Clunk sound when braking
Discussion in '2nd Gen Tundras (2007-2013)' started by red_5ive, Mar 24, 2022.
  1. Mar 24, 2022 at 10:48 AM
    red_5ive
    red_5ive [OP] Jedi Knight and friend of Cpt. Solo
    Southern California
    2008 4.7L CrewMax
    • 3.5" Maxtrac Spindle Lift • 2.5" Spacer • Monster XD778 18 x 9 wheels, +18 Offset • Nitto Ridge Grappler 325/65 R18 (34.6 x 12.8 - temporarily back on the 32s until I can decide on gears) • Nitro 5:29 Gears (awaiting installation - on hold for now) • Black/smoke headlights • Clazzio custom leather seats • Boss Wireless Android Auto head-unit • Backup camera
    I won't be able to look at this until this weekend so I thought I'd post here first and see what type of responses I get. And my shop is also booked this week so I couldn't get an appt until next week.
    So I noticed my truck makes a clunk sound when I quickly tap on the brake pedal. And when I say quickly, I mean not enough to engage the brake, just a very light and quick tap on the pedal. It doesn't happen if I brake normally where I initially feather the pedal and gradually press harder as I come to a stop.
    It only happens when the truck is moving forward. It does not happen in reverse. It happens in succession (e.g., if I'm coasting and tap the pedal in succession I hear the clunk each time). I can be at a crawl (even in neutral) or driving normal street speeds, and it happens even on a turn in either direction. While coasting I tap the brake I hear the clunk, and if I start to engage the brake like normal to slow down then release the pedal and tap it again, I hear the clunk. I'm not 100% certain, but I believe I heard a similar sound a few times from dips in the road, but it doesn't always happen.
    The sound mostly comes from the passenger side front. I was thinking maybe a bushing or even the strut especially given the age of the truck which just crossed 100k mi a few months ago, but the tap on the pedal isn't enough to shift any weight forward. The brakes otherwise operate fine when braking normally, and I don't notice anything off with the steering and suspension while driving.
  2. Mar 24, 2022 at 11:25 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Check if your brake caliper bolts are tight. I went wheeling a few weeks ago and 1 of the 2 brake caliper bolts came right out, lost on the trail somewhere. It was making noises prior but I could never pinpoint it.
    Don't even need to remove the tires. 19mm
    des2mtn, 2mchfun and red_5ive[OP] like this.
  3. Mar 24, 2022 at 11:46 AM
    2mchfun
    Just to eliminate em', check your lug nuts. Once upon a time I had a case of an attempted wheel theft I think. Took off down the road and noticed some clunking at times. Some lug nuts had been loosened without my consent. Could have easily made for a bad day!
    TheBeast, red_5ive[OP] and Cruzer like this.
  4. Mar 24, 2022 at 11:57 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Unauthorized loosening...reminded me of the drive home from Moab last year. Driving on the freeway. Something was off. Truck was vibrating. Decided to pull over to look around.
    4 lugs were missing:
    But it was actually 4 wheel studs that had snapped off and I was driving around with 1 lug nut doing 80mph :eek2:
  5. Mar 24, 2022 at 12:13 PM
    Kanobi13
    Kanobi13 New Member
    Lucky!!!
    2mchfun, thunder100, GODZILLA and 3 others like this.
  6. Mar 24, 2022 at 12:17 PM
    red_5ive
    Southern California
    2008 4.7L CrewMax
    That was it! Both bolts were a couple of turns loose. Just hand tightened it with a wrench for now and test drove it and clunk is completely gone. I'll torque it down tonight.
    Thanks! Saved me from having to troubleshoot!
  7. Mar 24, 2022 at 12:35 PM
    red_5ive
    Southern California
    2008 4.7L CrewMax
    Man, glad it held up for you! More evidence at how awesome Tundras are? ;)
    And speaking of unauthorized loosening, we had an issue in my neighborhood with some punks loosening up lug nuts a few years ago. It was reported in the neighborhood Facebook community page. I hate FB, but it's stuff like this that makes it worth keeping. My next door neighbor got hit if I recall. Fortunately we park in the garage and I rarely if ever leave our vehicles out overnight. Nevertheless I was still checking our lug nuts regularly for a while there.
    2mchfun[QUOTED] likes this.
  8. Mar 24, 2022 at 1:25 PM
    2mchfun
    IIRC these are one use bolts. Kinda crazy I sort of agree, but unless I am mistaken they have a thread locking compound applied to new ones to help secure them. Drove my 4Runner about 3 month ago and I was being pretty rough on the drivetrain when all of a sudden I heard dragging and clunking. Sure enough both bolts had completely fallen out somewhere in my travels. Luckily only a mile from home. Still need to get some factory bolts put in it now that it's getting warmer. Anyway, call your dealer parts, pretty sure they can see on the diagram where it specifies one use.
    red_5ive[QUOTED][OP] and Cruzer like this.
  9. Mar 24, 2022 at 1:36 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Bought a shit ton of new bolts since I'm always taking the calipers off. Adding red loctite on them now, not taking any chances.
    https://parts.toyotaofdecatur.com/p/63539618/90119A0277.html
    2mchfun[QUOTED] and red_5ive[OP] like this.
  10. Mar 24, 2022 at 1:38 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    The new bolts I got did not have thread lock on it.
  11. Mar 24, 2022 at 2:58 PM
    red_5ive
    Southern California
    2008 4.7L CrewMax
    So I just torqued the bolts down and also decided to check the other side. They were tight, but not torqued to spec. The bolts are new and I'm guessing were part of a spindle kit I had installed last Spring, so they probably weren't torqued to the right spec. It makes me wonder about my local off-road shop now, or at least the technicians there. The owner is awesome, really knows his stuff, but some of the techs tend to be flakes. Stuff like this makes me think I should have just done it myself. I'm just lazy these days.
    Thanks, yeah I'm gonna get a new set even if these are new bolts.
  12. Mar 30, 2022 at 6:55 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    If its any of the bolts the hold the front calipers or the rear one to the hub assembly put red lock tight on the treads.
    red_5ive[OP] and 2mchfun like this.
  13. Mar 31, 2022 at 1:36 PM
    Borgunit
    Borgunit New Member
    JR
    Ohio
    2013 Black Rock Warrior
    Dang. Talk about cutting it close.
  14. Aug 22, 2022 at 12:24 PM
    IowaGuy
    IowaGuy New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    Old thread but I am having the same clunk. Can someone show or tell we where to check these brake caliper bolts and tighten them? I assume they are on the inside of the wheel.
    My noise sound like a plastic blend / vent door would if you flapped it shut in that it is a plastic dull thud. Mine is only when moving forward and a little after braking but not every time and not if I brake fairly hard.
  15. Aug 22, 2022 at 12:34 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    What's rolling around in your storage boxes.?
  16. Aug 22, 2022 at 12:38 PM
    IowaGuy
    IowaGuy New Member
    In Process
    Nope, I checked those and looked all over the truck in and out.
  17. Aug 22, 2022 at 12:40 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Turn your wheel so that you can see the back of it and check these 2 bolts.
    IowaGuy[QUOTED] likes this.
  18. Nov 23, 2022 at 4:43 PM
    FredB32
    FredB32 New Member
    2011 TRD RW
    Resurrecting this....did the rear brakes myself 2-3 months ago and had the front brakes and suspension done by a shop about a month ago...I've been getting some awful vibration, pad squeal and an intermittent clunk, which all seems like it's coming from the front end. Lugnuts are tight, trim rings (Rock Warrior) are tight...everything looks good and connected, but I didn't check the tightness (it was late, cold, and dark last night). Does anyone think these two stupid bolts could be the culprit(s)?
  19. Nov 23, 2022 at 11:24 PM
    red_5ive
    Southern California
    2008 4.7L CrewMax
    Maybe check the brake caliper bolts? I was getting a clunk that turned out to be the passenger side brake caliper. I had some general service done including the brakes, and they must not have tightened/torqued the caliper bolts as they were 2-turns loose, so they were shifting when feathering or initially applying the brakes.
  20. Nov 24, 2022 at 6:02 AM
    FredB32
    FredB32 New Member
    2011 TRD RW
    Checked quickly this morning and everything felt okay. The only potentially loose bolt was the sway nar end link but I don't think it's supposed to be super tight and wouldn't cause these issues?
    I might have to jack off up and pull the wheels tomorrow to see if there's annoying I missed.
