Coolant in Oil
Discussion in '2nd Gen Tundras (2007-2013)' started by MXPCUS, Feb 24, 2022.
  1. Feb 24, 2022 at 5:00 PM
    MXPCUS
    MXPCUS [OP] New Member
    Ken
    Southern IL
    2007 Tundra SR5
    Push bar and bed rails
    Got an oil change today and the guy said there's a little coolant in the oil by showing me the oil cap. I saw a video saying that if you don't drive for a long distance and it's cold outside (like right now) then it's probably just condensation in the engine and it's not burning off. Coolant levels were fine, but what could be the cause? I'll be taking it to a mechanic soon, just not Toyota directly because they charge 100% more than everyone else for no apparent reason
  2. Feb 24, 2022 at 5:08 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Head gasket.
    14burrito and Black Wolf like this.
  3. Feb 24, 2022 at 5:11 PM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Coolant in oil diagnosed by gas cap. I’m still trying to wrap my head around that.
  4. Feb 24, 2022 at 5:11 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    What color was this stuff on the underside of the oil filler cap (you said gas cap but believe you meant oil)?
  5. Feb 24, 2022 at 5:18 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Well did you check the coolant level? Is it low?
    To know for sure and for less than the mechanics will charge you, get the oil tested by blackstone, may need to wait a couple thousand miles first....you'll learn for sure if it does, exactly how much along with lots of other fun stuff about your oil. Luck.
  6. Feb 24, 2022 at 5:20 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    I'm assuming you meant oil cap (not gas cap). But yes, there could be some condensation on the oil cap if driven short distances. It may not get hot enough to normal operating temps to "burn" off the condesation.
  7. Feb 24, 2022 at 5:26 PM
    MXPCUS
    Ken
    Southern IL
    2007 Tundra SR5
    Yes sorry, oil cap. Under the cap was slightly muddy brownish. They didn't tell me if the oil they drained was muddy too. I only drive like 8 minutes to and from work and it's near zero degrees most nights. Coolant level was a little low
    Mr Badwrench likes this.
  8. Feb 24, 2022 at 5:33 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Brownish, yes just condensation, wipe it off good and drive it around and check it again, and when cooled down check radiator cap , if oil in water it will be floating on top,and in reservoir tank will be oily inside.
  9. Feb 24, 2022 at 5:34 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    O.K. That distance is not nearly far enough to get the engine to full temperature AND stay at full temp long enough to cook off all the condensation.
    Take a picture of the underside of the oil cap tomorrow morning and share it with us.
    Wynnded likes this.
  10. Feb 24, 2022 at 5:50 PM
    slowpokepete
    slowpokepete New No More
    Peter
    Hillsdale, NY
    2007 Blue Tundra DC 4x4 SR5
    I'm very wary of anything told to me by an "oil change place."
    SPP
    TheBeast, Ericsopa and landphil like this.
  11. Feb 24, 2022 at 5:58 PM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    I am thinking this sounds more like condensation rather than coolant as others have said. You could do an oil analysis but you would really need to put some miles on it first. Personally, I would just check the dipstick every week and see.
    landphil likes this.
  12. Feb 24, 2022 at 6:54 PM
    MXPCUS
    Ken
    Southern IL
    2007 Tundra SR5
    Worst case scenario if it is my head gasket what do you approximate that that will cost?
  13. Feb 24, 2022 at 7:16 PM
    2-2400.00
  14. Feb 24, 2022 at 7:24 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    It’s totally normal to have some mayonnaise build-up on the oil cap when the oil filler is an extended neck like these. The cap is a nice cool spot for condensation to form. And yes, short trips in cold weather make it worse.
    If your coolant level isn’t dropping, and you have no other symptoms, carry on with life.
    NUDRAT, Ericsopa, TILLY and 1 other person like this.
  15. Feb 24, 2022 at 7:39 PM
    MXPCUS
    Ken
    Southern IL
    2007 Tundra SR5
    If it ends up being the gasket, I'll probably just get rid of the truck
  16. Feb 24, 2022 at 8:12 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    I wouldn't get rid of the truck without doing an exhaust gas test on the coolant. The kits are pretty inexpensive, and that will tell you what you're dealing with.
  17. Feb 24, 2022 at 8:42 PM
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    2021 platinum crew cab
    How many miles on the truck?
    I’ve never taken a vehicle to an oil change place. Always have changed my own oil. And most of my high mileage vehicles built up gunk in oil cap.
  18. Feb 25, 2022 at 3:08 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    Don't go there yet. Start simple and cheap, it's probably condensation but watch your coolant level.
    NewImprovedRon likes this.
  19. Feb 25, 2022 at 5:59 AM
    Slim Gym
    Slim Gym New Member
    2013 Tundra DC 4X4
    Normal to have the build up in a truck driven short distances.
    You may want to replace your PCV valve. Cheap easy fix. When they go bad they allow high pressure to blow out gaskets, etc in your engine.
    If it still bothers you. You can add a oil catch can to the PCV side. Depending on the brand(the more you spend the more it filters), it separates vapors and other gases from the oil.
    MT Madman likes this.
  20. Feb 25, 2022 at 6:29 AM
    Pretty sure you don’t have anything to worry about.
  21. Feb 27, 2022 at 2:52 PM
    MXPCUS
    Ken
    Southern IL
    2007 Tundra SR5
    Okay. That looks like coolant and not just condensation
  22. Feb 27, 2022 at 3:18 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Looks different than my oil cap. But one time on my old chevy, pennzoil did that exact same deposit
  23. Mar 1, 2022 at 4:29 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I have what I call banana pudding on my oil cap. Short drives thru MN winters. My oil comes out as oil when I change it.
    I would've asked to see the oil for the chocolate milkshake, not so much the cap.
  24. Mar 1, 2022 at 5:20 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    if there's coolant in your oil, it'll be everywhere, not only the underside of the oil filler cap. Check your dipstick oil's color. If you just had it changed, it should still be a dark coffee color.
    Another suggestion, drive around for a while, normal driving for 20 minutes or so if possible, then check the underside of the filler cap when it's hot. Still got that rice pudding color?
    Other ways to test the oil: https://www.machinerylubrication.co...n bubbles or a dried,as a test for antifreeze.
  25. Mar 1, 2022 at 5:30 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    2020 Tundra SR5 Extended Cab TRD Offroad Package 8ft. Bed
    Bilsten 6112's with 2.5" Front Lift w/Bilstein 5160 Rear Shocks
    Most of the time that's condensation form short trips, means you don't drive it long enough for the engine to get hot enough!
  26. Mar 1, 2022 at 6:17 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    My wife thinks I take too long running errands.
    Even if I just need to run down the street, I'm not starting a vehicle to drive it for a mile and shut it off. I like to explore first. Take the scenic route.
    Moe2o4 likes this.
  27. Mar 1, 2022 at 11:59 AM
    MXPCUS
    Ken
    Southern IL
    2007 Tundra SR5
    I've checked my oil since then and it's still just looks like oil so I'm assuming this problem is just the cap alone.
    Moe2o4 likes this.
  28. Mar 1, 2022 at 12:04 PM
    Slim Gym
    Slim Gym New Member
    2013 Tundra DC 4X4
    You are not the first and will not be the last to be worried about it.
    It is a weekly post that pops up in the Facebook Tundra Group pages too.
    MXPCUS[QUOTED][OP] and Moe2o4 like this.
  29. Mar 1, 2022 at 12:10 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Take it for a long drive and I bet it goes away. As others said, here’s another vote for it’s not anything to be worried about. Just condensation.
  30. Mar 1, 2022 at 1:39 PM
    Mr Badwrench
    Mr Badwrench New Member
    This is normal in humid climates especially if you are driving short distances.
