Confirm the color of my truck and any recommendations on paint touch up products?
Discussion in '2nd Gen Tundras (2007-2013)' started by mike11895, Oct 13, 2019.
  1. Oct 13, 2019 at 1:49 PM
    mike11895
    mike11895 [OP] New Member
    2010 tundra doublecab long bed
  2. Oct 13, 2019 at 1:51 PM
  3. Oct 13, 2019 at 2:14 PM
    mike11895
    Thank you!!! It is slate metallic 1f9
  4. Oct 13, 2019 at 2:22 PM
    Sure thing. Glad that something I put on here was useful. :thumbsup:
  5. Oct 13, 2019 at 2:23 PM
    mike11895
    Would trying to cover up the spot look good? I'm thinking no now it might look worse. Any way to cover up that spot correctly or is a professional needed?
  6. Oct 13, 2019 at 2:28 PM
    That's a bit (a lot actually) above my skills to determine, especially not seeing it in person. Touch ups will never match true professional paintwork, but it depends on how picky you are. I'm picky. lol
    If you have a local body shop that you trust, you can swing in and ask. Most will give you an estimate, and you could ask them if it'll be ok with a touch up, or if it needs more TLC than that. Only do that if you know they're honest.
  7. Oct 13, 2019 at 2:38 PM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    I have a similar situation close to the same spot but more from underneath. I would find a professional. Mines going to cost $350. Another guy quoted $1K because he want to pull the bumper and do the entire fender. I'm a pretty good mechanic, but I ain't going to deal with having to feather that shit in for something a decent body man can have done with a couple of hours of labor. Yours should be less than three fiddy cause mine needs some grinding and filler
  8. Oct 13, 2019 at 2:43 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Check the door placard for the paint code. I believe its slate metallic. One of my favorite colors. You'll need to wet sand that areas prime bare metal, then paint it and fade it one layer at a time. Probably more wet sanding to even and level it all out. You can then use some 2k clear and wet sand that even and hope not all matches well. Pretty big job but a body shop would charge a lot.the spot looks like a ratchet toe down strap sat right grrr and caused that damage. That's goo bad cuz the rest looks clean
  9. Oct 13, 2019 at 3:43 PM
    mike11895
    Yea I hate myself because it was from a grommet on a tarp that I used to hold down some brush. Absolutely stupid mistake
  10. Oct 13, 2019 at 3:57 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Just fix it and go on about life. I bought mine with some damage in the same area from what looked like something whacked the fender like a tire tread from the road and tucked the rear fender in a good 3/4" from the bumper. Factory certified. They took $800 of the price. I got it out to the best of my abilities but will finish the job with a body shop. Joe blow on the street wouldn't notice. But now I can get it sanded, filled, and sprayed for three fiddy. It was on the lot for 29000 sticker. I got it for 24K because I bitched about the damage.
  11. Oct 13, 2019 at 4:13 PM
    daveyjames207
    daveyjames207 New Member
    Dave
    2013 SR5 DC 4x4 5.7 Off Road Nautical Blue Metallic
    I bought mine with this ding. They offered to fix it, I said take $700 off the price and they obliged. I buffed it pretty good at home but you can still notice a bit. Gives them character. Id just do the best you can yourself if you’re able, then have a beer. Don’t sweat it.
  12. Oct 13, 2019 at 4:17 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    I wonder if my wife drove that truck and didn't tell me. Looks pretty normal road rash for her:rolleyes:
  13. Oct 13, 2019 at 6:29 PM
    mike11895
    Yea tbh I don't care I did that like a couple years ago lol:) but thought hey maybe one of those paint scratch brushes works but whatever f it :benchpress:ill just keep sendin it ya know. I bought mine with tons of damage lol shouldve been worth $18k got it for $13k.
  14. Oct 13, 2019 at 6:37 PM
    Being a metallic paint I would definitely let a body shop fix that. But I am a little OCD. Lol
    GODZILLA likes this.
  15. Oct 13, 2019 at 9:20 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Perfect place to use a TRD decal to cover up.
    Pudge and mike11895[OP] like this.
