Cleaning back window with a camper shell ?
Discussion in 'Tonneau Covers, Caps and Shells' started by crsides, Mar 22, 2021.
  1. Mar 22, 2021 at 12:21 AM
    crsides
    crsides [OP] New Member
    My 2018 tundra came with a camper shell and it fits so close to the cab I can't get anything between the two to clean the window. My cab window is a sliding deal, but my camper shell is a fixed window. Anybody figured out how to clean the outside of both windows without taking the shell off ? Its getting pretty nasty and I'm going half way across the country in a few weeks.
    thanks
    Charlie
  2. Mar 22, 2021 at 12:42 AM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    They make those window cleaners you attach to a hose. Maybe this can help or else just slide the camper back a couple feet and get to work.
  3. Mar 22, 2021 at 1:02 AM
    crsides
    I'm an fat old white guy and sliding camper tops back is past my pay grade.
    Rex Kramer likes this.
  4. Mar 22, 2021 at 3:56 AM
    ezdog
    ezdog New Member
    Gateway To The West
    I jacked around with this Yesterday and just used a thin stick with a rag on the end and had to reattach it 3 million times and it barely made a dent at all.
    Sp it is either slide the hell back or find a ferret to work for you and we all know that ferret are not all that productive in general too?
    1st world problem I think.
  5. Mar 22, 2021 at 3:59 AM
    timsp8
    NY
    If you can’t squeeze anything in there, then your only option is to slide it back. It’s not that hard or heavy. Just have to unclamp it, then lift and slide. I’m old too but can do that by myself. I just can’t take it off the truck completely by myself.
    Maybe look for a squeegee with a long handle.
    Black Wolf likes this.
  6. Mar 22, 2021 at 4:06 AM
    SouthWestGA
    SouthWestGA New Member
    Unclamp the Shell
    Get inside it and lift it with your back like a turtle shell
    Slide it back a few feet
  7. Mar 22, 2021 at 4:53 AM
    ezdog
    ezdog New Member
    Gateway To The West
    Yeah there are shells and then there are shells.
    Mine is a chore and 1/2 to move at all and is clamped and bolted in place too.
    Then the side boxes are full of stuff and the alignment on the truck is pretty specific too,it is not a job to be taken lightly!
    YMMV I hope!
  8. Mar 22, 2021 at 5:10 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    My Leer caps had a window that I could remove for cleaning, but this was not an option on my new ARE DCU cap. I am going to spray "Lemon scent Scrub free Total bathroom cleaner plus foaming oxi clean", then use a brush and high pressure water this spring after the pine pollen subsides. My cap is bolted down, an this old white guy isn't to unbolt and move it either.
  9. Mar 22, 2021 at 5:10 AM
    timsp8
    NY
    I have an ARE that weighs probably 150 lbs so I assumed he had something like that. Mine has 4 clamps that can be easily unbolted. I forgot about the bigger and heavier ones.
  10. Mar 22, 2021 at 5:21 AM
    Professional Hand Model
    Hand Protectors
    Thin stick, or better flexible fiberglass rod, with a Ziptied Microfiber Towel on the end. Dunk in warm soapy water and have at it down the slot. Rinse with garden hose. Patent Pending.
    Black Wolf and Rex Kramer like this.
  11. Mar 22, 2021 at 5:34 AM
    Rex Kramer
    Georgia
    That would work for light dust, but it won't work for thick pine pollen with mold growing in it.
    That yellow / green shit needs a powerful Tim the Tool Man solution.
  12. Mar 22, 2021 at 12:49 PM
    crsides
    Sir, your patent is no longer pending... it has been approved.
    5/16" dowel, zip tie, Microfiber towel. Works like a charm. Thanks
  13. Mar 22, 2021 at 12:56 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Hockey stick with a soapy towel attached to the end. You can rotate the stick to get the towel end into the glass.
  14. Mar 22, 2021 at 3:26 PM
    AndyCBR
    AndyCBR New Member
    Baton Rouge, LA
    Try out the Windshield wow!
    I like mine and I bet the magnet and pad would clear the gap.
    https://windshieldwow.com/
  15. Mar 22, 2021 at 4:02 PM
    ezdog
    ezdog New Member
    Gateway To The West
    That is INSANE!
    Me Likey!
  16. Mar 22, 2021 at 4:20 PM
    Rex Kramer
    Georgia
    Vince Offer
