collision sensor needs to be recalibrated after swapping grill?
Discussion in '3rd Gen Tundras (2022+)' started by Welderdude80, Feb 21, 2023.
  1. Feb 21, 2023 at 7:25 PM
    Welderdude80
    Welderdude80 [OP] New Member
    JP
    Alberta
    2023 Tundra limited hybrid crew max
    working on it
    I just swapped grill on my '23 limited hybrid for a TRD sport grill. after everything was done I went to start truck and a message came up in dash something with collision sensor please visit dealership. am I the only it happened ? or can I do reset by disconnecting battery ? btw I got an hybrid and I think battery is under back seat? anybody on this forum did reset to clear code ?
  2. Feb 21, 2023 at 7:34 PM
    Psam
    Psam New Member
    Philadelphia
    2019 Tundra Trd Pro voodoo blue
    i didn’t have to get it recalibrated and everything is working fine.
  3. Feb 21, 2023 at 8:24 PM
    Fxclm5
    Fxclm5 New Member
    double check the wiring harness is fully engaged plugged together?
    Welderdude80[OP] likes this.
  4. Feb 21, 2023 at 8:27 PM
    Welderdude80
    JP
    Alberta
    working on it
    I’ll double check tomorrow. I’m pretty sure it’s in probably but you never know !
  5. Feb 22, 2023 at 10:35 AM
    Welderdude80
    JP
    Alberta
    working on it
    Reporting back here ! Guess what sensor in back came undone !! I probably didn’t push the plug back in far enough. I double checked every other connections. All good ! No more message in dash
    Black widow TRD and Yaboy like this.
  6. Feb 22, 2023 at 11:31 AM
    KroppDuster
    KroppDuster Out with the old and in with the...older?
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Glad you found the cause.
    Because this has come up several times recently as people have been doing more & more grill swaps, it's worth noting for others:
    A calibration issue really should not throw a DTC / Warning message. If you're getting a DTC, then it's likely something wasn't plugged in, has come unplugged, or a connection/component was damaged during the install.
