Convex mirror
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rider0120, Mar 20, 2020.
  1. Mar 20, 2020 at 5:34 AM
    Rider0120
    Rider0120 [OP] New Member
    Bucks County, Pa
    2018 White double cab SR 4x4 long bed
    Ranch Hand full replacement bumper
    I want a convex mirror for the bottom outside conners of the top mirror in the circle to see the outer lanes since I like keeping my bottom mirror for seeing curbs and parking lines. I have looked at some on Amazon but just wanted to see what others were using square vs round. I am keeping my OEM mirrors and I’m not open to replacing the whole assembly Thanks in advance. DCC632B3-9ACB-458F-8ECA-B0074DCA3F3C.jpg
  2. Mar 20, 2020 at 5:56 AM
    biebs96
    PA
    I’ll go grab a photo in a few. I have ones in that exact spot.
  3. Mar 20, 2020 at 6:22 AM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    I used round ones when I had them on my last truck
  4. Mar 20, 2020 at 9:37 AM
    biebs96
    PA
    2.5” round ones from autozone. 3.99 each. First mod on all my vehicles.
    myt1 likes this.
  5. Mar 20, 2020 at 11:33 AM
    TheBeast The Beach
    does it help ?
  6. Mar 20, 2020 at 11:35 AM
    biebs96
    PA
    I have them on each side. You can see the bottom of the rear tires, and it makes cutting my trailer into the driveway very easy because I can also see the bottom of those tires in the spot mirror as well.
    TheBeast[QUOTED] likes this.
  7. Mar 21, 2020 at 1:41 PM
    Grandaddy
    Grandaddy New Member
    Roanoke Rapids NC
    2018 Tundra Limited CrewMax 4x4
    none
  8. Mar 21, 2020 at 2:02 PM
    biebs96
    PA
    ^^ I like that without the edge!
    Ordered!
    Grandaddy likes this.
  9. Mar 21, 2020 at 3:26 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Not for OP since you're keeping the Toyota ones, but for others considering this - GM style mirrors the convex mirror is big enough to get both your tires and half the 2nd lane over. The Toyota convex tow mirrors are just too small. If they were 1-2" taller than they'd be good for seeing both like Ford or GM tow mirrors. And to those looking at switching the GM ones cost the same as Toyota style on eBay.
  10. Mar 27, 2020 at 4:20 AM
    Rider0120
    Bucks County, Pa
    So the reason I was against the aftermarket tow mirror was I thought I saw a couple that didn’t sit level/square with the door (tilted up). After looking on eBay they don’t seem bad. Do you have experience with these mirror’s? Are they plug and play with the run and turn signals? The GM have the spot light built in, would I hAve to wire them up to a switch?
  11. Mar 27, 2020 at 4:01 PM
    belanger9
    Edmonton, AB
    A bunch
    Love mine - that picture should give you an idea for how square they sit. Totally plug and play like the Toyota OEM (I had them on my truck before these) mirrors for power, heat, and turn signal. I wired up the spot light to the cargo light circuit which already has the switch in the dash. And you can get the GM ones with blind spot monitoring which others have had experience with - can't remember if it worked just as well or if it required a couple wires de-pinned and swapped.
    There's one with Toyota OEM style for you to compare the tilt to. I think the GM ones are a tad off square, but it certainly doesn't affect the visibility from them which is so much better on them than both the OEM styles. The one downside to them is that they're big, they block the view forward a bunch. It takes a little getting used to but the improved visibility back is worth it IMO.
