Codes P043F, P2419, P043E, P2402, & P2401
Discussion in '2nd Gen Tundras (2007-2013)' started by Eduxstad, Jun 1, 2021.
  1. Jun 1, 2021 at 12:12 PM
    Eduxstad
    Eduxstad [OP] New Member
    2010 Tundra SR5
    My check engine light is on and these are the codes that the truck is showing. My main question is does the EVAP charcoal canister generally go bad with these codes or can I just replace the pumps and values for these codes. No obvious damage to any of these systems so I am probably just going to replace most of the parts anyway as the truck is 11 years old.
    Other than going to Toyota for the parts are there any other parts brands on say Rockauto.com that are reliable?
    First time posting on this forum and thanks for any information.
    Leo's first likes this.
  2. Sep 1, 2021 at 2:56 PM
    handyman99
    handyman99 New Member
    2010 Black Tundra TRD
    Eduxstad...did you correct this problem? I have the exact same issue on my 2010 Tundra.
  3. Sep 2, 2021 at 7:41 AM
    Eduxstad
    2010 Tundra SR5
    I did order the evap canister, pumps, and a new gas cap for my Tundra. I put the new gas cap on and it seems to have fixed the problem for now. Will put on the other parts when the weather cools down here in Texas.
  4. Sep 2, 2021 at 9:58 AM
    handyman99
  5. Sep 2, 2021 at 10:00 AM
    handyman99
    Was your gas cap gasket torn?
    The rust on the hose clamp in the previous picture from my 2010 Tundra is of concern. Might have water intrusion.
  6. Sep 3, 2021 at 6:52 AM
    Eduxstad
    2010 Tundra SR5
    My original gas cap seemed fine, but I replaced it anyway as it was cheap. No way to tell from the outside of evap canister if there is an internal problem.
  7. Sep 3, 2021 at 7:16 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome
  8. Sep 12, 2021 at 7:09 AM
    handyman99
    I bought a new gas cap and cleared the codes. The check engine light did not illuminate and the P2419 code was eliminated. The other 4 codes came back. After a few days, the check engine light returned as did the P2419 code.
    Ordered evap canister from RockAuto.
  9. Sep 12, 2021 at 8:21 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Late to this conversation, but if you push in the evap hoses by the airbox. There is a small rectangle with 2 or 3 hoses plugged in and a hose with a green cap can sometimes clear thise codes.
  10. Sep 22, 2021 at 1:20 PM
    handyman99
    RockAuto is solid. Received EVAP canister within two days after placing the order.
    The remove/replace of the canister was easy until the final step. I unable to reinstall the red C clip on the rightmost port. I pushed the hose/connector as far onto the port as it will go. The clip is to slide over the connector and after the barb on the port. Anyone have any experience installing this type of clip? See attached pics.
    To test the canister, I attached the hose using a zip tie and electrical tape. Cleared the codes with the OBD2 scanner and no more CEL!
    Just need to install the C clip.
    Ktate likes this.
  11. Jan 14, 2022 at 4:58 AM
    Randy.lee88
    Randy.lee88 New Member
    Silver sky metallic 2010 Tundra
    I noticed there's 2 options on Rock Auto, which one did you go with and did it come with everything needed?
  12. Jan 14, 2022 at 2:33 PM
    handyman99
    mb66, pickeledpigsfeet and Beau like this.
  13. Jan 15, 2022 at 12:17 PM
    Beau
    Beau De gustibus non est disputandum
    Beau
    2008 Sequoia with a 2022 style
    Can you post the procedure? I’m having the same codes and hope it will be helpful for a 2008 sequoia. If not, I bet others will benefit from it. Thanks.
  14. Jan 16, 2022 at 8:46 AM
    handyman99
    Ok, this procedure worked for me, can't claim it works on all vehicles/situations. Please take all necessary safety precautions.
    mb66, Trooper2, Beau and 1 other person like this.
  15. Mar 17, 2023 at 5:15 AM
    NAVGATOR
    NAVGATOR New Member
    '08 Tundra Limited CrewMax
    Just replaced my charcoal canister and was able to get everything connected, except for the red C retaining clip. I have the hose seated flush to the canister but cannot seem to get the clip to connect. Any suggestions?
  16. Apr 7, 2023 at 5:44 AM
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    As much as I hate to resurrect old threads... I have these exact codes. Was the canister the problem for you guys? Has the CEL come back since swapping it out?
  17. Apr 7, 2023 at 6:10 AM
    Beau
    Beau
    For me, I was purposeful in making sure that I didn’t overfill my gas tank anymore. When the gas pump clicks and stops, I’m done. The CEL hasn’t returned. It took about a month (possibly the canister had to dry out?). Hope you get it resolved!
    mb66 likes this.
  18. Apr 7, 2023 at 6:40 AM
    1BadTundra
    Clinton
    Too Much to List
    Thanks, I'm gonna pull mine down today. I'm guilty of topping off my tank... Been doing it since 2010 when new. Sounds like it finally bit me.
  19. Apr 7, 2023 at 2:38 PM
    NAVGATOR
    NAVGATOR New Member
    I replaced my canister after swapping out the gas cap and not overfilling my tank anymore after seeing the same codes for about four months. No codes since and my truck is running smoother now than it has in over a year.
  20. Jul 29, 2024 at 12:07 PM
    rileymichael95
    rileymichael95 New Member
    Michael
    This just happened to me on my 07-4.7L. I took a long trip and the day after I got back home it is throwing these codes but is driving just fine. Is this an easy DIY? Is this something that needs to be fixed immediately? Also, I noticed aftermarket part is half the price of OEM.. I really appreciate the help..
  21. Jul 30, 2024 at 7:10 AM
    1BadTundra
    Clinton
    Too Much to List
    Yea, easy fix, just a pain to figure out which one. Mine ended up being the harness for the front left speed sensor. I narrowed it to the front, replaced both sensors, then got a new code saying left sensor. Already having a new sensor, I swapped the harness feeding the speed sensor and that was it. Mine was corroded at the plugs, and turned the wires black and green... Couldn't read continuity from one, the other had a high resistance which indicated to me it was on its way too. I swapped the harness and we are back in business.
