Code: P1442 - Safe to install bypass kit?
Discussion in '1st Gen Tundras (2000-2006)' started by migx333, Apr 13, 2020.
  1. Apr 13, 2020 at 2:21 AM
    migx333
    migx333 [OP] New Member
    Code: P1442 Secondary Air Injection System Switching Valve no. 2 Bank 1 Stuck Closed.
    Upon research I see that most people recommend getting the bypass kit:
    https://hewitt-tech.com/store/index.php?l=product_detail&p=12
    I am a bit skeptical about this. I am reading that it can cause major and very expensive problems down the road but then I am also reading that the only thing the system does is pump air into the cats to get it hotter quicker for emission purposes.
    Can anyone care to chime in and quickly explain why this bypass route is safe?
    And after installing this bypass kit should I be looking out for anything in particular after bypassing that specific code since the computer won't be detecting it anymore?
  2. Apr 13, 2020 at 4:54 AM
    growit
    growit New Member
    2006 Dbcb SR5
    I used that kit on my 2006 several years ago with no problems since, it's a very easy install.
    revtune likes this.
  3. Apr 13, 2020 at 9:34 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    https://hewitt-tech.com/store/index.php?l=product_detail&p=29
    I used this on my 2006 and everything has worked good so far.
  4. Apr 13, 2020 at 10:02 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    noahrexion likes this.
  5. Apr 13, 2020 at 10:29 AM
    sflips
    sflips New Member
    Middle Tn.
    2006 DC XSP
    I have it on my 06, highly recommend it.
  6. Apr 13, 2020 at 12:32 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    For those that download/read that pdf, there is a link in the 2nd paragraph that's supposed to take you to a Tundrasolutions tthread about AIP. Due to the fubar caused by TS and other similar run sites changing to Xenforo software, most of their past links are screwed. The below link is the correct link referenced in the pdf.
  7. Apr 13, 2020 at 1:22 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Excuse my ignorance but can you still install it since the valve is stuck closed? Im assuming you can because its a "bypass kit" but still just wondering.
  8. Apr 13, 2020 at 8:38 PM
    migx333
    DO you recommend the PPP (pump proxy pack)?
    I just got the normal bypass without the PPP
    Thanks guys! im installing it as soon as the kit arrives
  9. Apr 15, 2020 at 12:44 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
  10. Apr 15, 2020 at 4:00 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    It’s not totally necessary, but it will get rid of a couple check engine lights associated with the air pump. The bypass kit eliminates the air injector tubes and prevents your truck going into limp mode.
  11. May 30, 2021 at 5:54 PM
    wandering_boy
    wandering_boy Junior Tech Wizard
    California
    2005 AC SR5 TRD
    Don't let a kid out smart you.
    As beautiful as it sounds. Will you still pass emissions??? I unfortunately live in CA. Stupid CARB MF's...
  12. May 30, 2021 at 8:19 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    did that one require running a wire for 12v ignition? if it doesnt im tempted..
    EDIT: i see this thread was a revive... lol
  13. May 31, 2021 at 4:55 AM
    Professional Hand Model
    Hand Protectors
