Cowboy Hat Holder
Discussion in '2.5 Gen Tundras (2014-2021)' started by lastgen5.7, Feb 23, 2024.
  1. Feb 23, 2024 at 5:45 PM
    lastgen5.7
    lastgen5.7 [OP] New Member
    21 Tundra SR5
    I bought this cowboy hat holder, and am trying to determine if I can mount it in this location without putting a hole in my roof. I know the back seat is an option where the handle is, but I would prefer it be here if possible. I know I need metal to screw it into.
  2. Feb 23, 2024 at 9:39 PM
    22creed
    22creed New Member
    Yes i believe so, i’ve had that panel put several times. You can pop that console out though to be sure. Either way you may be able to put a backer plate behind it and sure it up.
  3. Feb 23, 2024 at 9:54 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  4. Feb 24, 2024 at 2:12 AM
    2mchfun
    You might be able to give a backing plate a little more capacity by using either epoxy or magnets between it and the roof. Epoxy could also be used to secure nuts to the top side of the plate then cut fasteners to the length needed. Good luck and welcome to the forum!
  5. Oct 23, 2024 at 8:22 PM
    Conner2020
    Conner2020 New Member
    2020 Black Tundra SR5 4x4
    Lightbars, lift, custom wheels, larger tires.
    Anyone find a fix for this? I have a similar hat holder and I am looking to mount it in the same place.
  6. Oct 24, 2024 at 5:32 PM
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
    I slide my sunroof cover back enough works perfect.
    Florida AF likes this.
  7. Oct 25, 2024 at 9:25 AM
    seydou
    seydou Distinguished Member
    LOL
