Compatible Parts?
Discussion in '1st Gen Tundras (2000-2006)' started by mountainflamingo, May 28, 2019.
  1. May 28, 2019 at 8:05 AM
    mountainflamingo
    mountainflamingo [OP] New Member
    Stephen
    2000 Tundra SR5
    Hey Tundra Universe! Have a question. Just picked up one hell of a lemon, misadvertising and my fault for not double checking. So seeing what suspension parts not “vehicle specific” folks have used to build out there rigs with. Front axles, racks, etc.
  2. May 29, 2019 at 11:51 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    For critical suspension parts, IE: upper and lower ball joints, I’d stick with Toyota. Shocks - depends on what you’re looking for. Bilstein makes good stock replacements to various lift and off-road needs. I think there are some good rebuilt steering racks - use the search function. There are several good brake options - I recently installed Brembo rotors with Toyota ceramic pads and new Toyota drums and pads.
  3. May 29, 2019 at 11:54 PM
    SoCalPaul
    Paul
    For front axles I did Toyota but I didn’t have OEM Toyota cores to send back. This place gets good reviews.
    https://www.cvjreman.com/
  4. May 30, 2019 at 3:21 AM
    :threadjacked:
    Welcome from NY.
  5. May 30, 2019 at 6:11 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    If you mean stuff off other vehicles that can be used on a Tundra there isn't much. Most Sequoia parts will swap over but on suspension we don't share much with Tacos or 4Runners.
    ethan1911 likes this.
  6. May 31, 2019 at 11:45 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Well, there is the guy with a SAS front and manual x-fer case who I believe is swapping the rear axle out. @ethan1911
  7. May 31, 2019 at 5:29 PM
    ethan1911
    ethan1911 I’m one of those regular weird people
    Black 2006 tundra double cab
    Dana 44 sas, 63” Chevy springs, shackle flip, 4.10 gears
    Welcome from MO. If your not looking for a performance off road suspension id stick with OEM parts. If you want modified suspension there are a few companies that make lifts and long travel kits or if your good with a torch and welder you can make about anything fit with enough work. I’m running a Dana 44 front, 14 bolt rear but a sas isn’t the option for everyone.
