV front axles, Total Chaos lower control arms, and Camburg spindles. SDHQ Arb on board twin compressor.
    I just picked up this light bar from Amazon made in the USA. 119.00 bucks LED Light Bar 40 inch - 4WDKING Screwless 200W IP69K Waterproof Off-Road Combo LED Work Light Super Bright Truck Driving Fog Lamp Fit for Ford F150 Polaris RZR Jeep Wrangler Opens in a new tab and it fits the bulge perfectly, didn't need the wiring kit because I have the Switch-Pros controller, Just put the Sasquatch light sticker on the button. Extremely bright for the money almost as bright as my 40" bumper light from Rigid which cost over 1K. Definitely well worth the money, THE NV light bar super expensive and way harder to wire up. I will upload the file with beam comparison once I'm done with the install of my 30" ADAPT light.
    Jr3volution and Yota303 like this.
  22. Oct 12, 2021 at 10:43 AM
    619Iron
    619Iron Desert Diva
    Amber
    San Diego
    Well I made some changes to the original configuration that I planned with my Tundra. For the price of the Rigid Adapt light, I opted for a couple of Baja Designs light bars, an S8 wide Amber light for fog, and an OnX 6 combo driving, both 40” light bars. I ditched the Rigid Radiance Curved light for the Rigid RDS PRO midnight edition 40” light bar for the bumper. In the hood bulge I returned the Amazon light for the Rigid Radiance Plus SR-series 40” RBGW Light for the hood bulge. With a couple of Rigid DSS PRO ditch lights and Rigid SR Series Pro driving lights in the fog light section of the bumper.
  23. Oct 12, 2021 at 10:47 AM
    Does the Rigid bar in the bulge have the gap in front of it like the S8 does?
  24. Oct 12, 2021 at 12:04 PM
    619Iron
    619Iron Desert Diva
    Amber
    San Diego
    Very little if any gap. I did have to trim the inside of the bulge at the corners for a flush fit. No vibrations or noise even at 100mph.
    HulkSmurf14 likes this.
  25. Oct 12, 2021 at 12:11 PM
    619Iron
    619Iron Desert Diva
    Amber
    San Diego
    Here is a couple of photo close ups
    hANNAbONE, Yota303 and HulkSmurf14 like this.
  26. Oct 12, 2021 at 2:01 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
  27. Oct 12, 2021 at 2:14 PM
    Now for installs, all of those black clips get removed and replaced with nutplates and screws. For strength, could you still do the aluminum bar to reduce flex and then build up the areas around the plastic clip mounts with JB Weld? Putting the screen portion back in would help some too. I put it back in mine.
    Cruzer[QUOTED] likes this.
  28. Oct 12, 2021 at 2:16 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    JB Weld sounds like a good idea.
  29. Oct 12, 2021 at 2:22 PM
    I'll take pics when I redo mine. I also had to completely remove the 2 end clips because it was hitting my bar on the original install. Once I pushed the bar farther back, my corners of the bulge stick up a little and have a gap when it's in the hot sun. I have a new bulge already. Pushing the bar back allowed me to align it easier and allow me to reinsert the screen portion to hide the big gap between the edge of the bulge and the bar.
  30. Oct 12, 2021 at 2:36 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Gonna have to show me the nutplates and screws you're talking about as well. Anything to beef it up some more is a good thing.
