Check engine light, 4lo blinking, traction control light
Discussion in '2nd Gen Tundras (2007-2013)' started by Evkohuth, Mar 1, 2025.
  1. Mar 1, 2025 at 8:49 PM
    Evkohuth
    Evkohuth [OP] New Member
    Evan
    2010 black Toyota Tundra
    I recently got out of work after buying my tundra a day ago and the check engine light, traction control light, and 4lo was blinking, anyone got any ideas?
  2. Mar 1, 2025 at 9:15 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    is it in limp mode? could speculate all day but you gotta pull the code so you know what's actually happening.
  3. Mar 1, 2025 at 9:54 PM
    Evkohuth
    Evan
    No it’s not in limp mode thankfully, I drove home just fine, going to take it to get scanned at autozone tomorrow, hoping it’s nothing serious
  4. Mar 2, 2025 at 5:29 AM
    MartinBlank
    MartinBlank New Member
    Bruce
    Loveland CO
    2008 Crew Cab Limited
    TRD Sway Bars, TRD CAI, Bilstein 5100's, LED's, plus LED rear Plate backup light, Aluminum oil filter housing, ECGS Needle Bearing upgrade.
  5. Mar 2, 2025 at 11:11 AM
    Evkohuth
    Evan
    Update: got the codes read it was pulling these, P2438, p0761, p2714. Someone help me out here?
  6. Mar 2, 2025 at 11:20 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    oh my god, bro. google. google is your friend
  7. Mar 2, 2025 at 11:23 AM
    koditten
    Kirk
    Midland of the Mitten
    The 1st one is an air flow sensor showing high air pressure with the air injection system.
    The send 2 have to do with shift solinoids in the transmission.
    Are you sure something didn't chew on the wire harness?
    Mdl likes this.
  8. Mar 2, 2025 at 9:17 PM
    Evkohuth
    Evan
    I appreciate the help I don’t know anything chewed on it from what I can tell but I just bought it a couple days ago so. Just hoping I don’t need a new transmission
    koditten[QUOTED] likes this.
