Clicking noise when trying to start a 2003 tundra
Discussion in '1st Gen Tundras (2000-2006)' started by Tundratoy2003, Sep 10, 2021.
  1. Sep 10, 2021 at 10:21 AM
    Tundratoy2003
    Tundratoy2003 [OP] New Member
    2003 Tundra 4.7 litre
    Good morning . We are trying to fix a 2003 tundra 4.7 litre. It makes a clicking noise when we tried to start it after it was parked and not driven for 6 weeks. Tried to jump start it. Still clicking and engine doesn’t turnover. Replaced the starter. Still clicking. Anyideas? The battery terminals are clean and not corroded. The battery is about 5 years old. The fuses don’t look blown or melted.
  2. Sep 10, 2021 at 10:25 AM
    Stupid question, I hear you said you jumped it, but have you tried tossing a new battery in totally?
    FrenchToasty likes this.
  3. Sep 10, 2021 at 10:25 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Battery at 5 years old needs to be replaced. Confident that is part of your issue.
  4. Sep 10, 2021 at 10:28 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Sounds like a dead battery to me. Sometimes they are so dead even jumping it won't work.
  5. Sep 10, 2021 at 10:32 AM
    jsteph89
    jsteph89 The wish list continues to grow
    Joseph
    South Texas
    2019 Limited 4x4
    Blacked out emblems, Leer 100XL camper shell, Magnaflow exhaust, ProComp 3/1 level kit, 285/55R20 Falken Wildpeaks AT3, WeatherTech mats, full led interior swap,
    Definitely battery issue
  6. Sep 10, 2021 at 10:36 AM
    Tundratoy2003
    Thanks everyone for the new battery suggestion. Will try that today and keep you all posted!
  7. Sep 10, 2021 at 10:38 AM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    Check your battery with a volt meter and see what voltage it has. Then find all of your ground wires and check them for corrosion and tightness. Like others above have stated, it sounds like a battery/voltage/corrosion issue. Good luck OP
  8. Sep 10, 2021 at 10:39 AM
    Tundratoy2003
    Thank you I’ll pick up a volt meter today!
  9. Sep 10, 2021 at 10:54 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    hang around, we’ll have you spending all your money
    :spending:
  10. Sep 10, 2021 at 3:14 PM
    Tundratoy2003
  11. Sep 10, 2021 at 5:06 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Good luck and keep us posted with your results . . .
  12. Sep 10, 2021 at 5:16 PM
    KK6PD
    KK6PD 2 1 yr. retired . . . after 42 yrs
    ROAD
    Upper Los Angeles Foothills
    2003 AC Tundra . . . . 7th owner
    New Tires, Stereo & Speakers,Uni-Strut Tie Down Continue watching THIS SPACE FOR FUTURE DEVELOPMENTS
    There's always a minor possibility the starter relay is kaput, but I'll go with check the battery voltage first. If bad, new battery, if then still clicking starter relay!
  13. Sep 10, 2021 at 6:20 PM
    Yeah, to that point, I've had batteries where all 6 cells are perfectly fine, battery shows 12.5v or more, yet if you test the battery's CCA, it has virtually no cranking amperage to offer, which would result in this. The fact this one sat for a while... batteries HATE not being recharged, especially in cold temps, I wouldn't be surprised to know the battery is at fault. The good part is, you can potentially swap in any good charged battery from another vehicle with matching posts to do a quick test.
    Actually, you know, I really don't like that MF'er ChrisFix, but he has a battery testing video I watched once where he shows a dual-battery Humvee with two 800 CCA batteries, one tests out at like 75 or 85 CCA on one battery, the other was at like 300-400 CCA or something - end result of only having 400 total CCA instead of 1600 was the vehicle not being able to turn over.
    I don't remember what the Humvee did when he cranked it, and I'm too lazy to look it up, but the big giveaway is it's a CCA issue in my experience is, when turning the car over, all the interior lights will typically heavily dim or go out completely while the key is forward in the IGN position. Clicking it typical also - either the solenoid is getting energized and starter may even clank into the flywheel to engage but not getting enough juice to push the flywheel.
    KK6PD[QUOTED] likes this.
  14. Sep 10, 2021 at 6:45 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    If it doesn't end up being the battery I will say that I've dealt with replacing a starter to try and solve no crank issue only to find that the AC compressor had locked up while the truck was sitting. (03 6.0 Ford not a Tundra). Try disconnecting the serp belt if all else fails and see what happens.
    https://www.tundras.com/threads/2000-tundra-no-start-no-crank.90707/
    KK6PD likes this.
  15. Sep 10, 2021 at 6:50 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I like cheap first, battery test, if its good, jump the relay with a wire.. if it starts its the relay if it doesnt then its something else.. odds are is the battery or relay, since you already replaced the starter.
    KK6PD likes this.
  16. Sep 11, 2021 at 4:10 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    seems @Tundratoy2003 lost his way....
    Tundra won’t start
    bmf4069 likes this.
  17. Sep 11, 2021 at 6:01 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Yup. I just had to replace an 11 month old battery in my sho after it sat for at least 6 months without being charged. Weird thing is, it would jump and start, but it wouldn't hold electrons too well.
  18. Sep 12, 2021 at 6:35 AM
    Could've been a bad battery altogether. Or not enough distilled water in the cells.
    There's apparently a trick you can do with epsom salt and distilled water to help boost your battery I've never tried because it sounded looney or overly risky to me.
    I think I may end up running up to NAPA in the not so distant future and having them throw their tester on my batt. I'll post more on that in the 'what you did today' thread to avoid a hijack here.
