Clicking noise when stepping on brakes
Discussion in '2nd Gen Tundras (2007-2013)' started by wchang23, Apr 28, 2021.
  1. Apr 28, 2021 at 10:23 AM
    wchang23
    wchang23 [OP] New Member
    William
    2008 Tundra SR5
    20-inch aftermarket rims
    I have a 2008 Toyota Tundra SR5 and I noticed that whenever I am driving I hear a clicking noise when I step on the brake pedal. The clicking noise is coming from the steering column. This sounds like the release latch for the transmission when you release from P to R. Is it normal to hear that clicking noise every time I step on the brakes? I am a new Tundra owner and do not know if this is a normal thing or should I get a part to replace? Thank you!
  2. Apr 28, 2021 at 10:33 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Mmmmm maybe normal.... my Celica's rear brakes click when I apply them, so does my 07 Tundra.
  3. Apr 29, 2021 at 4:13 AM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    '07 tundra here.....No noise
  4. Apr 29, 2021 at 7:11 AM
    PayItOff428
    PayItOff428 New Member
    Jake
    The United State of Texas
    2012 SR5 Double Cab 4X4
    CV axles click that are going bad can make a clicking sound under load both when you accelerate or brake hard. Is yours a 4x4?
  5. May 13, 2021 at 5:51 AM
    wchang23
    William
    2008 Tundra SR5
    Hello guys,
    Here is a video of the noise whenever I step on the brakes. I can see the mechanism moving by the steering wheel. What is this part called and how do I change it?
    https://youtu.be/EsCHoZdvSPM
  6. May 13, 2021 at 6:00 AM
    Dan_Gleesac14
    Dan_Gleesac14 New Member
    2023 Tundra SR5;2018 Tundra Platinum (SOLD)
    Might be the brake lights activating? On my R6 and pretty much all bikes I've encountered, there is a very noticeable click as well, which is the brake lights activating first with very little brake pressure still.
  7. May 13, 2021 at 6:02 AM
    timsp8
    NY
    Pretty sure my 2018 and my previous 2010 clicked. I’ll check it later.
  8. May 13, 2021 at 8:12 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    That device unlocks the column shifter so you can shift out of park.
    That unlocks the shifter so you can shift out of park. If the noise bothers you, you can try greasing it a little bit, but it needs to be there and is definitely going to make noise.
  9. May 13, 2021 at 8:29 AM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    Normal. I always thought the clicking was relay but very clearly it's the park lock out physically in the column. Cool!
  10. May 13, 2021 at 9:54 AM
    wchang23
    William
    2008 Tundra SR5
    Thanks for confirming this is normal and not a defect. Will greasing it help reduce the noise? Was it always this noisy from when the truck was new?
  11. May 13, 2021 at 10:03 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Wtf??? How in the hell is that normal???
    Kgfit85 likes this.
  12. May 14, 2021 at 9:31 AM
    wchang23
    William
    2008 Tundra SR5
    That is what I thought initially. Not sure how to fix the noise or just leave it?
  13. May 14, 2021 at 10:10 AM
    audiowize
    Paul B.
    In a truck with a column shifter, that's where the lockout needs to be and the ability of the factory to quiet the thing down is space limited.
    In a truck with a console shifter, the lockout can be more buried and there's more space to deaden the sound a bit.
    joonbug[QUOTED] likes this.
  14. May 14, 2021 at 10:31 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Understood. I had a column shifter on my last Tundra and it made zero noise. For OP’s truck to click that loud every time he brakes is absolutely not normal. In fact that would drive me insane.
  15. May 14, 2021 at 11:30 AM
    blackoutt
    Indy
    OEM+
    My 2007 column shift: clicky click. I didn't really notice it when driving until you guys pointed it out! lol
  16. May 14, 2021 at 11:38 AM
    wchang23
    William
    2008 Tundra SR5
    Thanks for the video, mine is exactly the same. I guess there's nothing to worry about.
    blackoutt[QUOTED] likes this.
  17. May 15, 2021 at 8:04 AM
    audiowize
    Paul B.
    Did you try squirting a little grease in there? Maybe white lithium grease?
