Cooper Discovery AT3 XLT vs 4s
Discussion in 'Wheels & Tires' started by TundraNC, Aug 12, 2021.
  1. Aug 12, 2021 at 2:20 PM
    TundraNC
    TundraNC [OP] New Member
    Joel
    North Carolina
    18 Tundra Limited 4x4 SW
    Anyone run either or both of these tires and have an opinion about ride, gas mileage, or performance for either tire? I’m considering buying the 4S for weight and mileage, but am told the XLT will travel as far if not further being a 10 ply on lighter duty truck than they’re intended. I know the XLT is a bit heavier and not sure if that has affected anyone’s gas mileage compared to the 4S. Thanks for any help!
  2. Aug 12, 2021 at 3:07 PM
    Vuducrumax
    Vuducrumax New Member
    I just put on a set of factory sized at3 4s and haven't noticed any change in gas consumption. I was looking at the xlt but I don't need an e rated tire and the 4s was on sale and got them for cheap. Overall very happy with them. they are quite on the highway and much more aggressive looking than in photos.
  3. Aug 12, 2021 at 3:37 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    If you are worried about gas mileage you do not want E load LT tires, stick with the stock size and standard load tires. E load will reduce your MPG some, more if they are larger than stock sizes.
  4. Aug 12, 2021 at 3:37 PM
    TundraNC
    Joel
    North Carolina
    Thanks for the feedback. They also told me the 10 ply would feel more stable since it was more rigid, but I think that might cause it to feel more bumps in the road as well. The tread pattern looks the same except for the side lugs
  5. Aug 12, 2021 at 3:38 PM
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    I am running the cooper discovery AT3 XLT, rides great hardly any noise. With a heavier tire 275 70 18 I did have to go with the road force balance. As I do with all heavy tires. Very little road noise. As far as mileage I don’t buy vehicles based on mileage. I buy what I enjoy driving, regardless of mileage. Hope this helps
  6. Aug 12, 2021 at 3:48 PM
    TundraNC
    Joel
    North Carolina
    Not so much worried about gas mileage but they were selling more on longevity over life of the tire because Tundra is considered a light truck compared to a 250 and up series it would go further than the 60k warranty. Plus I don’t haul heavy loads so I was looking another advantage other than more mileage. It’s a win win with life mileage and no gas mileage change right? These would be 275/55/R20 and I travel on road 80% and off-road around 20%. Definitely going with the AT3 just narrowing my decision through research. Thanks for all the feedback
    poheller likes this.
  7. Aug 12, 2021 at 4:28 PM
    Rippyro
    Rippyro New Member
    2014 Tundra 1794 - Sunset Mica Bronze
    I'm curious about the XLTs as well. Not many long term reviews out there. I spoke with two guys at my local tire shop in two days. One recommended the coopers saying they have great life and are really quiet for an A/T. Another strongly recommended against them for poor rubber compound, can't keep them balanced, and wear problems. He said "I've had more people bring theirs in with negative opinions than positive after running them" (speaking about the coopers)
    :notsure:
  8. Aug 12, 2021 at 4:33 PM
    Toothpick
    Toothpick New Member
    TN
    2018 Black Tundra
    After about 5k miles on the xlt's I'm really happy with them. They ride way better than the p rated Falken's I was running, and have alot more tread.
    Rippyro likes this.
  9. Aug 12, 2021 at 4:48 PM
    Rippyro
    Rippyro New Member
    Same size between the Falken and Cooper?
  10. Aug 12, 2021 at 4:53 PM
    Vuducrumax
    I think the 4s actually has a higher mileage rating than the xlt. I got mine for $800 compared to $1300 for xlt so it was an easy decision to make image.jpgimage.jpg 275/55r20
  11. Aug 12, 2021 at 5:52 PM
    TundraNC
    Joel
    North Carolina
    They look good with the blue!
  12. Aug 12, 2021 at 7:02 PM
    Northwoods22
    Northwoods22 New Member
    MN
    2013 tundra grade
    I run the 4s. Very happy with them so far. Seem like a great all around tire
  13. Aug 13, 2021 at 2:54 PM
    TundraNC
    Joel
    North Carolina
    Sold. Going with the 4s
    Northwoods22 and Vuducrumax like this.
  14. Aug 14, 2021 at 9:40 AM
    Toothpick
    TN
    2018 Black Tundra
    The xlts were 265 vs 255 and a hair bigger diameter.
    Rippyro[QUOTED] likes this.
  15. Aug 14, 2021 at 11:35 AM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    If you tow super heavy or do any solid off-roading go with the XLTs if not the 4s will be just fine.
    I have the 4s on my Silverado that does not see off-road other than gravel roads and fields and does not tow.
    They have been great.
    I like a bit more greasier tread and side lugs for my truck that sees off road so the XLTs are not for that truck.
  16. Sep 10, 2021 at 10:21 AM
    Cockyram
    Cockyram New Member
    KC
    2017 Tundra TRD Pro Sunset Bronze
    Good comments, Thanks. Order my 4s set today.
  17. Oct 4, 2021 at 1:47 PM
    TundraNC
    Joel
    North Carolina
    Mine are being put on this month. Another question I have is, what PSI are ya'll running on the 275/55R20 tires? The truck came with the Bridgestone Duellers and the outsides have worn terrible which to me indicates not enough pressure or alignment issue. Well, I've had it aligned by Toyota to the specs and it still does it is pointing again to tire pressure. I run what the door jamb recommends 30psi in the front & 33 psi in the rear. I do not want these new Discovery tires to have the same issue. I was going to increase to 35 PSI all the way around and reset the TPMS, but welcome your experience with your trucks.
