Confirm what size socket to take of wheels
Discussion in '2.5 Gen Tundras (2014-2021)' started by Doxiedad, Mar 8, 2023.
  1. Mar 8, 2023 at 6:18 AM
    Doxiedad
    Doxiedad [OP] Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    So i have tried searching for what size socket i need to take tires off my Tundra. It's a 2020 SR5 with the TRD Off Road package. Most of my results bring up lug nut size M14x1.5 I think?
    I did find one thread that said 21mm, I have a 21mm 12 point normal (not deep) socket and it doesn't fit, but the 22mm does.
    So can anyone verify what size impact socket i will need?
    Thanks
  2. Mar 8, 2023 at 7:11 AM
    ekw_92
    ekw_92 New Member
    Wisconsin
    2017 Super White Tundra 1794 TRD offroad CM
    2017 Tundra 1974 CM - Bilstein 6112/5100 1.9 with CB 2/1 shims. CB +2 shackles. 17x8.5 RRW wheels, 315/70/17
    Its a 22mm socket. 21mm for the new tundra.
    Doxiedad[OP] and 773_eddie like this.
  3. Mar 8, 2023 at 6:00 PM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    22mm for sr5 steel rims here.
    Doxiedad[OP] likes this.
  4. Mar 8, 2023 at 6:02 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    I used this fella when I had my Tundra: https://www.amazon.com/gp/aw/d/B00X08OG3G?ref=ppx_pop_mob_b_asin_title
    Doxiedad[QUOTED][OP] likes this.
  5. Mar 8, 2023 at 6:17 PM
    biebs96
    PA
    I can go check, but I’m pretty sure it’s a 22mm. I remember taking a lug into home depot to confirm the size before buying a thin walled impact rated one.
  6. Mar 8, 2023 at 7:07 PM
    Doxiedad
    James
    Charleston, SC
  7. Mar 8, 2023 at 7:52 PM
    Doxiedad
    James
    Charleston, SC
  8. Mar 8, 2023 at 8:09 PM
    AZBoatHauler
    So.Arizona
    Pretty sure 7/8” also works. Especially for the swollen nuts.
    radon222 and BlueRibbon4x4 like this.
  9. Mar 9, 2023 at 3:42 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    I liked it but that one you linked looks like it would be even nicer
  10. Mar 9, 2023 at 4:23 AM
    Doxiedad
    James
    Charleston, SC
    Ok thanks for the insight, ordering the Matco ones now
  11. Mar 9, 2023 at 5:36 AM
    Tiger85
    Tiger85 New Member
    2025 Mag Gray Platinum i-Force MAX
    Mine must be swollen, but Autozone sold a double ended socket with 22mm and 22.5mm on the other side. The 22.5mm works perfect.
  12. Mar 9, 2023 at 6:28 AM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    I would recommend using 6 point sockets.
