Check engine light Flashes and engine idles rough and stalls
Discussion in '1st Gen Tundras (2000-2006)' started by paulmcheek, Aug 1, 2021.
  1. Aug 1, 2021 at 2:58 PM
    paulmcheek
    paulmcheek [OP] New Member
    Paul
    White 2003 Tundra
    None
    Started to idle and run rough all of a sudden. Then noticed check engine ight also flashing.
    Anyone got any ideas ?? Thanks in advance.
  2. Aug 1, 2021 at 2:59 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Sounds like a misfire. Better double check with a OBD2 meter. You really shouldn’t be driving when it’s flashing unless you know for sure.
    NewImprovedRon likes this.
  3. Aug 1, 2021 at 3:01 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Does it sound really loud? Your cats probably got stolen
  4. Aug 1, 2021 at 7:06 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Misfire.
    Get someone to read the codes and replace coils/all the plugs if they are old. Many people will recommend OEM coils but a lot of guys have had good luck with MSD ones.
  5. Aug 1, 2021 at 7:15 PM
    Solid light, code is registered that needs to be checked and addressed. Flashing light is reserved for serious codes that could affect drivability and potentially damage the drive train. Get a code reader and check the code before moving the vehicle.
  6. Aug 1, 2021 at 11:03 PM
    shootemintheface
    shootemintheface New Member
    01' Tundra V8 Limited New Frame
    Like others have said flashing check engine light is serious issue. Turn off asap. Get one of those code readers on Amazon. I use the Veepeak blue tooth along with Torque Pro to monitor system parameters. Do unplug it if you don't wish for it to drain your battery when you park.
  7. Aug 7, 2021 at 5:40 AM
    paulmcheek
    Paul
    White 2003 Tundra
    None
    Got a code reader. Got Misfire on cyclinder 1 , and Misfire on multiple cyclinders. Will try replacing coils first !! Thanks for help.
  8. Aug 7, 2021 at 8:02 AM
    Jack McCarthy
    Bill
    North of Boston
    Try putting some dry gas in the tank to make sure it isn’t water causing the issue.
  9. Aug 7, 2021 at 6:09 PM
    shootemintheface
    Gas that has ethanol in it that has been sitting in your gas tank for a months will do this also.
