Code Reader
Discussion in '1st Gen Tundras (2000-2006)' started by f-edtruckgotmemessedup00, Mar 5, 2024.
  1. Mar 5, 2024 at 5:56 AM
    f-edtruckgotmemessedup00 [OP] New Member
    Eamon
    2000 RCLB V8 4WD SR5
    Good code readers for 2000 Tundra? Not looking to break the bank, and ideally I could find it locally. (The second might be a weird ask for a forum question) thanks.
    Started throwing a check engine after a 400 mile trip. Didn’t throw the code on the trip. Runs good, transmission feels good, starts right up. Check engine came on during a short commute the next day.
  2. Mar 5, 2024 at 6:08 AM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    If you only want to read codes, any $30 OBDII reader from scAmazon will work for that. Or just pull into an auto zone and have the kid read you the code from his $30 scanner for free.
    NewImprovedRon likes this.
  3. Mar 5, 2024 at 6:10 AM
    Slag_Dynamics
    Slag_Dynamics Cut. Weld. Repeat.
    Arizona
    Gone
  4. Mar 5, 2024 at 7:01 AM
    Eamon
    “If I only want to read codes” would something more complicated be able to make a more accurate diagnoses? I’ve heard of Carly, and while they’re expensive is something like that an example of what would read more than just codes?
  5. Mar 5, 2024 at 7:04 AM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    Most inexpensive ones will read ECM only. Others will read TCM, ABS and Airbag. It just depends on your needs.
  6. Mar 5, 2024 at 7:06 AM
    Eamon
    Perfect. Thank you. Would a NAPA do this for free also or no?
  7. Mar 5, 2024 at 7:10 AM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    Call and ask. I know most chain auto parts stores will.
  8. Mar 5, 2024 at 10:38 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    I agree with this. It can also be used on multiple vehicles, real time data, basically all systems. Plus detailed explanations of DTCs.
    Slag_Dynamics[QUOTED] likes this.
  9. Mar 5, 2024 at 2:48 PM
    $5 says it’ll be an O2 sensor code.
    ATBAV8 and NewImprovedRon like this.
  10. Mar 10, 2024 at 2:54 PM
    meeseeks55
    meeseeks55 New Member
    2002 SR5 Access Cab 3.4L V6
    If you're not looking for anything fancy then there's cheap options on Amazon. I would guess Walmart would have some options as well.
