Cold transmission "slips"
Discussion in '2nd Gen Tundras (2007-2013)' started by OldAmerican, Jan 2, 2025.
  1. Jan 2, 2025 at 3:03 PM
    OldAmerican
    OldAmerican [OP] New Member
    2010 Pyrite 4x4
    I have a 2010 4x4 with just under a 100k on it. Have done a little towing over the years but not a lot. Recently developed this glitch where when I first start it up cold and shift into drive, it feels like the tranny is slipping and then quickly catches and off we go. Once it warms up, all is normal. Did a drain and fill and added some Lucas treatment. Fluid was definitely not clean. But that didn't help Time for a flush? Bigger problems?
  2. Jan 2, 2025 at 3:10 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Time for the proper diagnostics. May end up in replacing a solenoid or the full valve body (which is still cheaper than transmission or truck).
  3. Jan 2, 2025 at 3:18 PM
    OldAmerican
    2010 Pyrite 4x4
    Roger that on the transmission cost. Have been toying with replacing the truck and this might be the deciding factor. Truck has not given me any issues thus far but the bed is a rust bucket like so many others of this vintage.
  4. Jan 2, 2025 at 4:27 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    When you did the drain and fill did you check the final level or just put in what came out?
  5. Jan 2, 2025 at 4:37 PM
    koditten
    Kirk
    Midland of the Mitten
    My 08 and my 21 does this as well. I just assumed it was the time it takes for the electronic signal to travel to whatever solenoid is needed to change gears.
    2 trucks over a dozen years and they act the same, I'm not losing any sleep.
    The '08 has 250 k miles. It's done it since new.
  6. Jan 2, 2025 at 5:18 PM
    OldAmerican
    2010 Pyrite 4x4
    Did a level check. Since then I have seen a post about the gyrations you are supposed to do when checking the level. All I did was get it hot and check for a little bit of fluid coming out of the fill opening
    MadMaxCanon[QUOTED] likes this.
  7. Jan 2, 2025 at 5:20 PM
    OldAmerican
    2010 Pyrite 4x4
    Since the truck never used to behave this way, I assumed something was going south. Maybe not. Still makes me uncomfortable.
    koditten[QUOTED] likes this.
  8. Jan 2, 2025 at 6:00 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    Mdl likes this.
  9. Jan 4, 2025 at 4:40 AM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    You need to do the correct procedure . I would guess the level is low.
  10. Jan 4, 2025 at 6:30 AM
    OldAmerican
    2010 Pyrite 4x4
    I would agree, and that may be part of the problem, but the reason I did the drain and fill was because of that issue surfacing. If the temps moderate a bit here can certainly check it out before turning over to a dealer.
  11. Jan 4, 2025 at 1:47 PM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    It could have been low for while, possibly since new.
    The "check" temperature is lower than normal operating temp. When I checked my fluid level with the jumper wire method, the trans gauge was reading about 3/4 of normal operating temp. Not sure why toyota has to make this so complicated..
  12. Jan 4, 2025 at 2:40 PM
    Tundra family
    Tundra family New Member
    "Morning sickness". My truck locks out 5th and 6th until the trans is up to temp.
  13. Jan 4, 2025 at 3:03 PM
    I would add a half quart and see how it goes.
    fixnfly likes this.
  14. Jan 4, 2025 at 4:54 PM
    OldAmerican
    2010 Pyrite 4x4
    I hear you on the complicated check process. Whatever happened to the old days where you pull a dipstick?
    fixnfly[QUOTED] likes this.
  15. Jan 4, 2025 at 4:55 PM
    OldAmerican
    2010 Pyrite 4x4
    Always heard it is a bad idea to overfill. Not so?
  16. Jan 4, 2025 at 5:48 PM
    I have a feeling you are a little low.
    Did you pin the trans thermostat when you drained?
  17. Jan 4, 2025 at 5:52 PM
    OldAmerican
    2010 Pyrite 4x4
    Did not. Video I watched on UTube didn't go through all the gyrations that Toyota wants. Getting too old for this nonsense!!!
  18. Jan 4, 2025 at 6:01 PM
    Sounds like you might be a bit low.
    The reason I'm suggesting this is after warm up the transmission shifts and acts fine (fluid expands when heated).
    There are some other really great suggestions in your thread here, but this is the cheapest troubleshooting step.
    If this solves your problem, I would redo the level check procedure at the correct temperature. For example, my Lexus IS350 temp range to check fluid is 110-117*F then open the overflow drain while in Neutral.
  19. Jan 4, 2025 at 6:14 PM
    OldAmerican
    2010 Pyrite 4x4
    Nothing to loose by giving it a try! Hopefully the temps will go up a bit so I don't freeze these old bones. Thanks.
