Code P1633 throttle position sensor issue?
Discussion in '1st Gen Tundras (2000-2006)' started by Miwuc, Apr 21, 2021.
  1. Apr 21, 2021 at 7:40 AM
    Miwuc
    Miwuc [OP] New Member
    Had code p1633 (P1633 TOYOTA - Engine Control Module Malfunction Electric Throttle Control System Circuit) pop up a couple days ago. Pressing the gas pedal did nothing until it's at the floor and then the engine goes up to about 4-5000 rpm. Disconnected the battery for a minute and the truck went back to normal. Could it be a bad throttle position sensor? I read you have to change out the whole throttle body if that's the case, is that true? Hoping it's not the ecm. If it was a bad sensor why would it work fine after a quick disconnect of the battery?
  2. Apr 21, 2021 at 1:39 PM
    Professional Hand Model
    Hand Protectors
    What year and model truck? Access or Double Cab?
  3. Apr 21, 2021 at 2:41 PM
    Miwuc
    Sorry should have included that, 2002 4.7 access cab.
  4. Apr 21, 2021 at 9:32 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    It coulda just got outta whack and a reset got it back in line. Keep an eye on it.
  5. Apr 25, 2021 at 8:03 AM
    Miwuc
    This has been happening frequently now. Light comes back on after about 60ish miles after reconnecting the battery.
  6. Apr 25, 2021 at 8:20 AM
    Hand Protectors
    Sounds like you need new part.
  7. Apr 27, 2021 at 11:49 AM
    peanut
    peanut making uneconomical choices about my truck
    2001 Tundra 4x4 V8 Access cab 222k miles
    There is an ECTS fuse in the fuse box under the hood. It might be blown. Was for mine and replacing it got things working again.
  8. Apr 27, 2021 at 12:00 PM
    Miwuc
    Fuse is good and all wiring/ connections seem fine as well.
