Chrome Running Boards
Discussion in '3rd Gen Tundras (2022+)' started by JMUHokieCPA, Mar 11, 2024.
  1. Mar 11, 2024 at 6:58 AM
    JMUHokieCPA
    JMUHokieCPA [OP] New Member
    Roanoke Virginia
    My 1794 model was not equipped with the power running boards. As such, I am looking for something with a little bit of shine to go with chrome look of the model. Any suggestions would be appreciated. I have seen some aluminum ones, but they look dull in the picture and not sure they would match. Thanks
  2. Mar 12, 2024 at 8:53 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
  3. Mar 12, 2024 at 12:23 PM
    Eurodriver
    Eurodriver New Member
    Chrome won’t get you home!
    Hella Krusty and teab like this.
  4. Mar 16, 2024 at 11:47 PM
    Leicafish
    Leicafish New Member
    SoCal soon to be NorCal
    2024 1974 TRD
  5. Mar 17, 2024 at 2:24 PM
    Leicafish
    2024 1974 TRD
    Installed the Alum I step 6inch boards
    The Tundra fit and finish made it a very easy task. I used the bolts and washers that Toyota had pre-installed to plug the holes-threaded inserts. In my my opinion they were better quality and offered a corrosion resistant coating. There are four brackets for each side. Around 11.5 inches Clearance from bracket (if I measure correctly)
    The functionality and fit rendered a very good value. I received what I paid for. I like the style as opposed to usual off road scheme.
    I may add lineX to black later.
    4mm and DRP like this.
  6. Mar 17, 2024 at 4:04 PM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    I need sunglasses
    Hella Krusty likes this.
