Cover and rack
Discussion in '3rd Gen Tundras (2022+)' started by mtn406, Dec 10, 2023.
  1. Dec 10, 2023 at 2:01 PM
    mtn406
    mtn406 [OP] New Member
    Hello. I just bought a 2024 Tundra and wanting an opinion on what bed cover and racks to purchase. I don’t want to remove existing rails.
    Thank you!
  2. Dec 10, 2023 at 2:15 PM
    jhtram
    jhtram If I'm curt with you it's because time is a factor
    Jay
    Raleigh, NC
    2023 Lunar Rock Tundra Limited TRD
    OEM TRD Lift Maxxis RAZR AT LT285/65R20 tyres Spidertrax 1" Spacers Retrax Pro XR Tonneau Bumpershellz 'stache overlay TRD Pro Fender Flares Yakima Overhaul HD Bed Rack OEM Blackout Overlays aFe Front Tow Hooks Talon's Cat Shield Undercover SwingCase Toolboxes TufSkinz Console Cover (Matte black) ScreenProtech LCD and instrument cluster protectors Tailgate & bumper vinyl inserts (texas decal king)
    All depends on your use cases and budget. I went with a Retrax and Yakima overhaul HD. Happy with both but was not the most economical of choices.
    Figured it was worth the investment as I tend to drive my vehicles 10+ years.
    ETA: Retrax is the Pro XR. Mounts to the bed rails, has the track system to mount the rack and is a pretty easy self install. Purchased thru @SantanaRealtruck @ Real Truck.
    Tundraman479, Redward 25 and Alden like this.
  3. Dec 10, 2023 at 2:56 PM
    romanlegion
    romanlegion New Member
    Roman
    Katy, TX
    2022 Tundra SR5 TRD Off-Road Lunar Rock
    I have the Expedition One MULE Rack and BAK Industries Revolver X4s tonneau cover. Sorry the tonneau cover cannot be seen in the photos.
  4. Dec 10, 2023 at 4:11 PM
    Hella Krusty
    Hella Krusty New Member
    That looks real good. Well done !
  5. Dec 10, 2023 at 4:13 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Diamond back SE and Thule Tracrac, adds about 100 lbs to the truck. Great for the kayaks and carrying longer items.
  6. Dec 11, 2023 at 10:17 PM
    ncart
    ncart New Member
    2022 Lunar Rock TRD Pro
    I have this same setup. Very happy with it.
    Redward 25, Alden and jhtram[QUOTED] like this.
  7. Dec 12, 2023 at 3:23 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    How is the rack mounted to the diamondback?
  8. Dec 12, 2023 at 1:26 PM
    Todd34
    Todd34 New Member
    I have the Diamondback HD and an UpTop rack. I like it so far.
    PBNB likes this.
  9. Dec 14, 2023 at 1:53 PM
    lhfungo
    lhfungo New Member
    Dennis
    Retrax Pro XR with Rhino Rack risers and cross bars. I went low for easy loading and unloading of the bikes. If I get a kayak or canoe, I'll have to switch things up.
  10. Dec 15, 2023 at 6:14 AM
    TexasTacoma713
    TexasTacoma713 New Member
    2023 SR5
    How you liking them Swagman bike roof rack?
    Debating between them of the pricer 1up rack
  11. Dec 15, 2023 at 5:23 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I added 1"x3" aluminum blocks and bolted through the cover sections. The tracrac wants bed edges so I made them with the aluminum blocks. I didn't want to modify the feet on the rack to reduce the load capacity. I could have cut the feet flat and bolted them directly but you loose the strength where it is needed.
    The DB racks are great for adding all sorts of things to customize what you are carrying.
  12. Dec 15, 2023 at 10:51 PM
    lhfungo
    lhfungo New Member
    Dennis
    The Swagman racks have done a fine job. Nothing flashy about them but I’ve put them to the test over a few thousand of travels by now. For piece of mind, I use a terry cloth towel around the bikes uptube and the swagman clamp. I also use an additional ratchet strap for each bike. Keep in mind, neither bike on my truck is worth more than $500. I may do things differently as the bikes improve.
  13. Feb 19, 2024 at 7:36 PM
    andywocky
    andywocky New Member
    2024 Tundra 1794 Limited Edition (Blueprint)
    Would you mind posting pics? This sounds interesting..
  14. Feb 19, 2024 at 7:52 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Here are some shots of the Thule bolted to my DB cover.
  15. Feb 19, 2024 at 7:56 PM
    andywocky
    Thanks, I see what you did, now.
    So .. why Thule instead if Yakima Overhauls?
  16. Feb 19, 2024 at 7:58 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Way more money for the Yakima. And the Thule is a beast with huge capacity.
  17. Feb 20, 2024 at 10:27 AM
    shawn474
    MoCo, Maryland
    I actually bought a Yakima overhaul clone from Amazon - I took a flyer knowing that they had a 90 day return policy and just couldn’t stomach the cost of the Yakima. It is almost identical to the Yakima and I have used it for a couple ski trips and to haul stuff. Really impressed so far.
    andywocky likes this.
  18. Feb 21, 2024 at 5:32 AM
    bobby4
    bobby4 New Member
    Thanks for this, I bought my tonneau cover before realizing I had no way to get my canoe on the truck. Your solution is fantastic, without drilling through the truck roof or having to buy a different tonneau.
  19. Feb 21, 2024 at 12:09 PM
    ESalt206
    ESalt206 25 Limited
    CO
    25 Limited Lunar Rock
    TBD
    Undercover Flex cover (tri-fold hard cover) and Elevate rack and rails.
    Easy install and work together well.
    Mattedfred likes this.
  20. Mar 4, 2025 at 9:02 PM
    joshua32
    joshua32 New Member
    2024 Celestial Silver Platinum HV TRD OR
    Do you have a link to the one you bought? Still happy with it?
  21. Mar 4, 2025 at 11:37 PM
    shawn474
    MoCo, Maryland
    Yes still very happy with it; the only thing I noticed was that the powder coat flaked off / MINIMAL surface rust on the tie down ends. Emailed the company and they sent me four more. I paid $50 less than it is selling for now, but it’s still wayyyyyyy cheaper than the Yakima. I would be hard pressed to tell a difference between it and the Yakima. Full disclosure = I did buy new stainless hardware for the t channel bolts that attach the rack to the base camp rails.
    https://www.amazon.com/gp/aw/d/B09K3WLJ58?ref=ppx_pop_mob_b_asin_title
  22. Mar 5, 2025 at 8:00 AM
    jhtram
    Jay
    Raleigh, NC
    Man I hate supporting chinese knock-offs but that is a great price.
  23. Mar 5, 2025 at 8:21 AM
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    So not removing the rails, you are going to be hard pressed. Maybe find a last gen bakflip mx4. That’s what I have. I’ll be adding an elevate t slot rail system, then some Yakima cross bars. May had the elevate rack as well. I didn’t want to loose bed space and wanted to keep the oem rails. So that’s what I found. If Thule had a quick release I would have gone with them since I get 40% off with them…
  24. Mar 5, 2025 at 8:24 AM
    shawn474
    MoCo, Maryland
    I would definitely not hesitate ; they're probably made in the exact same factory and definitely modeled after each other. I have had no issues carrying kayaks, skis, SUP, etc.
  25. Mar 5, 2025 at 4:00 PM
    joshua32
    joshua32 New Member
    Right on man! Thanks for the fast reply! I think I am going to pull the trigger too.
  26. Mar 5, 2025 at 4:05 PM
    shawn474
    MoCo, Maryland
    do you have a diamondback cover? I don’t use the side bars so I can still open and close the cover
  27. Mar 5, 2025 at 4:10 PM
    joshua32
    joshua32 New Member
    No I have a Retrax tonneau with the t-slots.
    shawn474[QUOTED] likes this.
  28. Mar 5, 2025 at 5:45 PM
    gesekee19
    gesekee19 New Member
    I have retrax Xr with Kuat Ibax…just got the Kuat and it looks slick and very modular
    MAC25Tundra likes this.
  29. Mar 5, 2025 at 6:08 PM
    SD Surfer
    Bruce
    So Cal
    Love my Elevate stuff!
    Very few options to run Tri-Fold tonneau and racks.
  30. Mar 5, 2025 at 6:25 PM
    joe8512
    joe8512 New Member
    that front bumper is insane. It looks so nice.
    Has anyone heard anything from dealers about bumper replacement voiding warranty?
    romanlegion[QUOTED] likes this.
