Chrome bumpers on 1st gen Tundras?
Discussion in '1st Gen Tundras (2000-2006)' started by FirstGenTundra1867, May 18, 2022.
  1. May 18, 2022 at 10:29 PM
    FirstGenTundra1867
    FirstGenTundra1867 [OP] New Member
    Ron
    So. Cal.
    2006 access cab Limited V8 Auto trans 4x4 Tundra
    Removed aftermarket Pioneer unit and re-installed OEM 6 disk radio/cd/cassette unit.
    I've tried researching this with no luck, so thought it was time to turn to the forum. Trying to determine what the last year was for chrome bumpers on 1st Gen Tundras. Thanks, Ron
  2. May 18, 2022 at 10:52 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I believe that is right too. @empty_lord truck has the chrome bumper (painted black in the pics I found) it's an 05. His truck has been rolled so idk if its stock just something I had remembered seeing. Sure he'll chime in.
  3. May 19, 2022 at 3:56 AM
    Searching just for funsies or you have something in mind?
  4. May 19, 2022 at 4:28 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    According to Toyota Brochures, front and rear chrome bumpers were available on certain cab types all the way to 06.
    1st Gen Tundra Brochures & Owner's Manual | Toyota Tundra Forum (tundras.com)
  5. May 19, 2022 at 4:41 AM
    This an an 05 with a chromey front bumper. Note the new style grille. The filler panel(s) between bumper and headlights is different than the earlier 00-03 versions. Bumper appears the same though.
    Jack McCarthy likes this.
  6. May 19, 2022 at 5:08 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Mine was factory steel bumper. It was chrome, it was bent so I replaced it with a black one
    NickB_01TRD[QUOTED] likes this.
  7. May 19, 2022 at 6:57 PM
    HAL69000
    HAL69000 New Member
    2004 Double Cab 4WD
    I looked into retrofitting my double cab with a steel bumper last year and yes, a lot of standard cabs had steel bumpers for the whole first gen run.
  8. May 19, 2022 at 7:09 PM
    dbittle
    dbittle Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    My 2006 work truck came with the chrome bumper.
  9. May 20, 2022 at 10:49 AM
    FirstGenTundra1867
    Ron
    So. Cal.
    Thank you all for the great responses to my bumper questions. And Bubba, your "features chart" was a huge assist! And Knabores--my "ride" is a white 2006 Limited access cab with white, fiberglass bumpers. I was considering swapping out the white bumpers for chrome just to break up that all-white appearance and add some "Chromy Bling" to the truck, but changed my mind when I got a quote for the cost of chrome bumpers and front brackets that ran close to $2,000! Thanks again everyone for the responses! Ron
    BubbaW likes this.
  10. May 20, 2022 at 11:24 AM
    $2000 seems excessive. You could likely convert for $400 or so.
    https://www.ebay.com/itm/1443962370...jABrn33Qga&var=&widget_ver=artemis&media=COPY
  11. May 20, 2022 at 11:25 AM
